Had a thought.
Started by customsawyer, January 16, 2022, 11:30:01 AM
customsawyer
I think there must be some bad weather over most of the U.S. based on the number of folks on the forum. :D :D
www.thecustomsawyer.com
Yup, PatD is recovering from a bit of oral surgery so I
Built her a nice flicker and
Built her a nice Snowman out on the deck.
caveman
Jake, I was thinking the same.  I was surprised to see you posting after 630 a.m.  We had a line of showers this morning and I've used that as an excuse to be lazy today.  I may haul off the slabs from yesterday's sawing and may even saw a few pecky cypress logs.  The weather won't be a legitimate excuse for me much longer, the sky is clearing up and it is still comfortable outside in shorts.
Caveman
Don P
I just made the first pass at clearing the high tunnel, got lazy and hopped in the truck to come up for lunch, I'll be firing up the dozer to rescue the truck presently  :D
Raider Bill
We had tornado warnings going off this morning.
Harsh way to wake with a touch of ginfluenza.
The First 70 years of childhood is always the hardest.
SawyerTed
Sitting inside a little cabin in Northern Virginia.  Snow and sleet since 11:00 am. Spending quality time with the Mrs. and on the Forum
  I have hardly hit a lick at a snake all day. Walked out and fed the horse, put a few bungy cords on the tire chains on he R rear tractor tire that had come off and I put back on a few days ago. I also went and got an extension cord and plugged in the heat wires to the gutters so they don't thaw, refreeze and break the gutters off.
  I had filled the woodbox and pulled another cart full next to the loading chute yesterday in case we got enough snow it was hard to get back up to the woodshed in the pasture.
Lynn,
  Sorry to see and hear about that blizzard in Mississippi. I assume the governor has declared a state of emergency and called out the national guard till the weather improves. :D I assume that is half your winter wood supply we see in the fireplace.
Bruno of NH
Very cold here below 0
Monday 6 to 12 of snow
Quote from: customsawyer on January 16, 2022, 11:30:01 AM
No, it just feels a lot nicer where it is warm and dry. ;D Hey, I did push snow for 2-1/2 hrs this morning @ -2F. I've never been cold working in cold. It would be down right miserable sitting on a loader truck with no heated cab, I would not want that position. :D
Peter Drouin
+4° here today and going up. Went out to clean around the new Hot Rod shop [scrap wood]
Had to take off my coat, starting to sweat.
I think it went up to 20°
Snow tomorrow Will be making 1x12x8 I think.
Don P good one. :D :D ;)
Customsawyer how do you like working at home all the time?
Andries
I'm on the forum and the weathers normal . . for Canada. Did I see photos of snow in Georgia? ! ! What IS the world comin' to ? 🥶
Lit the woodstove in my shop and by suppertime, I estimate to have burned the equivalent to MMs entire winter stockpile.😉
The only critter outside was this cutie:
I was making glue up panels of ash and had a GD playing in the sawdust under the jointer for most of the pm. Turns out that her favourite tool in the shop is a rolling floor jack. She's WonderWoman now because she could lift her grandpa up by herself!  😁 Sanding ash panels isn't as much fun as playing with a six year old.
Sanded panel.
Panel with finish.
LT40G25
Ford 545D loader
Stihl chainsaws
  I commend you for keeping your priorities straight. Time with a 6 y/o is priceless!
  I commented today about our 2 youngest GKs who are 3 & 5 and at the perfect age to enjoy everything. They had a light dusting of snow in Charlotte and they loved playing in it.
Quote from: WV Sawmiller on January 16, 2022, 05:41:50 PMSorry to see and hear about that blizzard in Mississippi.
It brutally cold here, 34° this morning with that dumping of snow and jeepers, it's 35° now with a forecast of 33° tonight !!!   :-X  Folks that is almost down to freezing.   :o :o
I have kept that flicker going in the insert all day long and probably used 8 sticks of firewood.  This has gotten beyond serious.  :-\
Nebraska
Hold on now, it's 33° down there.  It's 45° up here still,  almost all the snow melted. I doubt this happens very often.  You might have to scrape your windshield. I might not wear long johns  to work tomorrow, supposed  be warm again (relatively). HMMM go figure!
Old Greenhorn
Geez Lynn, are you guys gonna get thru this ok? That sounds dire and frightening. You have already used the entire amount of kindling I use in a week (because my fires never go out and I rarely use kindling). But everything is relative and I hope you folks can hang in there. There is light at the end of the tunnel, I'm sure. It was chilly here this morning (-4°) so I think I can empathize a bit. We are not having much difficulty but I do have to put on a jacket and even a hat when I go outside.
 I hope you folks get through it. Keep us updated.
moodnacreek
We are supposed to get lucky here. Light snow started an hour ago and should turn to rain 6am. That's fine with me. Finished the mud saw chip auger today for the new mill. 7 days a week since mid october and hope to be sawing next month. These cold cloudy days are the best for working, nobody comes around. When it snows it is the same amount of work and fuel as sawing but I can't ever sell the snow.
customsawyer
Quote from: Peter Drouin on January 16, 2022, 07:54:55 PM
It's not to bad. I enjoy the commute a lot more now that I don't have one. It can get difficult dealing with all of the customers when I was used to dealing with one. Sure don't burn as much fuel, but burn a lot more electricity.
Andries those boards are awesome.
It was 33° when I got up this morning and has now dropped to 32°.  Da fire is ah burning.  fire_smiley
I ain't sawing but I did do my 2021 year end Taxes yesterday.  I am trying to slow down but 2021 was still one of my better years income wise.
SawyerTed
To my northern friends, if you are missing your weather, it is drunk down here in my yard!  Y'all are welcome to come get it!
Yea, leave it be. We'll get it in the spring.
YellowHammer
Even the deer wanted to come inside to get warm yesterday.  Some of these are inside the fence in the backyard.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
K-Guy
Quote from: SawyerTed on January 17, 2022, 07:51:00 AMTo my northern friends, if you are missing your weather, it is drunk down here in my yard!  Y'all are welcome to come get it!
We thought you would like a sample of it, if you like it you can keep it. No money down and no payments!! smiley_jester
Nyle Service Dept.
- D. Adams
Walnut Beast
Quote from: Andries on January 16, 2022, 08:43:47 PM
Sanded panel.
Panel with finish.
Definitely some eye candy 👍
