Quality Axes
Started by Big Z, April 15, 2019, 01:21:00 PM
Walnut Beast
Let's see some more of your vintage and high quality axes large and small guys!!
Walnut Beast
Double Bit Felling Axe? Do you guys that have them like them or think they cut better for felling than a regular one?
DonW
Double bits are a lot of fun to swing, bucking, felling, limbing, splitting, juggling, all that +.
And these too
br>
Front to back, breitbeil, carpentry axe, carpentry axe, rafter hewing axe.
Hjartum yxa, nothing less than breitbeil/bandhacke combo.
Walnut Beast
Absolutely beautiful!
 My Great Granddad's Hewing Axe with some ERC timbers that he hewed.
 My Craftsman Handaxe that I use to split kindling.
My John Neeman Carpenter's Axe.
Walnut Beast
Thanks for sharing Magic! Those are beautiful!
Texas Ranger
Been with me 60 years or better.  Used lesser axes most of the time.
Walnut Beast
Nice collections everyone!  Some real eye candy!!  I'm getting jacked out of my mind thinking of putting some trees on the ground by hand and when I get done bore cutting some big Black Walnuts the spurs are getting cut by hand to drop them! Nothing wrong with creating more work and excitement 💪. I think I'm going to get a Gränsfors Bruk double bit axe. For serious felling the double bit seems to shine.
DonW
My skew on Gransfors is one of relativity and while I have some I've also gotten rid of them out of discontent when compaired to actual high quality. Probably for availability and ease of acquisition it's a reasonable way to go, certainly more so than what's there at the hardware, Council, or whatever. When you wanted a goo d one though this version posted would be like a Cadillac of double bitteds.
Walnut Beast
No candy boyz here!
DonW
Another kind of double bitted action.
RPF2509
Spot on Brad B with using a maul for splitting rounds.  I got mine 30 years ago for $5 at a yard sale.  Sharpen it up once a decade or so.  3-5 cords of oak every year since and its still going strong.  Replaced the wood handle every so often after a missed swing.  Tried a fiberglass/plastic handle once and never again when I missed and it shattered and almost took off my ear with the shrapnel.  I don't use an axe for kindling anymore after I sliced my left index finger with a newly sharpened axe.  The maul takes just a tap and the weight takes it through.  Axes are for felling or limbing and only if the chainsaw is not handy.  I tried a hydraulic splitter once and it was more work getting the round to the splitter and vice versa instead of just pecking away where the round lay.  I find that for the wood I split, its easiest very green or very dry.  Its that in-between time that is the hardest.
RPF2509
Double bit axes for felling work no better than a single bit.  The other edge is for when one side gets dull or to use on hard bits like limbing branches or when there is a chance of hitting the dirt.
firefighter ontheside
I got a nice solid brass axe for my 30th year at the FD.  Doesn't have a very sharp edge on it.  Nice hickory handle too.  It's adorning my wall now.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Walnut Beast
Quote from: RPF2509 on January 30, 2023, 06:59:32 PM
Couldn't disagree more on the felling part!!
Walnut Beast
Pretty sweet firefighter 👍
DonW
....  The other edge is for when one side gets dull or to use on hard bits like limbing branches or when there is a chance of hitting the dirt.
That about covers all the bases. :) In other words, for whatever chopping you'd like to use it for.
woodroe
Snow & Nealley's up this way.
Skidding firewood with a kubota L3300.
Walnut Beast
Got this bad boy on the way and I'm ready to put some big timber on the ground!
https://www.gransforsbruk.com/en/butik/products/double-bit-axes-en/
Will look forward to the video of you putting big timber on the ground with that axe. What diameter size are you calling "big" timber?   8)
Nice axe.
DonW
I guess you've got the felling version coming and not the throwing in the link you've posted.
Walnut Beast
Beenthere I'm not up on all the video action yet but will do some pictures. Have a few 60" walnut to get the party started to graduate to some bigger.
Don I have the double bit with the 35" handle on the way. Not the short one.
Walnut Beast
Double bit action! I'm looking forward to mine but there is no way I could run with these boyz. 120- 150 feet up cutting the trunk at 14- 20 inches Wow!
Walnut Beast
Double bit motivation! Both guys with them. The one on top has his also. For you suspender boys! How about his!
Tom King
Imagine being inside that notch while you're chopping.
