Author Topic: How do I pull engine hours  (Read 215 times)
Offline Husky546
« on: June 07, 2021, 11:32:54 PM »
Looking at upgrading from my dinosaur of a Mack to a more modern Ford. I recently found a 95 l8000 with a 5.9 for sale for what seems like a reasonable price. Odometer shows about 50k on the truck but the owner claims it dosent actually have an hour gauge. I have never owned anything this new but maybe new trucks donít have a gauge anymore.
Regardless the odometer only tells part of the story and Iím hesitant to buy anything I donít know actual running hours on.
I have heard these trucks should still store hour data on the computer but I have no idea how to retrieve it. Can anyone lend some advice
Offline Southside
    • White Oak Meadows
Re: How do I pull engine hours
« Reply #1 on: June 07, 2021, 11:49:02 PM »
A '95 5.9 is a mechanical engine - no computer.
White Oak Meadows
Offline mike_belben
  • Pulp Friction
« Reply #2 on: June 08, 2021, 12:44:21 AM »
Contact blackstone labs for an oil analysis kit.   Oil will tell you more than any meter.
6bt is my favorite engine, but it is small for an L8000 unless its just a light duty hauler or service truck or something.  If it was an original industrial engine and not a dodge swap youre only gonna have a 165hp pump on there ill reckon.  Pull the CPL off the timing cover data plate and the part numbers off the pump, tag will start with P7100 or P3000 or maybe even "A" and thatll tell you what they are.
Proverbs 19:11
Offline barbender
« Reply #3 on: June 08, 2021, 01:36:50 AM »
I used to run a Ford F7000 that had a 5.9 industrial that was 195hp iirc. It had good power in that, but an 8000 (is it single or tandem axle) is pushing it. Not nearly enough engine for a tandem.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #4 on: June 09, 2021, 09:43:46 PM »
Factory Build with the 5.9??
Tell us about that Old Mack :)
D
what are high engine hours on machines
Started by barniescamp on Forestry and Logging
Last post June 15, 2016, 05:44:46 PM
by coxy
ANTIQUE ENGINE AND OLD TRACTOR PARTS + HIT MISS ENGINE - $1000 (NORTH JERSEY)
Started by Dangerous_Dan on For Sale
Last post February 17, 2010, 12:13:36 PM
by Dangerous_Dan
Too many hours in a day
Started by Darrel on General Board
Last post June 11, 2017, 05:15:57 PM
by Darrel
How many hours are too many
Started by jph on General Board
Last post September 11, 2005, 10:07:43 PM
by farmerdoug
