Looking for opinions on swingblade mills
Started by plantman, March 10, 2017, 08:51:24 PM
plantman
I was looking that Peterson, Lucas, D&L Timber technologies, and Turbosaw. I was wondering it anyone  has had experience with any of these mills and what they thought.
bandmiller2
Welcome Plantguy, I don't own a swingblade but if I was going to buy one I would give the D&L a serious look. They all work good and are a well thought out machines. In my mind the only thing you give up with a swinger is ease of milling wide boards. I like the D&L design because everything is in the carriage meaning height adjustment. You could buy the carriage and make as long a bed as you want. It would also be easy to make a power feed. Just one old guys opinion. Frank C.
Don P
I've been playing on a friends Lucas recently. Yesterday I bombed in with a load of beams and planed them. The beauty of planing on one of these is that it is jointing the timbers dead straight where my planer simply makes parallel sides and follows any bow in the timber... that is huge. Instead of square rule joinery or scribing to fit, it just became simple mill rule layout. Plus I planed some 12" timbers, which aren't going through my 6" deep machine. When I got out of the way the next thing going on was the slabbing bar to make some large ash tabletops, it has about a 5' wide capacity. We're looking at the sanding head as well. I can't say what options the other mills have but I do like that machine.
dgdrls
Welcome,
I run a Lucas  8/27 on the side, Great mill, excels with large logs but will saw them all with little to no log lifting, is very mobile and its
easier to access lone logs or tight spots, stores easily.
It saws consistent lumber and blade sharpening is a 5 minute affair with the supplied sharpener.
A slabber bar is available for wider cuts if you want,
Always best to test drive before you purchase if you can
What are you looking to saw??
D
plantman
The D&L mill looks a little sturdier because it rides on a track resting on the ground as opposed to one suspended in the air. However, I can imagine that it wouldn't be good if I were trying to transport off road and set it up on uneven ground which I don't plan on doing. It appears that mills like the lucas are spiked into the ground like pitching a circus tent which means they wouldn't be appropriate for paved surfaces. And it appears like they would wobble quite a bit. Perhaps you could give me your take on this and whether it causes them to be constantly out of adjustment.
Mt406
I have a D&L 10/20 if you would like to give me a call I would give you my opinion.
I will be away form the place this morning I should be back around 2.
406-660-1940
Scott
scsmith42
Quote from: plantman on March 10, 2017, 08:51:24 PM
I've owned a Peterson WPF for over ten years.  The first question is what species, diameters and lengths of logs are you planning to mill, and what type of lumber do you want to make?
Different mills are better suited for different tasks.  We have a hydraulic band mill, dedicated slabber and a swing blade mill, and each has it's one strengths and weaknesses.
Tom's 3638D Baker band mill
longtime lurker
What scsmith42 said!
Every sawmill is a series of compromises, and even looking at just  swingmills the different manufacturers have got inherent strengths and weaknesses that make some better then others in different logs or cutting different product mixes.
Grandedog
Howdy,
   I know you were asking for opinions. We sell Peterson Mills so a grain of salt might be in order but, on the other hand I've got over 22 years experience with the swing blade evolution. The concept hasn't changed but, the machines have. Probably one of the biggest things everybody can agree on no matter if it's a band, or swing mill, is the materials used in the manufacturing. Let's face it, most portable mills live a rough life outdoors. At best, usually just the power-head gets covered. It's really no fun having to put WD on everything even if it's a short time between uses. Stainless steel, and aluminum are the are the best options. The features, and upgradable options are probably the next most important. Most people have engine brand, and performance preferences along with manual to automatic option choices. The versatility of the swing blade mills have changed over the years with the advent of siding, slabbing, planning, and sanding capabilities. If you're going to be making large timbers, the double cut feature without having to pick up and turn the power head around is a big advantage. One slabbing feature that I really like is where the bar and chain are adjusted separately., This allows you to adjust the tension on the bar only to where it is perfectly straight, and then put the chain on and adjust it separately. Now for the grain of salt part, there's only one brand with all of these options, features, and advantages. The icing on the cake is that from now on the mills will be assembled in the US with as many components as we can source here. We will be testing, and adjusting every machine so, right out of the box performance can be expected.
