Author Topic: Frick 27" Gang Edger Adjustment  (Read 361 times)
Offline 354maple
« on: May 04, 2021, 09:01:35 PM »
I am trying to help my next door neighbor with a question on a Frick 27" gang edger.
When he runs a 8 foot pine board through the edger the board is bowing by as much as 1/8 inch in the middle.  So if you lay the board on a flat surface on its edge there is a 1/8 inch gap in the middle of the board.
His question is this: is there some king of a adjustment he can make to the edger so the edge will run true for the entire 8 ft?
I appreciate any help you can give me since the edger is of no use to him if he can make a adjustment somewhere.
Offline dgdrls
  • Learning the Art of Milling Logs
Re: Frick 27" Gang Edger Adjustment
« Reply #1 on: May 04, 2021, 09:30:39 PM »
Welcome 354maple
Not sure what your asking,
Are the boards coming off the mill already bowed?
or are you saying when he runs a board through it comes out with a bow?
If the boards are bowed across their width the edger will not correct that
D
Offline 354maple
« Reply #2 on: May 04, 2021, 10:48:03 PM »
The 1" boards are straight and true coming off the mill they get bowed when they go through the edger
Offline moodnacreek
  • Sawin by the notches
« Reply #3 on: May 05, 2021, 07:53:48 AM »
Edgers are very fustrating when cutting curves. There are so many things that can cause this the question can not be answered . I could say; put in new feed rolls absolutely square with the mandrel and new teeth, and overhead guide light and guide the board by hand.  When I rebuilt mine it did this bad. The problem was the outfeed table had one dead roll a little off.
Offline 354maple
« Reply #4 on: May 05, 2021, 11:42:30 AM »
Yes I was afraid that a complete overhaul was going to be the solution. My neighbor is a mechanic and I thought if there was  an adjustment somewhere he would have found it.  Maybe feeding by hand will work.
I appreciate you taking the time to respond.
Sincerely
354maple
Offline moodnacreek
« Reply #5 on: May 05, 2021, 09:43:08 PM »
I was just using the statement as an example of a 'correct answer'. That edger may have just one or 2 little things wrong. The alignment of the rolls and the condition of the saw teeth first off. A stick with a wood screw makes a perfect gage to measure from the mandrel to the rolls. Anything the board touches must be considered. I spent a lot of time changing my outfeed table builds until I got it right. Many edgers just don't cut straight until the owner and the machine get tuned up. There are ways to make a fixed outfeed fence with a shifting fence to keep the board straight but this is last resort because trash gets caught in these things.
Offline 354maple
« Reply #6 on: May 09, 2021, 07:25:44 PM »
Thanks for giving me additional information to pass along to my neighbor.  As soon as I here him fire up his diesel I'll be over to see him with a printout containing your suggestions.
old gang edger question
Started by woody1 on Sawmills and Milling
Last post August 24, 2008, 08:42:25 PM
by WH_Conley
gang saw/ edger questions
Started by getoverit on Sawmills and Milling
Last post August 13, 2017, 01:50:21 PM
by longtime lurker
Edger adjustment qustion
Started by Mt406 on Sawmills and Milling
Last post March 14, 2018, 01:00:23 PM
by moodnacreek
Frick 2-27 edger
Started by moodnacreek on Sawmills and Milling
Last post June 17, 2021, 07:49:20 PM
by barbender
