Charge Less for Beams?
Started by homesteader1972, March 10, 2015, 09:32:08 PM
homesteader1972
Got a potential customer wanting to build a log cabin, so it will consist of a lot of 6x12 logs/beams. Do you charge less for such, and if so how much less. Certainly the bf will add up fast that way, especially the 20 footers. What do yall do?
thanks much
Woodmizer LT40HD20G
terrifictimbersllc
U charge hourly so can't answer from experience . But cutting long beams accurately and handling them eats up a lot if any time savings.
ncsawyer
A little while back I sawed a bunch of 8x8 and 8x10 white oak beams to be made into trackhoe mats.  I quoted my normal board foot rate and it ended up being cheaper than he could have hauled them to a large mill and had them milled by the time you figured in the haul bill, so he was happy and I was happy.  The other thing to consider is the equipment needed to move the beams off of the mill.  That may add time to the milling process.
The alternative to charging by the board foot is to charge by the hour.  The bottom line is to work out a pricing schedule where you make money and he is satisfied.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
red
What kind of wood?   Whose LOGS?
Much depends upon how much support equipment is there and who is furnishing it.  I do not provide any support equipment, so that would be hourly rate for me.
4x4American
Is this on a portable job you talking?
Boy, back in my day..
homesteader1972
Its a mobile job, his logs, poplar. He provides the skid steer. Its sounding like you all do not discount any, and maybe charge hourly. Do most of you find that it takes longer to mill long beams like this?
Thanks again
Woodmizer LT40HD20G
Jim_Rogers
By the bdft. You have down time while you're waiting for him to move the timber off the mill.
Jim Rogers
Percy
Up here, cutting WRC or Sitka, beams fetch more than the side lumber. There are way more logs that can make a 1x6 than a 6x12. Tractors and skid steers are your friend with this type of cut.....obviously
Quote from: homesteader1972 on March 10, 2015, 10:39:53 PM
Thanks again
You are making it sound like you do not have any experience sawing long beams. Hope you are not painting yourself into a corner. Maybe do some short trial runs before making a big commitment that might not go well for you and/or your customer.
But hope you get the job and it works out well for you.
Brad_bb
Also consider that for beams, you need to have them square withing 1/16th at worst and preferably better.  If used for anything better than posts, they need to be grade 1 or better.  Usually better because you need to take into account cosmetics for timberframe.  You might be able to use a lower grade for log cabin stacking logs on top of each other to make walls?  I an not informed as to log building.
No I don't think you'd charge less per sae.  You have different specs and handling considerations.  Think about this, if your band is not cutting parallel to the bed, the thickness of one side of your first board and last board might be off a bit(assuming flat sawn).  Not too big a deal on lumber.  it would make more of a difference on a timber though- causing it to be out of square.  In other words, make sure your band mill is cutting square to the bed and adjust if necessary before starting the job.
As Jim says, you probably need to figure an appropriate BF price if sawing your logs, and it's a choice for customers logs at their site, hourly or BF.  If they have to do all the handling, and they are not Johnny on the spot, maybe hourly would be better?
Bandmill Bandit
He cant buy those at the local lumber yard unless the lumber yard orders em from you or some one like you. and the lumber yard sure wont sell them cheap i can tell you that for sure.
In this country that kind lumber brings a premium. Real good stuff can go as high as 1500 per MBF or higher.
Non-standard sawing.  Charge an hourly rate. If they are good logs, he's got his site set up, and is on the ball moving logs, slabs and beams, he will gets a cheaper job. If you are held up waiting for him, or have a few reject logs in the pile, it's not you problem. End of they day you got your hourly agreed rate.
Now if you are selling beams, they may very well be worth more than boards. Need better logs, more equipment to handle them, limited supply etc.
But if you are just supplying machinery and labour, those factors don't really come into it. If he wants beams or pen turning blanks, you cut, and don't worry. Work out what you need to earn to make it a "good" day, and divide by ~7 hours, and that's your rate.
customsawyer
I charge the same bf rate for sawing the customers timbers. I use all my own equipment and they supply the logs.
www.thecustomsawyer.com
Peter Drouin
I don't get in a game with the customer  where  he says you only have 4 or 5 cut to make a beam. Can't I get a better price. :D :D :D :D :D :D :D
NO!!!!
Good luck
red
If they were short in length may be but anything over 12ft it's all about handling and Time
Chuck White
I would charge by the board foot.
Even though the bf adds up more quickly, the handling enters the picture.
If that don't work for you, go hourly!
red
I worked in an Auto Parts store and everyone wants a discount. I would say this is not Discount Auto go ask them all your Questions and follow their advice.
The best were people from the phone company wanting a discount I say Sure as soon as you can get me a discount on my phone bill.. . Find out what the customer does for a living
redbeard
If you compare BF prices at local lumber yard, You should see a increase in cost the bigger the lumber. Example a 8x8 will be alot higher BF cost than the standard 2x4 BF cost. Something to consider.
Ohio_Bill
I find one of the hardest things in a job like this is getting  the customer to understand  what logs he needs for the beams he wants. For a 6 by 12 it takes a very staight 14 inch log . Not sure about your area but around here most 20 ft poplar will have some sweep.
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
homesteader1972
Thanks for all the great comments and feedback! I have not told him anything on the price yet, he still has some homework of his own to do. I also told him i would need to come out and look at what he has got before I could give him a price. What all you have told me will help in matter much.
Thanks again!
Woodmizer LT40HD20G
Brucer
If I'm sawing my logs, I charge a lot more for beams than for lumber. Timbers require bigger (and often better) logs than plain lumber and they are harder to handle.
If I'm sawing the customers' logs, I charge the same amount per BF no matter what I cut. Sure, there are fewer passes of the saw to cut a beam, but it takes just as long to fetch the log, load and position it, and square up the cant as if you were making boards. The saw still had to cut through that (possibly dirty) outer shell. And you have to pay more attention to positioning the log just so.
Bruce    LT40HDG28 bandsaw
landscraper
Quote from: Brad_bb on March 10, 2015, 11:55:06 PM
That's pretty darn accurate.  I just finished a complete alignment on my mill and I used a steel rule and a straight edge for my measurements. It is sawing what I consider to be straight, parallel and angular lumber, but I don't know that I could produce consistent 1/16" or better diagonal accuracy on big timbers from end to end.
I agree that bigger beams and slabs should be no cheaper than dimensional lumber for the reasons of scarcity and added difficulty.  They should in many cases be more expensive IMO.  Even more so if you furnish the material.
Firewood is energy independence on a personal scale.
4x4American
landscraper
Quote from: 4x4American on March 14, 2015, 08:18:10 PM
Really?
If you're asking me, then, yeah, really.  I mean to say that if I cut a bunch of 20' 6"x12" like the OP was talking about that I'm certain that I could find a point somewhere along the length of one of the beams where if I sawed it in half at that point and checked diagonals that it could be out 1/16".  Where a knot was, or grain slope change, internal stress, or whatever.  I'm not saying the whole beam would be out of square, that's why I check and adjust alignment.  The post I was responding to was saying that if you were sawing beams that the spec was 1/16" or less out of square, which I thought was a pretty accurate requirement for the entire length of a beam and that it was likely for there to be spots along the beam that might not be perfectly square.  My opinion FWIW.
