Diesel kubota lost power??
Started by shinnlinger, June 25, 2011, 09:11:48 PM
shinnlinger
Hi,
Topped up with fuel and threw the brush hog on this eve.  Mowed for about an hour when it suddenly lost power and stalled.  I was able to restart and limp it home putting it in low range to climb a hill, but definitely lacking.  Seems to idle fine and no smoke or funny sounds.
It acts like I have a gelled fuel filter in the winter and that is the first thing I will swap out, but what else should I look at?
Thanks.
Dave
Shinnlinger
Coon
Sounds like either fuel filter is clogged or you may have a blockage in the line somewhere.  Is it hesitating  or bucking at all?
scsmith42
Check all aspects of fuel delivery to the injector pump.  I had a JD 550B dozer that had similar problems a number of years back; turns out that someone had dropped a rag into the fuel tank and it would occasionally float over next to the fuel pickup and block it.  Took me a few weeks to figure that one out...
Tom's 3638D Baker band mill
shinnlinger
Well CS you called it.  Put in a new filter and the tractor ran great for 5 minutes while I burnt the ATF I had put in the fuel bowl and then died out.  I noticed the fuel bowl slowly refilling though so I ended up taking the tank out and dumping the fuel thru a t-shirt screen and a little piece of foil that seals anti gel bottles came out.
Runs good now!
Dave
Shinnlinger
Coon
Uhuh, you found the culprit, eh?  Bet you'll be more careful from now on.   ;D  I actually had that happen to me with an old snowmobile that you had to premix your fuel and 2 cycle oil.  The spout from the jerrycan never had a screen to stop the foil.  The machine would run great for about 5 minutes than just starve for fuel and stall out.  Took a good while to figure out.  I had to get a lil anal with myself and making DanG sure I remove the foil carefully and completely from any kind of bottle before attempting to use. A little pair of needlenose pliers and small flat screwdriver take care of that.  ;)
scsmith42
Quote from: shinnlinger on June 29, 2011, 09:56:20 PM
Runs good now!
Dave
Dave, glad that I could help out!
Scott