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
ButchC
I have shopped 1-2 man mills of various types  for years and decided long ago that a swinger best met my needs but I have to be honest and say that the tariff held me back from purchasing. I am just sawing my own logs for my own use. 90% for repaIrs and new builds around the farm and 10% for my woodworking hobby.  I bought a Junior Peterson from LCS and it has met or exceeded all expectations.  I can saw by myself with minimal handling of both logs and finished lumber or when help is available I simply reverse my cutting sequence and finished lumber is on the other side of the saw for handling.  One point vertical adjustment saves may steps at the end of the day and that means board feet sawn. Ease of double cutting is importat when you only own one mill like me.
Had a couple small issues and LCS took care if them Pronto.
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
Many chainsaws, axes, hatchets,mauls,
Antique tractors and engines, machine shop,wife, dog,,,,,that's about it.
TKehl
What size logs are you after?  Support equipment?
A big plus for the Lucas/Peterson/Turbo group is they are quick and easy to take to the log.  Which is great for the oversize logs that I look for (too big for most commercial mills or band mills).  I like that with my Lucas, I can carry individual components into someone's backyard and mill there.  Tree cutters charge quite a bit more when there is no truck access.  30" plus diameter, it's easier to move the mill than the log, and I have some OK support equipment.
On smaller logs, that's no longer an advantage, but also not a strike against them.
qbilder
I have been thinking of getting one for a while now, too. I have a band mill and love it, but it gets cumbersome with certain jobs. I quarter saw hard maple into one inch thick boards, dry them, then resaw into 1"x1"x30" turning squares. A swing blade would allow me to cut accurate & consistent 1"x1" right off the log, which would save a lot of time for me both in drying speed and extra steps. I just haven't been able to justify the cost. I don't even need a big one, just something to cut 1"sq. from 15"-20" diameter maple logs.
God bless our troops
longtime lurker
Actually you'd do better with a cabinetmakers sliding table saw or a straight line rip... Cut random 1" on your bandmill then rip them out. Doing inch by inch on a swingmill would drive you insane
ButchC
Just a goofy old guy with a new hobby here but trying to wrap my mind  around the need to quarter saw  when the end need is 1x1 and going in a lathe? Also a  swingmill is going to have a very large pile of dust beside it after and entire log is reduced to 1x1
Morbark chipper
Case W11B
NZJake
Actually, sawing 1"X1" stickers  is pretty quick on one of our swingsaws. The Model 6 could run a narrower kerf (around 3.8-4mm kerf).
We quite often drive forward (using the power feed, climb sawing) then back (standard cuts) up to 4 boards at a time, then saw them horizontally all at once revealing a handful ready to stack.
You get pealings that resemble straw not dust like a bandsaw.
Wife says I woke up one morning half asleep uttering thin kerf and high production, I think I need a hobby other than milling?
ButchC
Thanks for that Jake, I have been sawing stickers just as you mentioned, 4-5 vertical cuts then one horizontal and viola! a handful of stickers.  I usually do this when just starting out on a log and use  what would mostly end up in the top  waste slab anyway. I have also made them  when sawing my way past tension figuring the stickers were worth more than crescent shaped lumber?
Morbark chipper
Case W11B
bandmiller2
Swing, band and circular they all cut good lumber each has a nitch. Solution get one of each and have the sawmill trinity. If you cut trees for hire a swinger is worthwhile for big yard trees, no heavy equipment digging up the lawn, stuff you can haul, take it back, to the yard for the band or circular. A swing mill is much cheaper than the truck and loader that will handle huge butt logs. I have a band and circular now and you can bet if I scooped a deal on a swinger I'd grab it. Swingers can be compactly tucked away in a shed. Frank C.
