help identify the tree
Started by coyotencuttin, July 12, 2009, 07:39:01 PM
SPIKER
second set of pics tells me maple as well most defiantly not hickory from this latitude.
this is a pignut hickory it shows the traditional diamond shaped raised bark.
standard shag bark hickory
king nut hickory
unfortunately I do not have any pics in the gallery of any red/silver/sugar maples.  My best guess is red maple as silver usually has more furled bark, like mentioned some maples will twist/corkscrew as the grain grows red is worse for this and also worse for splitting, usually silver maple will pop and fall apart with little effort.
I'm looking for help all the shrinks have given up on me :o
OneWithWood
After looking more closely at the pics I am moving away from hickory and closer to red maple.
Jeff has seen a few more logs than I so I suspect he has it right.
One With Wood
bull
I hit the Maple button !!!!   white wood thru to the heart.....
LeeB
Burn some. Your nose knows.
I just saw this thread, and it was maplish to me from the start.  I lean maplish.  Like Dodgy says, the end grain tells the tale.
coyotencuttin
sorry i haven't updated anything lately. been busy cutting my little personal log yard. i tried to burn a little piece sunday night and i think it stunk. wouldn't want to eat anything from that. kinda smelled like citronella or punk. i don't think its very heavy to lift.a couple pieces pulled the limb/spike out of the wood.it would split and sometimes it would split hard but it would not split clean, it would tear more than i would say it split. thanks for all the help.  harold
Woodmizer LT 40 Hydraulic.
stumpy
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Good going Coyote!  You've made a positive ID.  It's a nothickory! ;D 8) 8)
