timber harvester rescue
Started by BM36HTD25, November 06, 2021, 05:44:31 PM
BM36HTD25
this is my first post and im an amature sawyer at best
Found this 36HTD25 in an old field.
Engine full of water.
Seized and rusted solid
after working on it of and on all summer finally got it running
Never knew what i was missing , Had a old home made hand crank push mill
Illl never go back
had alot of down time waiting on parts from Deutz
Deutz doesn't produce this engine anymore so parts were hard to find
FYI after i got them i found out Kohler Produces this exact engine
You folks have inspired me to do some upgrades - Setworks is done from scratch
(that should probably be another post)
Home Made Set Works - YouTube
Bob Marshall
Timber Harvester 36HTD25
Home Made Setworks
Hilltop366
tacks Y
Can't beat an old field find. Welcome, hope to see more pics of your mill. I have never seen a TH in person.
Iwawoodwork
Great find.. please fill in your profile so we know what area you are from, and age if inclined.
BM36HTD25
I Updated the profile
wish id gotten pics before i moved it
the setworks upgrade was worth the time and effort.
ill get some more pics of the mill this morning
Bob Marshall
Home Made Setworks
BM36HTD25
so here are some more pics
the guy i got this from was original owner
he had some custom log lift 3 arms instead of 2
he also had hose cable hanger installe don the control side (to make it easier for tender to remove lumber)
has dual tapers, hyd log turner, hyd cant dogs, hyd log lift
blew one hose that had been compromised (probably when i dragged it out of the field)
when i fired it up everthing worked :)
the blade covers where rotten so i made new ones from pcv sheet at hd they wont rot agian
Bob Marshall
Home Made Setworks
esteadle
That is a beautiful mill, and I am so glad you have spent the time to restore it. These machines were built properly and with long-lived parts choices and good solid design and engineering. I'm not surprised you were able to get this running again. I have the 30ht25 that i bought new in 2003, and I just disassembled the clamps on mine this weekend to fix up a little gear slipping problem with the far clamp. I'd buy another one if I could.
Best of luck,
eric
BM36HTD25
Still have a ways to go but its a start now i can play
Bob Marshall
Home Made Setworks
jrsloan1
PS Bob,  that's a nice looking mill!!   Very similar to my TH36ht25 but mine is gas. Have you had to do any adjustments on the carriage lift chains?  I had to replace my gear box and can't get it to stay in adjustments or get it quiet right. Looking for any hints, tricks I can get!!  Thanks.
Never trust nobody cause you can't fix stupid!!!
