Munters dehumidifier
Started by black, December 19, 2010, 12:58:54 PM
black
I have no experience but want to build a dehumidifying kiln.
Bought a used Munters ML690 dehumidifier and would appreciate any comments on the unit.
Here is some specs:
www.munters.com
Munters Model ML690
Width (A)
715 mm
Depth (B)
590 mm
Height (C)
1410 mm
Diam. (D)
200 mm
Diam. (E)
125 mm
Weight
143 kg
Technical Specification
Process air
Rated airflow (m³/h) 690
Available static pressure (Pa) 300
Reactivation air
Rated airflow (m³/h) 254
Total power,
voltage and current (amps/phase)
Total power(kW) 7,82
220V 3-50Hz (A) 22,0
220V 3-60Hz (A) 22,5
230V 3-50Hz (A) 21,6
230V 3-60Hz (A) 21,7
380V 3-50Hz (A) 12,7
380V 3-60Hz (A) 13,0
400V 3-50Hz (A) 12,4
415V 3-50Hz (A) 12,2
440V 3-60Hz (A) 11,3
460V 3-60Hz (A) 11,0
480V 3-60Hz (A) 10,8
500V 3-50Hz (A) 10,0
Miscellaneous data
Operating temperature (ºC) -20/+40
Max noise level unducted (dBA) 74
Air filter standard G3
IEC protective class (unit) IP33
IEC protective class (electrical panel) IP54
Dehumidification
Capacity
Approximate capacity in kg/h at
different inlet process air relative
humidity, % RH.
Dehumidification capacity, kg/h 7,0
Process Air Temperature, °C
Options
• Hours run counter (monitors the
number of hours the system is
operational)
• Blocked filter alarm
• Rotor stopped alarm
• Humidity control system with alarm
and display
Refer to the RH98 product data
sheet
• Air cooled condenser
Refer to the ML690L product data
sheet
• Stainless steel sheet metal casing
DH