WIwoodworker
I've owned a Peterson for several years and love it. It's a 1993 9" WPF model I bought used and still runs strong. I bought the mill for flexibility and ease of transport. It handles anything I throw at it but at the end onthe day it boils down to what you think you'll be sawing.
Peterson 9" WPF
qbilder
Quote from: ButchC on March 17, 2017, 04:14:02 AM
Quarter sawing the lumber all but eliminates drying stress, so the wood is much more stable in the end product. If I could cut them 1"sq before drying, it wouldn't matter how they were cut. But so long as I'm drying boards, quarter sawn dries with significantly less stress.
plantman
I am intrigued by the swing blade mill for a number of reasons. The first is that these mills typically can handle much larger logs than bandsaw mills. In my area I have a large supply of large logs free of charge from tree services who are too far away from the large woodmills to make transporting them a realistic option. Second, the swingblade mills don't require the logs to be turned like on a bandsaw mill which adds considerable cost to the operation. Third the swingblade mill can be set up around a large log eliminating the need to even lift the log off the ground until it is whittled down to a manageable size. Fourth. the rigid nature of a circular saw blade prevents it from wanting to deflect over or under grain patterns in the wood. Fifth, the circular saw blades are extremely easy and inexpensive to sharpen which could save approximately $100 per day in expense. And if you want an occasional slab they offer chainsaw blade slabbing attachments. Next, the swingblade mill can much more easily quartersaw wood with less waste than a bandsaw mill so there goes your argument that swingblade mills produce more waste because their blades are wider. And finally, wood produced on a swingblade mill doesn't require a second process of edging which saves a huge amount of time and expense.  I can't see any reason someone would want a bandsaw mill other than the fact that small bandsaw mills can be had for a few thousand dollars which satisfies the hobby mill market.
TKehl
As the happy owner of a swing mill, I can say bandsaws have a place.  I'd like to eventually add one to complement (not replace) my swinger.  They are much faster cutting live edge slabs and have better recovery from curved logs as long as it fits through the throat.  I think they can be faster on short and small stuff as well.  I also have plans to set the bandmill up as a resaw with some add ons.
longtime lurker
I'd suggest thats a perfect scenario for a swingmill or a twinsaw such as a Mahoe or Mobile Dimension. Much depends on the kind of volume you're looking to do in a day: theres a lot of difference in output range between the likes of say the little Turbosaw and a Peterson ASM. There are also portability issues - as with all mills the bigger it gets and the more it can produce in a day the less portable the mill is.
Would you be taking the mill to the logs or taking the logs to the mill?
Yeah well - thats what they say. I'd suggest I've got more real world tonnage through a swingmill then every one of the mill manufacturers involved combined and I turn the log 95% of the time when cutting because I obviously think its worth the trouble. But you don't have to, particularly with large logs in stable species.
Smaller logs turning the log can really push your recovery up and definately push the quality of your recovery up a long way. D&L do one thats trailer mounted on like a bandmil style deck with turners and clamping - I dont know the mill but it looks like a good thing to me. Problem is you come back to size limitations in the logs again. Turbosaw have also done a fixed deck for the gladiator model and most of the twinsaw manufacturers have a fixed or trailer mounted deck option as well.
Definate plus. Hard to beat a Lucas in that situation
oh they'll deflect alright. Maybe not often and it takes something ridiculously hard to make it happen but it can happen. On the bright side you kinda know that a bandmill would have probably broken before it got that far but seeing a circular saw rise over a knot and jamb is both weirdly fascinating and a major PITA. Sometimes you just got to slow the feed rate down.
