Author Topic: Upgrading my mill  (Read 3173 times)
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
Upgrading my mill
« on: October 21, 2005, 08:51:16 AM »
Well, I just sold my Norwood LM 2000 and bought a used WM LT30. I loved the LM2000 and believe it is a great saw that is very well built. I have not a bad word to say about it. My wife has been worried that I would ruin my back doing everything manualy. She's even jocked about getting me one of those things you wear around your neck in case you get hurt, you can send a signal out or something.
The LT30 is not the full hydraulic I was hoping for, but it offers enough features that will reduce some of the heavy manual stuff I've been doing till I can afford full hydraulics.
My question is: Has anyone ever installed a hitch coupler on the tail end of the WM for manuvering the saw? I have a spot that my saw sits in when I'm not doing mobile. The problem is, I can't drive in, I have to back in. If I do that with the WM, it's facing the wrong way. Any thoughts?
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline DanG
Re: Upgrading my mill
« Reply #1 on: October 21, 2005, 09:13:14 AM »
Congrats on the upgrade, Stumpy! 8) 8)  That's bound to make your life easier.
I've seen dollies used to move boats around by hand. It is just a pair of wheels with a trailer hitch mounted above, and a handle to pull it with.  That might work for ya. ;)
Offline stumpy
« Reply #2 on: October 21, 2005, 09:27:54 AM »
Thanks DanG, But there is a slight incline that I'd have to pull it up. I don't know how heavy the saw is to pull around much less up a slight grade. Any thoughts would be apprecieated
Offline DanG
« Reply #3 on: October 21, 2005, 09:32:05 AM »
Could ya tow it in there with a riding mower?
Offline woodhick
  • I hope it don't clear off cloudy and come a dry drizzle!
« Reply #4 on: October 21, 2005, 09:46:01 AM »
Put a hitch on the front of your truck.  Works great for moving small hard to back machines like log splitters or air compressors. Sounds like it would work here. Also there is no reason  you couldnt put a hitch on the other end of the mizer to move around.
Woodmizer LT40 Super 42hp Kubota, and more heavy iron woodworking equipment than I have room for.
Offline stumpy
« Reply #5 on: October 21, 2005, 09:49:38 AM »
As a matter of fact, I do have a hitch on the front. It works great for manuvering trailers in tight spaces. I also put my winch there when I need it. That's how I would park the saw if I can put a coupler on the other end of the saw. One concern is, If I put the coupler on, will I be able to lift or push down the back end of the saw to hook it up to the truck hitch.
Offline OneWithWood
  • I am happy!
« Reply #6 on: October 21, 2005, 10:14:02 AM »
You can use the weight of the engine and mast to lighten one end by moving the assembly to the other end.  Try experimenting with this and you should find a point of equalibrium that will make the coupling or uncoupling fairly easy.
One With Wood
Kirk_Allen
  • Guest
« Reply #7 on: October 21, 2005, 10:43:37 AM »
If you move the head to find that balance I suggest using 2 sets of vice grips clamped onto the rail to stop the head from moving in either direction once you find that spot.
Lets just say experience has shown the importance of securing the head so do inadvertantly do a wheely  ;D
Offline Rockn H
  • long way to go
« Reply #8 on: October 21, 2005, 11:08:03 AM »
Kirk, those heads move pretty good when they are headin' down hill don't they. ::) :D
Offline ronwood
  • Enjoy Making Sawdust !!
« Reply #9 on: October 21, 2005, 12:28:10 PM »
stumpy,
I only move it my mill around when I put the end in the travel position that Woodmizer recommends. The weight at the hitch is around 100 lbs. based on discussions with Woodmizer.  Sure don't want to get the head back to far. Done that one time with out the back outrigger up and I had the hitch high up in the air.
 :D :D
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Offline stumpy
« Reply #10 on: October 21, 2005, 12:52:57 PM »
Thanks for all the responses so far. Good comments and alot to consider. The big question is: any ideas on the feasability of welding a hitch coupler to the rear of the mill?
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #11 on: October 21, 2005, 12:58:25 PM »
  Mount it on a piece of Tubing that will fit inside the main frame tube. One quick pin and it is on or off, so ya won't bang yer shins on it.
Offline logman
    • M&K Timber Works
« Reply #12 on: October 21, 2005, 01:27:45 PM »
Don't know about the hitch welding but I just installed the log loader
on my LT30 and sure do love it.  It's not that loading logs with the ramps
was that hard when the log rolled up straignt, it was when they would
get cockeyed coming up that was a pain.
LT40HD, 12' ext, 5105 JD tractor, Genie GTH5519 telehandler
M&K Timber Works
Offline stumpy
« Reply #13 on: October 21, 2005, 02:07:50 PM »
I made a loader for my Lumbermate. I found that the log rolled up great when you put a chain or cablle attached 6' wide down under the log then hooked the loader cable to that. It made the log roll up straight instead of having just one cable in the middle of the log.
Offline moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #14 on: October 21, 2005, 04:12:05 PM »
Stumpy,
 Did your LM2000 have the trailer package? Use the same idea for your rear hitch. That way you can take it off when not in use.
Just a thought.
mh
Higher than my expectations
Offline Furby
  • Blurb....
« Reply #15 on: October 22, 2005, 12:21:58 AM »
Offline stumpy
« Reply #16 on: October 22, 2005, 01:19:38 AM »
Thanks Furby. Do you move the carraige back a little to balance it when using the rear hitch
Offline Furby
  • Blurb....
« Reply #17 on: October 22, 2005, 01:23:04 PM »
It's not mine, just one I seen.
I figure ya might have to move the carrige, but your hitch sould be good for 500# or more if you have a bigger one.
I would just drop it on and move it into place, it's not like you are towing it down the road a ways..... right ???
Just use a high lift jack and you are good to go!
Thinking about upgrading my mill
Started by Collima on Sawmills and Milling
Last post September 16, 2011, 06:39:07 AM
by bandmiller2
Thinking of upgrading to a lil newer mill
Started by paul case on Sawmills and Milling
Last post January 21, 2016, 10:41:35 AM
by pineywoods
Upgrading to a Hydraulic Mill - any downside?
Started by Engineer on Sawmills and Milling
Last post February 07, 2004, 04:55:09 PM
by ScottAR
Upgrading a TF Garage
Started by Shovel Man on Timber Framing/Log construction
Last post December 29, 2008, 09:34:51 PM
by Michigan Mike
