Lube tank vent cap replacement?
Started by Ga Mtn Man, August 23, 2014, 08:47:05 PM
Ga Mtn Man
I've lost the vent cap for the lube tank on my LT40 and WM doesn't offer a replacement.  I've checked every cap on every bottle in my house and can't find anything to fit.  I'm thinking of threading the inside of the hole and installing some sort of a one-way air admittance valve.  Anyone got an idea or suggestion?
Dave Shepard
What, you don't like getting squirted on the head when the mill stops? :D I still have my original, I think, but the tank is long gone. Ordered two new tanks this summer, and put the caps in the toolbox. I bet something could be found a McMaster-Carr, or something like that. Let us know, I would thread mine and put a vent in there.
I just screwed the top on tight and drilled a small hole in the tank beside it with my knife point.  If I lost the cap, I would use Goop or something to close that hole.
leroy in kansas
Well, ya could measure the size needed then go to the supermarket or walmart and buy what ever has the correct size.   8)
Ga Mtn Man
Quote from: Magicman on August 23, 2014, 10:37:40 PM
I don't think I could sleep at night knowing I had bored a hole in my mill with a knife and covered another with Goop.  I'm just a little too up-tight about things like that for my own good. :-\
LeeB
My lube tank came from WM with a hole already bored in it. Same with the new one I just bought. actually never noticied it until I got the new one. No vent valve. I must be missing some part of the equation here.
Nomad
     Getting splashed with lube when the mill stops is annoying.  (I can't find a cap that fits it either.)
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Ga Mtn Man
Quote from: LeeB on August 23, 2014, 11:18:45 PM
Mine has had a small screw-on cap just above the handle that is intended to be loosened to vent the tank.
sprucebunny
I don't know what the cap looks like but here's an idea.
Find a cap that is a little bigger. Cover the threads  on the tank with plastic wrap.
Put silicone caulk into the cap. ( you may need to thicken the silicone by mixing corn starch into it. This will also make it set up faster)
Put the cap on the threaded part and let it set up.
Voila ! ???
LeeB
Do you suppose that would be diesel resistant?  :D I sure could have used an idea like that the other day.
I would call wood-mizer  and ask who they buy the tanks from, that company has a whole bin full. Probibly some gas can top would work unless WM gets the tanks from Hong Kong Harry. Frank C.
petefrom bearswamp
I'm guessing that you fellows (and gals) must ride, walk or have the command control center in the factory position.
I have swung  my CC about 20 degrees inward as I got tired of craning my neck to look down the log/cant.
Board return is not a problem as i built a deflection piece to keep the boards from hitting me.
My lube/coolant bottle came without a cap.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Correct LeeB.  The older lube jugs did not have a screw cap, just a small pre-drilled vent hole.  I did not like the new one because I forgot to loosen the cap a few times.  Retrofitting it back like the old one was worked fine.
Loosen up Paul, a vent hole will not end the world.  Use your drill and it will make a neater hole.   ;D
Ga Mtn Man
Quote from: bandmiller2 on August 24, 2014, 08:00:48 AM
I did call WM GA and WM Indy and was told by both that replacement caps are not available.
Quote from: Magicman on August 24, 2014, 08:35:54 AM
I can't do it Magicman.  This is a non-problem that requires an engineering fix.  I'm on it smiley_book2_page :).
LeeB
Go to a wine makers supply and get a spigot. You can then drill a 1/2" hole in the jug and affix the spigot. Open the valve for venting and close it for storage.
drobertson
Lost mine years ago, I just fill below the hole,  I have stuck a stick in it,  I kinda liked the idea of a larger cap filled with silicon,
LeeB
POSTON WIDEHEAD
Jeff's probably got several Forestry Forum caps left.  running-doggy
LeeB
tjhammer
Ga Mtn Man I have on ideal what size the cap size is but if a wine bottle cork will fit drill a hole in the cork and install a clear plastic hose long enough to fall over so the saw dust won't be sucked in the tank wine corks are great tools tj
hammer
terrifictimbersllc
5/16 bolt coarse thread blocks the splash and spill but still lets in air
Ga Mtn Man
Quote from: LeeB on August 24, 2014, 09:26:57 AM
This looks even better and I think I'll order a pack for all of my gas cans.
http://www.amazon.com/YELLOW-Chilton-Briggs-Rotopax-Rubbermaid/dp/B00MNC6L24/ref=pd_sim_sbs_lg_1?ie=UTF8&refRID=1JD03J1NH957TX15FZGE
I'll have to check the inside diameter of the existing spout to see if these will work but, regardless, I'm gonna order some of these for my gas cans.  Good find!
LeeB
You got me started, but yeah, good find. may have to put this on the general board for everyone to see. We all hate the new style gas cans.
j-dland
   A boat plug works well for me , and the hole is big enough for adding water from a hose.
David
QuoteWe all hate the new style gas cans.
I must be different, or have a different "new style".  I have the "no spill" style.  No venting problems and like the cans.
http://www.amazon.com/No-Spill-1450-5-Gallon-Poly-Compliant/dp/B000W9JN4S
