Author Topic: NEW WOODMIZER LT40 SUPER  (Read 775 times)
Offline BattleChops
  • Finally Retired....Somewhat
« on: September 17, 2022, 02:23:50 PM »
Hello all, I need some help please.  Just brought home my new LT40 Super from Missouri yesterday, everything worked fine during the training while I was at the Wood-mizer shop.  Got home (Oklahoma City) and set up the mill, got a log all set up for my first cut and tried to engage the auto-clutch and all I here is a click on the side of the engine.  Everything works, I can move the head unit, the loader and the debarker, but the engine doesn't rev up and the blade doesn't engage when I use the auto clutch toggle.  I'm bound to be overlooking something since this is all new to me, if someone has some advice, I would really appreciate some help.  Thanks
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: NEW WOODMIZER LT40 SUPER
« Reply #1 on: September 17, 2022, 02:34:29 PM »
Your auto clutch motor is under a cover on the head of the Sawmill by the engine. I would take that cover off and see if that electric motor is responding to the engaging and disengaging of the switch. Call Woodmizer customer service in Indianapolis, they can guide you through it if you cant figure it out.
PS there will be a breaker for the auto clutch motor. I forget where it is, it might be one of the five in the control station, underneath the Swiches along the panel there five decals and breaker buttons. If not there then in the large electrical box on the head.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: September 17, 2022, 05:32:17 PM »
Congrats on the new Wood-Mizer.  8)
Monday is a looong way off, but make a call to them and they will walk you through the troubleshooting steps.  I am sure that it will be something simple that happened during traveling, but it still is frustrating.  :-X
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #3 on: September 17, 2022, 07:20:55 PM »
Look for the breaker if you havent.
LT 35 (Sold) Future Owner Woodmizer LT50, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #4 on: September 17, 2022, 08:11:37 PM »
Hello
  I assume this is a diesel? When you put the sawhead on rest pin and for transport the Auto clutch should be engaged. Was this done? If not the connection possibly came apart? Remove the cover under the engine and take a picture.
 It should look like this.
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline trimguy
« Reply #5 on: September 18, 2022, 07:50:10 PM »
Congratulations on your new mill.
Offline trimguy
« Reply #6 on: September 18, 2022, 07:53:03 PM »
Is the auto clutch supposed  to be engage for transit on just the diesel model, or on all sawmills (gas also)??
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #7 on: September 18, 2022, 09:19:50 PM »
My Manual says that it should be engaged for transport.
I flip the auto clutch switch back to the down position after I turn the ignition switch off.
This keeps me from starting the engine with the blade engaged
lots of dull bands and chains
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: September 18, 2022, 09:43:39 PM »
Here is a topic discussing this very subject:  LINK
Offline BattleChops
« Reply #9 on: September 19, 2022, 06:00:50 PM »
Thank you so very much to everyone for your help.  It was the 2 part linkage for the auto-clutch had decoupled during transit.  I was able to get it put back together and everything op-tested ok.  Now I just have to wait for the next weekend to try it out.
Offline tawilson
« Reply #10 on: September 19, 2022, 06:23:51 PM »
Thanks for the closure and the reminder to engage the clutch for the couple times a year I move the mill.
2017 LT40HDG35 WIDE
Woodmaster 725
woodmizer LT40 super
Started by rwepinetree on Sawmills and Milling
Last post October 19, 2015, 11:28:04 AM
by Solomon
Woodmizer LT40 super kobata Won't start
Started by Jmartish on Sawmills and Milling
Last post October 31, 2018, 10:24:51 AM
by Chuck White
woodmizer lt40 super drag back
Started by mikeb1079 on Sawmills and Milling
Last post August 15, 2015, 06:09:40 PM
by Brucer
moved
MOVED: Woodmizer LT40 super kobata Won't start
Started by Ron Wenrich on Ask The Forester
Last post October 28, 2018, 06:57:50 AM
by Ron Wenrich
