Author Topic: Firewood splitter  (Read 4791 times)
Offline TeaW
Firewood splitter
« on: May 27, 2006, 10:01:57 PM »
It dosen't matter how big or good a firewood processor you have there are always some stick's that don't work well in it. The big ,knotty,crooked and punky.
I used to to use this IH spreader for it's intended purpose but the beaters broke, I sold the cows and added the splitter to it.
The floor of a manure spreader is not all that strong, you have to add some support,I took out the wood floor and added a steele crate that lets some of the fines and snow slip through. Now I can drop blocks into it with no damage. I added a sprocket to the pto to drive a gear pump and a oil reservoir, with the tractor running about 1500rpm the pump put up about 15gal/min.
It will handel any size of block I have for it.The apron advance was mechanical , but it was noisey so I added a hydraulic motor to advance the next block to me if i can't reach it.
It is as easy to pile it as you take I  it from the splitter as to throw it. So I have boxes made that will hold 1/3 of a cord, I can leave it in the box or dump it in the pile
I like the wood that goes through the processor best (faster) but if it wont I can still make use of it.Since these pictures I have changed a few things . I put on a Honda motor with a hydraulic pump and a new loader tractor.
Teaw
TeaW
Offline Sprucegum
Re: Firewood splitter
« Reply #1 on: May 27, 2006, 10:13:47 PM »
That's a real neat setup you got there  8)  8)
Offline Frank_Pender
« Reply #2 on: May 27, 2006, 10:16:00 PM »
coooooool! 8)
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #3 on: May 28, 2006, 12:46:27 AM »
That's a right slick outfit there...
Scott
[Magicman]
Offline Gary_C
  • Sunrise on the Prairie
« Reply #4 on: May 28, 2006, 01:10:13 AM »
Nice setup.  8)
Can you tell us more about that box? How big and what is it made of?
Offline TeaW
« Reply #5 on: May 28, 2006, 07:05:25 AM »
Nice setup.  8)
The box where the wood is piled is 4 feet high 4 feet wide and 32 inches deep, it is 4inches of the ground to let the fork slide under. They are made of 1x1 square tubeing with 1inch wood on the floor and a couple of pieces on the sides. Short chains are welded to the sides of the box and grab hooks on the loader you hook up if you want to dump. I have 25 of these when they are full I dump in the piles.
TeaW
Offline SwampDonkey
  • Large Tooth
« Reply #6 on: May 28, 2006, 10:38:06 AM »
Well that pretty much eliminates all my firewood. :D :D :D Just kidding. ;)
No amount of belief makes something a fact. James Randi
Offline SwampDonkey
  • Large Tooth
« Reply #7 on: May 28, 2006, 10:41:53 AM »
I got all my firewood this week, all stacked and sun drying. It was cut in winter and split from treelength before delivery. I purchased 7.5 cords, I had 1.5 cord outside and I have about 3/4 cord in the basement from last winter.  All set for another season. ;D
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #8 on: May 28, 2006, 12:09:09 PM »
 8) setup!!
Offline Coon
« Reply #9 on: May 30, 2006, 01:03:53 AM »
That is a nice looking setup you have there.  I really like what I see there.  I though would change one thing.  I would add a small engine driven hydraulic pump to run the whole works, that way you would be able to pull it with a 1 tonne truck if needed.  Something like that could be rented out by the day and show real good returns.  I would be able to rent that system out here for atleast $150/day here.
Brad.
Offline TeaW
« Reply #10 on: May 30, 2006, 07:06:38 AM »
Thanks Brad, I added a 9 hp Honda to this outfitt a few weeks ago and it works like a charm and frees up the tractorfor other work.
TeaW
Offline Coon
« Reply #11 on: May 31, 2006, 12:34:44 AM »
Great minds think alike. 8) 8) 8).
Brad.
Offline sawguy21
« Reply #12 on: May 31, 2006, 12:46:28 AM »
That reminds me of the manure spreader New Holland built for the amish. The pto was driven by a Wisconsin because they would not use tractors. Liked the shiny implements though.
Offline SwampDonkey
  • Large Tooth
« Reply #13 on: May 31, 2006, 04:13:14 AM »
My uncle has a horse drawn manure spreader. It's sitting on the edge of the field with a sheet of steel over the top of it. It required two good sized horses to haul it and he mostly borrowed a neighbor's tractor to haul it.
Offline Sawyerfortyish
  • Bigger they are the more mess they make
« Reply #14 on: May 31, 2006, 01:01:19 PM »
There's a guy near me that loves those ground drive manure spreaders. He loads it with his loader on the tractor then hookes it to his pickup drives to where ever the field is in some cases a couple miles puts the spreader in gear empties it and is back in half the time it would take a tractor to make the trip. Since he's only got one tractor he doesn't have to keep unhooking and hooking up to it.
firewood splitter
Started by weisyboy on Sawmills and Milling
Last post June 29, 2013, 09:27:23 PM
by hackberry jake
splitfire firewood splitter
Started by spencerhenry on For Sale
Last post July 02, 2010, 08:15:15 AM
by Piston
Long firewood splitter
Started by Gadgetman on Firewood and Wood Heating
Last post April 08, 2016, 10:51:02 AM
by DeerMeadowFarm
The Lockdown Firewood Splitter
Started by billhook on Firewood and Wood Heating
Last post September 06, 2020, 05:39:42 PM
by billhook
