Cantilevered Racks For Air Drying
Started by Pepe_Silvia, June 18, 2020, 07:16:39 PM
Pepe_Silvia
Since I'm running out of space in the horizontal direction, I need to start moving in the upward direction.
Looking to build or have built some cantilevered racks for storing my lumber as it dries.  Is there a rule of thumb for spacing between the arms of the racks - the span that the wood will be resting on?
Woodmizer LT15Wide GO, John Deere 318D Skid Steer
farmfromkansas
Think Tom the Sawyer posted some pics of racks with roof on top.
I did a search on here and found some posts on this subject. That will keep you busy for a while.  ;D
firefighter ontheside
I bought some pallet racking with the intention of putting them up and then putting a roof on them.  Then I discovered that Tom the Sawyer had already done the same thing.  I haven't put mine up yet.  I have put some up under my covered deck and have a couple layers of drying under there.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
longtime lurker
I just keep going vertical with pack on pack.
If you want to put a "roof" of roofing iron on top for outside storage you just keep putting the fresh pack on the bottom - saves playing around with the iron and top weights each time
Keep your sticker spacings consistent and it will give very flat lumber... the best weight for a pack of timber is always another pack of timber IMHO
There's a guideline says that total stack height when doing this should not exceed 4 times the width of the packs.
(One of my favourite photos of this place... straight, laying flat, everything consistent... almost looks like we know what we're doing and stuff)
I think I see one out of place on the right hand stack, second pile in, about half way up. :D
Now that looks mighty nice. And than some!!!
