Small twig growth on oaks
Started by kelLOGg, March 12, 2019, 09:14:50 AM
kelLOGg
I have several small oaks that have twigs growing low on the trunk. I have always thought that this means the tree is dying but before I cut them down (mostly for firewood but some sawlogs too) I want to ask those who know if the tree is soon to die. If you look closely the twigs will show up. I would hate to cut them if they are viable. Thanks.
Woodpecker52
Usually tree has started getting more sunlight on trunk. And for the Doomers :'(I do not think it has anything to do with global warming!
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Southside
It's called Epicormic branching and yes, usually it's as a result of new or more light getting to the trunk.
White Oak Meadows
kelLOGg
Allrrrright. I'm glad they are not nearing their end because there are too many to lose. (I don't know how I got into italics????)
Thanks.
titanoftrees
kelLOGg
Logger RK
I was told buy a Log buyer a few years ago,what I thought was red oak,was pin oak. Of coarse it paid less then red.
Ron Scott
Yes, epicormic branching which arises from opening a stand up to much to sunlight. They can also be caused by fire. The branches arise from dormant buds. The trees aren't dying, but veneer or log grade quality may be affected.
~Ron
TreeStandHunter
Epicormic growth can absolutely be a sign of the tree declining, in declining trees it is a last ditch effort to perform photosynthesis. If you recently opened the canopy and it's getting full sun now than yes that will cause it also, look at the rest of the tree (canopy) for other signs of it declining. If it looks healthy when leafed out than it's fine.
In the process of building my own mill.
Ron Wenrich
The problem with epicormic branching is that it puts a defect in the underlying lumber.  Sometimes you can saw through it, sometimes you don't.  In hardwoods, it can be a defect.  And that effects the value of the wood.  I've seen epicormic branching come from cutting a stand too hard and from insect defoliation.
White oak is also prone to what is called a cat face.  Its a bud cluster under the bark.  Same thing as epicormic buds, but it usually kicks white oak out from being veneer quality.  Sometimes these will have a tiny branch or a cluster of leaves break out.
barbender
Bur oak typically have a lot of those, in my area.
Walnut Beast
Quote from: Southside on March 12, 2019, 09:57:33 AM
How about black walnut ? Just getting sunlight or problems? This wild child leaner has all dead branches up high but the main one seems good. Maybe the other ones we're getting blocked a little and there was some trunk growth. I thought about cutting it down thinking it was dying but after looking at the top last night and reading here maybe but I guess all the little suckers are not good. I'll get a picture of the top
Rhodemont
The oaks and other trees that are along the sides of a newly cleared pasture (4 yrs) all have many new branches sprouting from the trunk.  Trees 50 feet back into the forest do not.  Amazing how the thick barked trunk getting direct sunlight is pushing them out.
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
