Author Topic: Field stone chimney wall thickness  (Read 863 times)
Offline BigJim2185
« on: July 25, 2014, 02:54:11 PM »
I'm trying to figure out some chimney dimensions.  Is 6" wall thickness about right for a field stone chimney?
-Thomas 8020 w/10' extension
-New Holland TC45D w/ fel and farmi jl501
Offline sprucebunny
  • Gender: Female
Re: Field stone chimney wall thickness
« Reply #1 on: July 25, 2014, 04:55:24 PM »
Are you talking about the thickness/size of the rocks that you will put on the flue squares ???
Offline talldog
« Reply #2 on: July 26, 2014, 09:06:35 AM »
6 inches on the outside of the flue is about right. I had a chimney fire in mine once years ago. I went up in the attic and felt to see if it was hot. It was not
Offline Holmes
  • 1840 house
« Reply #3 on: July 26, 2014, 10:09:34 AM »
Generally a flue is encased in 4x8x16" cement blocks then the stone veneer is added to it. an 8x8 with a 18x18 beside it would take up 4"+18"+4"+8"+4" [38"] wide and 4"+18"+4" [26"]deep  add another flue, the width of the flue plus 4".  6" for stone on each side is ok. Chimneys get big fast
Think like a farmer.
Offline BigJim2185
« Reply #4 on: July 26, 2014, 10:21:35 AM »
Thanks guys.  Blocks + ~6" for stone seems to be the consensus, for a 10" total wall thickness.  Thanks for the help.
Making a stone wall, How to split stone???
Started by Piston on General Board
Last post July 13, 2010, 05:44:24 AM
by Ianab
Ss chimney liner to double wall insulated
Started by muddog77 on Firewood and Wood Heating
Last post September 20, 2020, 01:04:20 PM
by jmur1
Natural Field Stone for new construction fireplace???
Started by Piston on Firewood and Wood Heating
Last post August 17, 2011, 04:58:28 PM
by JohnG28
Stone wall replacement
Started by Deek18 on The Wisconsin Barn Preservation Program
Last post December 10, 2019, 08:45:27 PM
by nativewolf
