Hourglass cuts on sawmill
Started by JHand080, July 22, 2022, 10:31:19 PM
JHand080
Hey guys,
I am having a major issue with milling lately. Just to get this out of the way, I have a Norwood HD-36 V2. Bunks are straight and level as well as main track. Blade is sharp, and all adjustments are as perfect as I can humanly get them.
Every single cut I make on logs now, my boards are very very warped. My sawmill has never done this before. I can cut into the log, starting slow, and by the time I am about 2' into the log, you can already see the board start to curl up and then when I get halfway through the log it changes and drops and starts curling up the other side. When I finish my cut the board literally rocks in the cant like a see saw.
I have never been more frustrated at a piece of equipment my entire life. I have been as patient as I can, adjusted every thing I possibly know how to, and still nothing works.
So my question is this, could it be the logs? They are differing species that have been down for about 2 years. ANY HELP IS APPRECIATED.
In Jesus,
Jon
WV Sawmiller
  No answer just more questions:
What size logs? (Length and diameter)
What species of logs?
How is your support for the mill? (Any chance something is sagging as you make your cut?)
Was the mill cutting okay in the past?
If so, has anything changed recently?
Blade type/profile?
 I am not familiar with your mill so what size engine are you using?
Could be the logs.
Any way to get a fresh log on the mill?
Even a short one, 4 feet, would tell you, because you said 2 feet it started to cut bad.
I always enter the log at full speed too.
rusticretreater
I assume we are talking about a manual sawmill.  How wide a log are we talking about here?   Have you cut this type of wood before?
I would remove the blade and spin the wheels manually, looking for problems in the bearings, tires, drive belts, etc.  Then check your guide bearings for smooth operation.  If you have to, take them off and spin them.
After reinstalling the blade, I would spin the wheels manually while watching the blade to make sure it tracks straight, true and is properly positioned on the tire.  Make sure there is no free play in the sliding guide arm.
Watch the blade as it enters the wood.  Does it immediately cut into the wood or flex in any direction?  When the blade starts to wander, is it still properly supported by the sliding guide arm?
It could also simply be a bad blade.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
barbender
If the board is rising up after the cut, that is tension in the log and nothing to do with the mill at all. There's mot much you can do with those.
barbender
Please follow up and let us know what kind of wood it is.
JHand080
Thank you all so much for all of the input. I'll try to answer as many as I can in this one reply.
I have milled 6-7 logs ranging from 14"-28" all with the same results. The logs have also been differing species of wood from poplar to cherry and maple. The mill has never done this before, so I'm guessing it's either something has went bad with my mill or it's just how the logs have laid out in the sun for 2 years. I have no idea though.
Quote from: JHand080 on July 22, 2022, 10:31:19 PMEvery single cut I make on logs now, my boards are very very warped............... I can cut into the log, starting slow, and by the time I am about 2' into the log, you can already see the board start to curl up and then when I get halfway through the log it changes and drops and starts curling up the other side. When I finish my cut the board literally rocks in the cant like a see saw.
What you are describing is not the sawmill but tension within the log being released as you saw.
JHand080
Quote from: Magicman on July 23, 2022, 06:36:03 AM
That gives me peace of mind. Would that happen with every log though?
Stephen1
I would expect it in poplar ( we have cottonwood/popple) cherry moves and cracks, so does rock maple. A lot heat from the sun could make those move like they are. AS BB says, any chance of finding a fresh log?
Maybe start by taking all 4 sides off the long and then keep turning after every cut.. That might release the tension as you work your way around the 4 sides.
Oddman
The knowledge of tension and how to counteract it is one of the most important skills to have as a sawyer. Knowing the mill is one thing but will only get you so far, you must know how to read a log as well.
Lots of knowledge on the forum here that should get you well on your way.
It would be interesting to see some pictures of your logs and perhaps some of the thick&thin lumber?
Oddman
Depending on the logs and how your sawing them, it could happen with each one.
