Author Topic: Nyle Kiln sterilization  (Read 340 times)
Offline Jstier
« on: June 16, 2021, 11:12:32 AM »
Just finishing my first run, got my lumber down to 7-8%. I'm starting the sterilization and curious how long should it take my Kiln to reach 140-150.
Its a Nyle L53, my chamber is 10ft-8ft and 7ft tall. I just cranked it up last night from 120- 140 and this morning it was sitting at 132 degrees. Curious how long should I keep it in that range once I hit it. Slabs are 2in thick.
Sorry new to this and open to suggestions, tried to include much info as possible.
Offline K-Guy
    • http://www.nyle.com/
Re: Nyle Kiln sterilization
« Reply #1 on: June 16, 2021, 12:12:51 PM »
It's hard to say. It depends on how much insulation, how tight your building is and local weather conditions.
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Offline Southside
    • White Oak Meadows
« Reply #2 on: June 16, 2021, 12:55:25 PM »
Also depends on how many BF of lumber are in there and the number of chickens you sacraficed.
Offline samandothers
« Reply #3 on: June 16, 2021, 01:10:41 PM »
Always about the chickens.
Offline K-Guy
« Reply #4 on: June 16, 2021, 02:00:15 PM »
That's because chickens are cheap like Southside!!  :D
Offline Jstier
« Reply #5 on: June 16, 2021, 03:06:06 PM »
Well I've only sacrificed one chicken so guess I need another :) Also Stan after I talked to you and switched the baffling temp went back up to 135 and gaining. So if I keep the kiln at 130 I read 10-12 hours to sterilize? If I keep it at 140 can I do 5 hours? Are these numbers correct, or should I get the temps higher?
Offline K-Guy
« Reply #6 on: June 16, 2021, 04:00:58 PM »
I recommend 140F for 24 hours after you reach 140 for 4/4 wood. That guarantees that the internal temperature hits 133 for 45 minutes and that is the USDA requirement as far as I know.
Offline Southside
    • White Oak Meadows
« Reply #7 on: June 16, 2021, 04:05:20 PM »
I don't know the upper temp limit on a L53, but whatever it is I would get the chamber to that and hold it there for 24 hours.  I sterilize at 160 for 24 hours.  The last thing you want is a cold spot in the stack of lumber that was just cool enough for some Powder Post Beetles to enter your, or your customers, home.
Offline Jstier
« Reply #8 on: June 16, 2021, 06:00:46 PM »
Hey Stan left support a message. Unit is still shutting down right at about 135 degrees. It acts like its going to start up again but it just cycles like its trying to kick in. The fans wont even run. All baffles are out. Not sure what would be causing it now. Compressor switch is off. Does it matter what the wet bulb sensor is set at for this part of the process.
Offline K-Guy
« Reply #9 on: June 17, 2021, 08:10:29 AM »
@Jstier
If the compressor switch is off, then the wb setting doesn't matter as the compressor is off. I'll call you later to discuss the fans issue.
Offline Jstier
« Reply #10 on: June 17, 2021, 11:14:16 AM »
Yes the compressor switch is off.
Thanks I have the kiln off right now because it seemed like it was struggling. I took the side off if we need to check out anything on it.
Offline K-Guy
« Reply #11 on: June 17, 2021, 01:54:56 PM »
@Jstier can you call me at 800-777-6953 ext 212?
Kiln Sterilization Certification
Started by YellowHammer on Drying and Processing
Last post May 01, 2020, 11:15:49 PM
by GeneWengert-WoodDoc
Sterilization Experiment in Solar Kiln
Started by btulloh on Drying and Processing
Last post June 06, 2018, 04:33:55 PM
by btulloh
Small kiln for project-sized sterilization: ideas?
Started by tpcolson on Drying and Processing
Last post January 19, 2021, 12:08:27 AM
by samandothers
Nyle L50 Kiln?
Started by WoodChucker on Sawmills and Milling
Last post September 04, 2003, 05:21:34 AM
by GarryW
