Author Topic: My new shirt  (Read 7889 times)
Offline samandothers
Re: My new shirt
« Reply #160 on: June 05, 2021, 08:48:59 PM »
You are focused on the right things!  I was just trying to temp you.  smiley_devil
Offline tule peak timber
  • The Wizard of Crap
    • tule peak timber
Re: My new shirt
« Reply #161 on: June 05, 2021, 11:06:08 PM »
Well,,,, The temptation is certainly there . I ordered a fishing drone  in prep for the next visit and spent some phone time with a couple of contacts today on fish counts starting up the rivers on Kodiak. I'm there at least in spirit...... :D
Re: My new shirt
« Reply #162 on: June 06, 2021, 07:55:45 AM »
A bit of day dreaming and preparing for future makes the work days a bit easier.
    • tule peak timber
Re: My new shirt
« Reply #163 on: June 18, 2021, 04:36:44 PM »
Some tables that passed inspection this morning. These are Claro walnut museum pieces still in process.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: My new shirt
« Reply #164 on: June 19, 2021, 06:44:53 AM »
Beautiful natural colors.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Online doc henderson
Re: My new shirt
« Reply #165 on: June 19, 2021, 07:03:06 AM »
I love your long "countertop room"  was that by design, or just luck of the draw?  what will these be setting atop?  single post with a base?  how thick are they?  Nice production, very classy and beautiful.
Offline Larry
    • Copas Sawmill
Re: My new shirt
« Reply #166 on: June 19, 2021, 11:16:03 AM »
Can't wait to see this one.  How thick are the pieces?  Did you cut them out with a pattern on a router or shaper?
    • tule peak timber
Re: My new shirt
« Reply #167 on: June 19, 2021, 11:16:29 AM »
The room itself is an insulated "wind tunnel" that we can loft , sand , and finish pieces with heated /filtered air. The 40 foot torsion box table is a great reference to keep things flat.
 The tops are blind spline construction using Baltic birch plywood. A couple of years ago I switched to this style of internal joinery because it is fast to machine and has very consistent results that never fail. You can even dial in the amount of clearance in the joint depending on what type of glue you are using. Very consistent!
The corners of these tables are a flared radius called out in the specs by the designers. I had to draw, then build one corner, then mirror image it to the opposite side to keep things perfectly even. You'll notice that in the template I did not put the 2 corners together until I had batch cut all of the table blanks exactly identical, then I put stretchers on the 2 corners and glued them in place for the master end template. This ensures that everything is perfectly balanced and symmetrical to the actual blank.
I started with rough 3" thick slabs from the kiln and it took 3 weeks to creep up on the final blanks at 1-1/4" thick. The original specs were for 2-1/4" and mid stream in my building the customer switched to 1-1/4.
This weekend I am doing spot filling and getting ready to bullnose all of the edges at one time. Then the tedious finishing process begins.
smiley
Red Shirt
Started by Magicman on General Board
Last post November 26, 2019, 12:18:28 PM
by Jeff
Red shirt day
Started by Raider Bill on General Board
Last post October 25, 2017, 06:28:21 PM
by slider
Tom's other Shirt
Started by Tom on General Board
Last post July 16, 2006, 08:30:50 PM
by ellmoe
Today Is Red Shirt Day
Started by thecfarm on General Board
Last post March 27, 2016, 09:37:03 PM
by Magicman
