How many spools on a hydraulic bed
Started by JoshNZ, September 19, 2022, 02:17:48 AM
JoshNZ
I've had the opportunity to pick up some some valve spools for a reasonable price in my quest to gather parts for going hydraulic. I wondered how many valves you want for fully hydraulic bed only (not head). How many controls are valves and how many are diverted afterwards for multifunction.
Guess I'm also asking how many of each component you have, toe boards at each end, clamps turners etc.
Are the linked rotating backstops ok or would I be better off with two or three vertical back stops?
ladylake
My TK has
1  Head foward and back plus a speed control knob
2  Log clamp
3 Back stops up and down
4 toe boards with a selector for front or back
5 Chain turner chain
6 Chain turner up and down
7 Log loader
 All at a nice height.   Steve
Southside
If you think you may have a live log deck at some point in the future leave valves or at least a power beyond port available for those functions.
White Oak Meadows
JoshNZ
I've read a bit about power beyond and can't say I really understand it. What stops someone just plumbing the input port of a second spool to the tank return port of your first spool?
fluidpowerpro
You need power beyond because the cavities in the valve casting, at the end of each spool is connected to tank thus keeping the pressure for the spool seals low. Using the tank port as a pressure to feed a downstream valve would expose the spool end seals to high pressure. That part of the valve casting may not be designed for HP either. Also, depending on the valve you plumb in downstream, you may not have relief valve protection because the rv needs to vent to the tank port.
When a power beyond sleeve is used, you still have to connect the tank port of the first valve to tank, and the outlet of the power beyond sleeve is plumbed to the pressure port of the downstream valve.
Change is hard....
JoshNZ
Right I did wonder about it being a pressure problem. Are there spool banks designed for pressure on the tank port? I've been talking to this guy a while he's bought out a fallen over hydraulic company and has a bunch of stuff. One unit is a 4 and 2 bank spool plumbed exactly like that, little loop between ones output and next input.
Do you actuate power beyond on the first bank somehow?
JoshNZ
What do you make of that? Looks like it might be what you're describing with two hoses joining them
fluidpowerpro
No, you don't need to "actuate" power beyond in any way. Once the power beyond sleeve, or plug, is installed, it isolates the flow through galley in the valve from the tank galley.
Change is hard....
customsawyer
On my extended mill I have 7 functions on one spool and 6 on the spool for the extension. I run it off of a external hyd. pack. I have the feed line going to the 7 spool then what would normally be the return line going to the 6 spool, from there it is returned to the tank. I didn't know any better. Over the years different WM folks have been down to look at my mill. A few days after one trip I got a call from one of their top hyd. guys. He starts asking questions about how my mill and extension is hooked up. After a bit he tells me it won't work like that. All I could tell him was it had for about 10 years at that time and that was about 8 years ago.  It still works now. I'm sure there are reasons why it isn't supposed to work but as long as it does I'm not going to change it.
www.thecustomsawyer.com
Andries
Well CustomSawyer, it's plain to see that he didn't have faith in what you've finessed up.
The rest of us sure do.
"Faith Based Hydraulics" 👍
LT40G25
Ford 545D loader
Stihl chainsaws
Southside
I can't tell you how many extension, university, and other experts, who are all highly educated but don't actually farm for a living, have told me our farming methods won't work.
White Oak Meadows
customsawyer
Not trying to pick on the OP but I have always called them a valve bank and not a spool. I'm curious what is the proper name or is it a regional thing?
It's amazing how many things will work when you don't know that they aren't supposed to. I've also messed up my share of stuff with this same method of "I didn't think that would happen".
JoshNZ
It's when you go to do something obscure or strange with it when you might find out it doesn't work.
I think the spool is the actual steel rod inside the casting itself. They get called spools and valves here, I think proper name is "spool valve".
So new question on same track, should I link all the back stops with a rod and have them rotate up on one cylinder or have seperate vertical stops?
customsawyer
I would have all of the side supports on the same function. The fewer levers you have to use the quicker you'll be able to saw.
