Author Topic: Shut down the OWB  (Read 883 times)
Offline gspren
Shut down the OWB
« on: April 08, 2019, 08:46:39 AM »
  It's to hit the 70s here the next few days so I shut her down. I may wait a week or two to clean it so I could restart but probably wont. I still plan to cut a few standing dead oaks before summer sets in but not on the 70 degree days.
Stihl 041, 044 & 261, JD 2355 4X4 w/fel, JD 620, Yamaha Kodiak 400 & trailer, Kubota 400 RTV,  P&M OWB, 75 acres to play.
Offline luap
  • Not as good as I once was
Re: Shut down the OWB
« Reply #1 on: May 06, 2019, 12:45:21 PM »
I shut down the owb today. Still only in the 40's but supposed to see 60 by the weekend. At this time of year the stove will go days before needing wood and makes lots of creosote.
Offline RHayes
« Reply #2 on: May 08, 2019, 08:34:09 PM »
Just flipped the water heater breaker back on so looks like I'm done for the season as well.
Offline petefrom bearswamp
« Reply #3 on: May 09, 2019, 06:13:54 AM »
I only shut down when going on vacation and for water changes.
In winter when gone i drain and vacuum out lines.
Burn Hemlock slabs all late spring summer and early fall to heat domestic water.
Kubota 900 RTV
Polaris 570 Sportsman ATV
241 acres of woodland
Offline hedgerow
« Reply #4 on: May 09, 2019, 09:17:03 AM »
I normally never shut the Garn down usually do the Maintenance between burn cycles as we heat our domestic water year around with it. But during the ninth  heating season it started to leak around the front air collar door area so I  drained Monday and we are back heating domestic and house with propane. I have had some shoulder surgery so I won't be able to get into the Garn and clean up the leak area and see if we can repair the leak and move on. Got a friend coming Saturday to do some clean up on it and get some pictures of the affected area and I have been making some calls of folks I know that are welders. I usually do my own welding. It going to have to be a small younger guy.
Offline woody_88
  • If it can be done, it can be re-done
« Reply #5 on: May 15, 2019, 10:40:57 AM »
Going to shut it down soon too, have to fix a sensor on my furnace first for propane.
This being my first season with an OWB, I am interested in hearing any and all techniques of clean up for the off season. I purchased a rust blocker emitter cup to stick in there (firebox) after scraping clean, what about covering the inside of the fire box with motor oil? (New or..)
Offline Roger2561
  • Love the outdoors
« Reply #6 on: May 17, 2019, 05:57:34 AM »
woody-88;  I only use new motor oil.  The reason for changing the engine oil is to remove the toxins that build up over time, why introduce the toxins and contamination to your OWB?  What OWB do you have?  Roger
Roger
Offline woody_88
« Reply #7 on: May 17, 2019, 06:56:23 AM »
That is solid thinking Roger, even the cheapest no-name oil would be better than used for this application. I have a Classic Edge 550, an early titanium series, stainless water AND fire box.
Do you cover the chimney stack, even though thereís a rain cap?
What do you have?
Looking forward to many years of burning!
Offline Rebarb
« Reply #8 on: May 19, 2019, 12:25:39 PM »
At the end of burn season I burn it hot for an extended period, not boil though......let it cool and scrape the inside, clean then dump fresh synthetic oil in the fire box and slosh it around, done.
Run the pumps every time I mow.
Offline woody_88
« Reply #9 on: May 20, 2019, 10:18:19 AM »
Good tip on running the pumps at an interval, when youíre already outside! I was going to ask the question next about running pumps thru summer or what. That answers it.
Shut down
Started by Bruno of NH on Sawmills and Milling
Last post May 25, 2017, 07:27:31 PM
by Crossroads
Bat shut down?
Started by timberlinetree on Forestry and Logging
Last post June 10, 2016, 12:47:11 AM
by gimpy
Shut it down
Started by dgdrls on Sawmills and Milling
Last post November 18, 2012, 09:04:21 PM
by Jim_Rogers
4/53 Emergency Shut Off ?
Started by Autocar on Forestry and Logging
Last post July 08, 2011, 03:08:56 PM
by Autocar