In general - smaller logs, less turning and thicker cuts will cause the stress/tension to be more evident.
Larger logs, turning more often, taking thinner cuts, will relieve the internal stresses more evenly. A pith that is off center is a sign of uneven internal stress and will need to be sawn correctly to account for that. Different species of trees can have more/less stress or even build it in a different way internally.
Old Greenhorn
Jon, first, welcome to the forum, Second, filling in some of your profile info will be helpful, especially where you are. This tells us, among other things what the conditions are likely to be in your area.
 Third, take and post some photos of your general set up, log pile, and this wood that is making you crazy. There are some sharp folks here and there may be some clues in those photos you have overlooked. These are technical issues that require careful and thorough examination. Details are important.
 How long have you been milling?
 From your description it sounds like the mill is cutting flat, but the boards are curling? Is that correct? Have you put a straight edge on top of the cant after a cut to see how it looks?
 The devil is in the details with things like this. Examine the details and post some photos so we can help. Right now we are all guessing and throwing out common issues we've all had in the past.
ladylake
 If your sawing 2 x 4 you might have to leave the cant  a little oversized  and then skim cut down to 4".   Steve
Quote from: JHand080 on July 23, 2022, 07:09:55 AMWould that happen with every log though?
Proper log setup and face opening will determine how many logs will respond when you saw them.
Mark the logs with a lumber crayon and take note of any sweep that the logs may have.  Now observe what happened when you sawed.  Orient the logs differently and observe what happens.
When sawing framing lumber I normally "saw through" from either the hump or horn face.
Asking questions is good but you will ultimately have to be your own teacher.   :P
YellowHammer
Imagine a piece of cheese or bologna, and no matter how you cut it with a knife, all the pieces would lie on top of each other, even if the cut was a zig zag pattern.  That is how a a neutral or unstressed log or cant would behave.  So no matter how your mill is aligned or cutting, the boards of an unstressed log or cant would just lay there, even if your band is cutting like a drunk monkey.
If the piece of wood curls up like peeling a carrot, then, as the folks say, that is log stress, and is just part of sawing.  There are lots of techniques to minimize the stress, and sometimes they work, sometimes they don't, but it's not your mill, its your logs.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Walnut Beast
WV Sawmiller
   Cheese, bolonga? These topics always get back to food one way or another don't they? :D
ladylake
 No matter how good you are at setting up logs some will have stress that shows up when sawing.  Steve
YellowHammer
I din't even mention the wet noodle or fish fillet analogy. :D :D
YellowHammerisms:
OlJarhead
This really is "sawmilling 101".
I can't tell you the times I've learned things whether asking or not!
For those who do the answering (I try to but I'm usually beat out by MM and others who know far more than me anyway lol) THANK YOU!  I was recently told by a member who is fast approaching the Million Board Foot mark that he learned a ton because I was asking.  I loved hearing that!  Many don't ask but read what others ask and for that, I thank all of those who do the answering!
Way back in 2010 MM and the gang were here to help me get started when I bought a CSM...and they were here when I got the LT10 and when I put a trailer under it and when I got the LT40...and passed 100Mbf and are still here today.  You are all the best!  Hands down!
doc henderson
YH, I love your dog, but can we see a video of the drunk monkey you mention, sawing on your WM sawmill?   ;) :)
JHand080
Y'all are hilarious 😂. Thank you for all the input. It really eases my mind and helps. Gonna start trying some more fresher logs and see what happens
SawyerTed
Is this what's happening?  It is stress in the log.
Sometimes when you see the slab moving, the cant will lift off the bed on one end or both ends or the cant will raise up in the middle.
customsawyer
Doc I have gotten some lumber that has come in here from that monkeys cousin. He was apparently the one that taught YH's how to drink. It was stacked on stickers by some of their other kin folk that was hitting the bottle pretty good too.
www.thecustomsawyer.com
