Fabtek 4-Roller Tech Manuals & Info Needed
Started by bkane200, April 28, 2021, 11:18:40 AM
bkane200
I have an older JD 490E Fabtek conversion w/4-roller head.  I'm looking for Fabtek technical documentation for the head and electrical systems.  Specifically maintenance, set-up, operation, diagrams, basically anything.  I have contacted JPSkidmore and CrossTrac but all they could provide was the 'Series 2000 Computer Measurement System' manual.  Any help would be appreciated and well received.  Thank, B.Kane.
BargeMonkey
bkane200
Thanks, I'll check with him.  He might have some good info and advice.
BargeMonkey
c greenham
Hi I just bought a machine just like yours.  Any info would be great.
I'm having trouble with the delimbknife not closing.
Any help greatly appreciated.
Skeans1
Both knives? Might be a simple as flushing the circuit by turning the compensator relief above the max pressure then turning your port relief out well that function is being pressed after that adjust your relief then compensator.
bkane200
I've had trouble with the wiring in the joysticks for several head functions.  Luckily I've been able to clean and re-solder the wires.
