four side planer
Started by Deerlope, May 05, 2014, 03:02:20 PM
Deerlope
 Hey guys where do I go to start looking for a four side planer that can also do T&G. I do not have any 3PH power so anything would either have to be small or can be run by an engine.
MS 230, MS 260, MS 361 Husky 576XP, Husky 390
woodman58
Logosol PH260 Single phase will work. Look at this page on the top right.
i LOVE THE SMELL OF SAW DUST IN THE MORNING.
Timberking 2200
Dewey
You can either Buy or build a Phase Convertor.... I am almost set to start planning with my 4 sider....( I need to build my shavings building.. )
I had a fellow build a convertor out of a 20 HP electric motor.... It will start 75 hp of 3 phase motors.... But.... I have'nt run any lumber through it yet ..
Larry
You might look for Smithway XL's.  A lot of them had 2 hp on the side heads, 5 hp for the top and bottom, and 1/2 hp for the feed.  Years ago they were a common machine used in thousands of door and window shops.  I just sold one to a neighbor sawmill a couple of months ago.
Birchwood Logging
Let me sell you my Newman 8b its a 4 sided planer its a little big though lol about 5 tons and has a 50hp 3 phase motor. Boy will it chew through the wood
John Deere 700H with winch, John Deere 550A with winch, Cat 232 Skid Steer,Cat 262c Skid Steer, Wood Mizer Lt 40 super HD, Ford F-700 and F-600 log trucks, Ford F-450 dump truck
DGK
I have the Logosol PH260 in the 3 phase version using a phase converter. The machine does a very good job and makes money.
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
scsmith42
A Baker M412 is another option to the logosol. You will need a high suction /volume dust collection system too. Between the Baker and the dust collection I have around 40hp of load when I run mine, which is a tad much for a phase converter. I run mine off of a 3-phase generator.
Tom's 3638D Baker band mill
ozarkgem
Quote from: Dewey on May 05, 2014, 06:16:41 PM
I always heard the phase converter motor had to be twice as big and the motor you are starting. a 20 hp converter will start a 10 hp motor. Have you started a 75 hp motor with yours? I would like to see some pics of that because I need to build one for my mill to do away with my gen set.
petefrom bearswamp
Ozarkgem, that is what I was told regarding creating the phantom leg.
Mine is a 20 running a 10 on my spiral head planer.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
ozarkgem
Quote from: petefrom bearswamp on May 10, 2014, 06:54:37 AM
I've looked at some factory ones and seems 30 hp 3 phase is all you can run on a 200 amp single phase system. But someone may have figured out a way. Lots of people smarter than me.
