Mill revamp and upgrades
Started by Happycamper, March 31, 2013, 07:52:05 PM
Happycamper
It's been a busy time getting the mill operating well but we are there now I am happy to report.
                                        Jim
   Takes two fingers to move the mill head up or down from very bottom to very top, 1/2 turn of the crank handle = 1". This is one incredible improvement. The sprockets and chain are ones I replaced years ago on my planer. Winch made in china.
Wether you think you can or you can't you're right
drobertson
Everything looks great! nice shed too!
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
I can see that you are a thinking man  ;D.
MEMountainMan
Real nice, I did some of the same mods to mine
LT15 30 feet cap., John Deere 850 tractor with a loader bucket and backhoe, John Deere 1010 dozer. some husky saws, a 5ft Logrite cant hook, a 3ft mill special, and a 30" hookaroon. A shop full of tools and 108 acres of trees to make things out of.  Done building homes for others now it's my turn
scully
realy like what I see nice job !
I bleed orange  .
mikeb1079
jim those look like some great mods.  well done!  thanks for sharing  ;D
homebuilt 16hp mill
justallan1
Ga Mtn Man
Nice job on the mods, especially on that hand crank. smiley_clapping
So, no fix from WM?
All good ideas.Anything to make sawing easier.
Happycamper
Ga Mt Man,
  No, no fix from wm. Jacob Money said quote (We have thousands of these little mills out there, and this is really the first time we've had any negative feedback on this feature, hence the lack of a perfect solution.)
dboyt
The mill shed, log deck and sawdust catcher would work for any mill.  Thanks for posting.  Do those rollers on the log stops come out so that you have a flat stop for the last cuts?
Happycamper
deboyt
The mill comes with two sets of log stops one set longer than the other set. I use the rollers for large logs only.
                                   Jim
Chuck White
Nice mods you've done there Jim.  smiley_thumbsup
YellowHammer
Very useful improvements.  Good job 8)
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
redbeard
Nice job on the modifications with your ingenuity you will have your mill all tricked out. Your set up looks really good!
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
rambo
Great tricks for the water line.
Sixacresand
I like what you have done, HappyCamper.  Great pictures.
Happycamper
Thank You Fellas,
  For your kind remarks about the mill. I remember reading when I first joined the forum that the mill will give you many sleepless nights. Now I know what they were talking about. I woke up many a time working out the next improvement that I wanted to make but now it was all worth while. The little mill does all I expected it to do and is easy to work with and pleasure to use.
                                       Jim
frye
  wired this gas shutoff valve to my electric clutch on my Timberking 1600 so that it turns on and off with the blade clutch.
Seaman
Awesome mods. I know about nothing for ban saws, when you get a minute, come down south and show me some mods for my Lucas setup! ;)
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
rimshot
 Nobody can dare argue that the LT10 is not one of the best entry level mills on the market but Jim has managed to give his mill a personal touch that even Wood Mizer can't repeat.  Hey Jim, you forgot the cup holder.  And you got this all done in a heart beat.
Thanks for the boost to the rest of us.
rimshot
busy copying a genius
LT 10 with a 10 h.p. and a converted boat trailer to provide mobility for a once permanent mill.
Happycamper
Rimshot,
  Many thanks for the kind words. Necessity bring the mother of invention helps. I have stickered a stack 4 ft. wide, 8 ft. 6 inches long and 7ft. high after sawing many logs. I'm still using the band that came with the mill. The box of 15 blades await their turn. Remember (Necessity being the mother of invention.) I take my little thermos of coffee with me to the mill.
                                  Jim
rimshot
Hey Jim,
could you tell us the dimensions of the mill shed.  It looks to be about 14 long nd maybe 10' wide?  Tht is  nice looker
rimshot
Happycamper
Bingo, you win the prize measurements as you guessed.
