band sawmill manual lift assembly
Started by Tacrites, February 07, 2021, 02:28:44 PM
Tacrites
Hey guys I'm new here and also inexperienced so I'd appreciate a little help. I have had a Harbor freight Band sawmill for about 5 years. It has served me well. I realize it's the cheapest mill I could get and frankly I simply did't know what I was doing when I purchased a mill. I hope to upgrade but for now I need this mill back operational in a bad way. The lift consists of a threaded steel rod and a threaded brass piece. The threads in the brass has stripped. HF says 10 to 12 weeks to replace. I know this mill is also built under at least a couple other names. Surely there is someone that has parts on hand. Does anyone have any suggestions to help me find who I might check with? Does anyone have a suggestion on getting this brass piece made? I am presently fabricating a lift with an electric winch although not sure how well its going to work once completed. Any pointers are appreciated thank
 you.
DennisK
Get an ACME nut, Turn it to the outer dimensions. McMaster Carr?
Nebraska
Got a local machine shop?? they could probably make one up.
JoshNZ
Any engineering shop should be able to make one no problem. Or a friend with a lathe etc
Tacrites
Thank you. Its pretty much a farming community, got to be a shop around somewhere.
Sawmillmike1
These are not acme threads... They are trapezoid threads.  You can order an exact repl from McMaster carr.
charles mann
@Tacrites
https://www.roton.com/family/acme-right-screws-and-nuts-7059286/
Go to the main page for the above link and search for the proper thread, tpi and size, or like others mcmaster carr
Temple, Tx
Brad_bb
Are you sure it's brass, or is it bronze(stronger)?
ladylake
 You need to oil the thread and nut every day. I just use 80 90 gear oil out of a 1 quart squirt bottle.  Steve
JoshNZ
I'm sure he's got it sorted as it's been nearly 2 years lol
ladylake
Quote from: JoshNZ on December 06, 2022, 12:50:45 PM
That thread and nut looks really dry to me. Also there's  no way it should way it should be shot on a light mill.  I have over 8000 hours on mine with a heavy diesel.  Steve
