?? Stacking drying wood?
Started by leroy in kansas, April 07, 2014, 08:45:25 PM
leroy in kansas
I was cruising the videos recently and came across a guy that was drying under clear plastic and putting a containment around the stack. Looked like he made a ring with 2x6 on edge and wedged a piece under the top to keep it tight.
Is there any merit in doing something like this? Will it help keep the boards straight ?
Will the clear plastic cover reach an even temp throughout the stack?
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
red oaks lumber
cover the top only. never block the sides.. air flow is critical :)
You have to have air flow to get the moisture out of the wood.
Maybe he's thinking of a solar kiln? But that has fans to move the air, and vents to let the moisture out.
Otherwise you have a combination sauna / mushroom farm....
If you are air drying, just cover the top to keep the rain and sun off, but let the breeze blow through the stack.
