Green ship lap/nickle back shrinkage
Started by Sedgehammer, July 30, 2022, 03:36:12 PM
Sedgehammer
If one was to put up green ship lap , what type of gappage wood there be on the sides and ends on interior walls?
I'm considering 1x12 , but could do 1x10 or 1x8 , but prefer the larger widths , but perhaps that's a mistake
Yellow pine most likely
Necessity is the engine of drive
doc henderson
inside an exterior wall, or interior wall?  It will need to release water from both sides, or it will cup, and could damage fiberglass insulation
Southside
Green SYP 1x12, expect up to 3/4" shrink depending on the grain.
White Oak Meadows
Sedgehammer
@doc henderson would've been both , but based on what @Southside mentioned , too much shrinkage . Some would be desired , but not 3/4"
What woods could one use with a lot less shrinkage
doc henderson
ERC is good.  maybe a brief period of air drying before milling and installation.
doc henderson
you are just the next state over. this time of year, I bet you could get it pretty low like 12 in a month outside.  stacked and stickered the OK wind.
Sedgehammer
@doc henderson yes , wrc is good , but spendy
Prolly quicker then that actually . Thinking of doing that instead of sheetrock
Southside
If you don't HT SYP you will get pitch bleed and issues with paint coming off.
White Oak Meadows
Sedgehammer
Southside
Heat treat - IE set the pitch.  No way I would install non KD, HT, SYP as an interior finish in a home.  Just trying to plane the stuff will convince you that it's a bad idea.
White Oak Meadows
Sedgehammer
@Southside thought that's what you meant after I sent that and was thinking of possible HT acronyms
Sedgehammer
No need to tag members who are already in your thread. Saves on having to delete those tags on our end. tks
Maybe only use the tag to those who you want to drag into your thread.
