Author Topic: 4 sided plane and tongue and groove machine  (Read 701 times)
Offline jimrr
« on: May 07, 2021, 12:53:05 PM »
I would like to find a rebuildable (can't afford new!) machine that planes boards.  Squirrel somebody on this forum had a ten ton 4 sided planer that looked like a good deal quite some time ago but basically I am asking what I would call such a machine?  Obviously I don't even know what I should be looking for or what it's called but my start begins on these forum pages.
   Thanks,  Jim
Offline metalspinner
Re: 4 sided plane and tongue and groove machine
« Reply #1 on: May 07, 2021, 02:02:24 PM »
Moulder. Weinig is one brand.
I just made a post in the Drying and Processing Board with a video.
Offline woodyone.john
« Reply #2 on: May 07, 2021, 04:01:50 PM »
Also known as a 4 Sider.
Saw millers are just carpenters with bigger bits of wood
Online Bigly
« Reply #3 on: May 07, 2021, 06:37:44 PM »
I am also moulder-curious and hope to add one to my operation in the nearish future.  What is the make of the one in the other thread & video?  It looks like a machine I could wrap my head around.  The newer models with all the bells and whistles are a bit intimidating.
Offline Don P
    • Calculator Index
« Reply #4 on: May 07, 2021, 06:43:03 PM »
...But are sure easier to set up and do a better job than the old ones.
The future is a foreign country, they will do things differently there - Simon Winchester
Online Bigly
« Reply #5 on: May 08, 2021, 06:06:45 AM »
That's good to know- what kind of moulder do you run DonP?
Offline curved-wood
« Reply #6 on: May 08, 2021, 07:26:24 AM »
I agree with Don, older one could be long to set up depending on the precision needed.  The worst situation is when I have to match a flooring profile , I could easily spend 2 hours on the set up. I have 2 moulders , one 4 heads and the other one a 5 heads, both old machines. They are long to adjust so it is not good for small runs. But once it is set up it flies!!
Offline Don P
    • Calculator Index
« Reply #7 on: May 08, 2021, 08:17:38 AM »
Alas, tablesaws and routers  :D. I've run an old push feed Berlin up to what was then a newfangled SCMI through feed machine. We went from multi hour setups to around 30 minutes for a complete pattern change. The newer machine was bottom head first with soft feed pressure, the long infeed table was then doing some face jointing and also had an adjustable fence and indexing knife to do some side jointing. So rather than forcing the stick flat and pushing it through the machine if fed it through the machine more lightly and had flattening/straightening operations going on at the same time. It has now been, goodness, almost 40 years since then, ours was machine #7 in the US at the time. As far as I know pretty much all machines work on that basic throughfeed concept now.
The relatively fast set up time meant i could do short runs pretty efficiently. We were in an area with a number of register houses and could usually pretty cost effectively reproduce moldings for those carpenters.
In the boat anchor pile here I have a 1928 Vonnegut 6x12 4 head machine that was state of the art in its day, rigid spindles that ran much more chatter free than competitors. It had been refitted with a "doubler" at some point that converted 60Hz 3 phase to 120Hz, fooling the motors into running at double speed, the first sort of variable frequency drive I guess, that alone weighs over a ton  :D.
Offline scsmith42
    • Whispering Pines Farm
« Reply #8 on: May 08, 2021, 06:41:32 PM »
Truer words have never been spoken!
My 6 head Wadkin produces beautiful material, but the setup time is a bear. If I had it to do over again Id spend the extra bucks to get a newer 5 head with digital setup.
Tom's 3638D Baker band mill
Offline Southside
    • White Oak Meadows
« Reply #9 on: May 08, 2021, 06:44:55 PM »
Spent 20 minutes today swapping profiles on my 4 head WM4000. I have a single surface planer in front of it that skip planes any high spots out so it effectively becomes a 5 head set up.
White Oak Meadows
Offline jimrr
« Reply #10 on: May 10, 2021, 10:56:17 AM »
Thanks folks,  I'm inpressed.  My very first post about sawmills and 9 replies and 400 views.  I'm intimidated!
   I'll look for your video Metalsider,  and Don P. your 1928 1 ton,  I'd be rebuilding it were it within 300 miles.  and SCsmith,  your machine truly does look .....wow,  way over my head.
   Now I can recognize the correct words for a 4 sider or moulder.   again, thanks and I am glad to of received a reply to a post here as there are generations of knowledge to gain.
         Jim,
Offline jimrr
« Reply #11 on: May 10, 2021, 11:13:03 AM »
metal sider,  I found your video on making ship lap, ............ I kinda think you folks are on a level quite a ways up there.  Maybe I can get a photo on here of my sawmill but it's a totally refurbished LT40 HD super i got basically for scrap value but with a history of metalworking and engineer It works like a new one i suppose.   (without the LED's!)  i think a 4 sider would be about the limit of what business in the region would warrant but who knows?  sure appreciate this resource.
Tongue & groove fit
Started by David Freed on Drying and Processing
Last post May 19, 2008, 09:54:06 PM
by BBTom
Tongue and groove
Started by dean herring on General Woodworking
Last post May 15, 2018, 06:53:24 AM
by curved-wood
Tongue and Groove
Started by Brian_Weekley on Timber Framing/Log construction
Last post October 23, 2018, 02:09:42 PM
by RAYGYVER
Tongue and groove ceiling
Started by HandymanTodd on General Woodworking
Last post May 20, 2014, 09:53:56 PM
by Bill R