Another definate plus for circles is blade maintenance for sure. I'd suggest if you logs are sourced from tree service comapnies then circles are the way to go. For forest grown logs where theres not much chance of nails etc etc its still the way to go in most cases. Yah you loose a bit to kerf but if you take the blade savings per day and buy more logs you still win unless you're cutting stuff thats very valuable
yup. and beat the pants off them at backsawing too But a bandmill has advantages when you're chasing width.
yah but you've still got to resaw some for grade, fix up the occasional missawn board, recut them straight if they spring (not required if you roll the log during cutting which is why I do it). Aint no avoiding a certain amount of rehandling if you saw timber.
But the volume of timber you need to rehandle will be a lot less then a band. And its not the cost of an edger thats the issue - its the cost of the man to operate it.
I can. Theres a lot of them out there for a reason - its about horses for courses. When you're sitting all day in logs 18" round the hydraulic turning and clamping functions standard on a midrange bandmill are advantage bandmill
terrifictimbersllc
I use both band mill and swing mill in portable milling.   I use the band mill if it can do the job.
longtime lurker
i think one of the things with swingmills is there is a lot more variation in capacity then there is with an equivalent bandmill. Some are more portable, some more flexible, some have higher output.
I started with a Lewisaw. D&L's mills are all based on that design but the original Lewis with the parallelogram frame is the grandfather of them. It was very portable, as in hump it up a mountain and helilift the lumber out portable. Limited production and takes two people to operate one but yeah... you can hump it up a mountain on your back and cut a board when you get there. The little turbosaw with the chainsaw powerhead is probably the most portable option now for real remote work like that but I havent seen/used one to know: if I was young enough to do it all again I'd look real hard at that one.
The automatic mills like the Peterson ASM and the Turbosaw gladiator are way out there in production above the rest of the swingers. Both are relocatable rather then portable, but both make up for that with increased production once set up. The double cut feature they both have is a selling point - the ability to remove a couple boards from the back side of a log to help balance stresses while sawing can be a decided advantage in some timbers. And never underestimate the ability to cut a wide board with ease quickly and repetitively. At that production point though you also need to start to look at the twinsaws, and much will depend on what product your trying to get out as to which is the better mill. The swingers both offer more flexibility then the twinsaws, at the cost of lower throughput. You want to see a big log reduced to dimension lumber and sawdust in short order there aint much in the world will keep up with a Duncan beam saw or a 1212 Mighty Mite.
D&L I have not seen their mills except tube videos so cant speak for real world functionality and build integrity. But I do like the look of the trailer mounted D&L with the hydraulic log handling package. I think in the right logs it might take a bit of beating compared with anything else on the market - bandmill log handling without the band is how I look at it. If the logs can fit onto the trailer, and you can get the trailer to the log its hard to see how you could go wrong with it. Other then that the "ground rail" type design I personally think is limiting.
Lucas sit kind of in the middle. Portable enough to get them into a tight spot but not ultra lightweight portable for humping up hills. More production then the lightweights though. Less production then the bigger automatics but far more portable then them. Real good for big logs in backyards and the like. Accurate. And dammed near indestructible with regular servicing and wear part replacement as required. I've worked with an ATS Peterson which is the equivalent mill and far prefer the Lucas - personally I think they're about the best bang for your buck mill out there, but its all relative. (I own one but dont think Im biased - I'd probably not buy another based on where my business is at now)
Whole thing in this is that you as a purchaser have got to make choices around what features you need most. Theres a lot of nuanced difference in the offerings from the manufacturers and what features you need is determined by your log supply and product mix. The mill that you want to carry on your shoulders isnt the mill you want in an urban backyard isnt the mill you want breaking down oversize logs in a production sawmill operation isnt the mill you want to tackle a pile of 12" diameter logs with. And swingers cover the whole range of these scenarios.
plantman
I've only watched a few videos on the lucas so perhaps you could fill me in. That frame work they supply looks kind of flimsy and as though it would wobble around quite a bit. Am I wrong ? Is it required that they be set up on dirt where they can be staked in ? Or do they set up on pavement just the same ?
