SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: Milling ash?  (Read 974 times)
Offline Broncman
Milling ash?
« on: September 06, 2023, 06:28:00 AM »
I have several ash logs from 12" to 24" diameter.  About 6 trees. I want to cut some into mantle sized pieces.
How does ash behave when cut and dried? I know that sealing the ends helps with splitting  as the few I have done split when not sealed.
For beams and mantles, does the heart need to be boxed like other species or can a the heart be split on large pieces without much issues?
Was thinking of splitting the heart on some of the 18" diameter stuff and ending up with 2 pieces that have a live edge?
Thoughts or pointers?
Thanks in advance!
Offline Nebraska
  • Lurked for quite a while, learning !
Re: Milling ash?
« Reply #1 on: September 06, 2023, 07:00:40 AM »
Hardwood rules apply....For me it saws about the same as White Oak.
Online doc henderson
Re: Milling ash?
« Reply #2 on: September 06, 2023, 08:54:36 AM »
either box the pith or exclude it.  remember the 2/3 rds rule.  you could get a 12-inch square cant from an 18-inch log, assuming it is fairly strait and that you wanted straight boards.  you can get 3 big live edge slabs and take the center one and cut out the pith, getting two 4-inch-thick live edge on one side mantles, total 4 mantles 4 inches thick.  some will twist and split anyway and can be trued up after dry.
Offline Old Greenhorn
    • Woodsman Forest Products
Re: Milling ash?
« Reply #3 on: September 06, 2023, 09:00:50 AM »
What Doc says. I have done a bunch of ash slabs, it is/was everywhere here. Splitting the pith will give you nothing but headaches. Good milling rules apply. It will crack and split, that's what it does. It dries much faster than any of the oaks. If you wan 'flat and straight' think about the machining after drying.
Offline jpassardi
  • Converting Tree Carcasses 🌲
Re: Milling ash?
« Reply #4 on: September 06, 2023, 09:21:01 AM »
I agree, cut out the pith whenever possible.
Husky 372XP, 550XPG, 60, 50
Orlan EKO Wood Gasification Boiler -Slab Disposer
Re: Milling ash?
« Reply #5 on: September 06, 2023, 09:34:27 AM »
This is a bar I finished in April from a 3" Ash slab. I started with this:
...And ended up with this. 3+ years air drying in the shop. The pocket defect in the center caused some drying warpage. The tree was LTD (long time dead) before I felled it.
 Best of luck.
Offline Broncman
Re: Milling ash?
« Reply #6 on: September 06, 2023, 10:14:56 AM »
OG, that is very nice! I need to build me a giant drying shed...
Offline kelLOGg
Re: Milling ash?
« Reply #7 on: September 06, 2023, 03:33:42 PM »
And I have had good luck with live edge staying on even after kiln drying -on 1” thick slabs.
Online ladylake
Re: Milling ash?
« Reply #8 on: September 06, 2023, 05:22:12 PM »
  From ugly to pretty.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline cutterboy
  • Sometimes trees fall where they want to.
Re: Milling ash?
« Reply #9 on: September 07, 2023, 07:38:28 AM »
Tom, very very nice work on that bar. I think the rumor is true.
To underestimate old men and old machines is the folly of youth. Frank C.
Offline DanMc
  • Thankful for this forum!
Re: Milling ash?
« Reply #10 on: September 07, 2023, 11:59:26 AM »
I love to see people making something beautiful from what others would throw out.  Kind of like what the Lord does with people.
LT35HDG25
JD 4600, JD2210, JD332 tractors.
28 acres of trees, Still have all 10 fingers.
Jesus is Lord.
Offline Bostonstrong
Re: Milling ash?
« Reply #11 on: September 13, 2023, 08:14:52 AM »
Great information, here!  This is helpful, as I have about 12 ash trees coming down in the next months, so I will be milling a ton of it!  Thank you!
“Men invent new ideals because they dare not attempt old ideals. They look forward with enthusiasm, because they are afraid to look back.”
G.K. Chesterton
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Milling ash?
« Reply #12 on: September 13, 2023, 01:43:57 PM »
Bos,
   Warning! If those ash trees coming down are standing dead trees be very careful. Dead ash trees have a tendency to snap in the middle and the top will fall back on you if you are not watching closely. If you are just watching the lower trunk as the tree falls everything looks wonderful and normal but if you look up you'll find the top headed your way. Also big dead limbs like to fall down to see what you are doing when sawing.
Offline Resonator
  • Board Footage and Cord Woodage
Re: Milling ash?
« Reply #13 on: September 13, 2023, 02:44:22 PM »
To add to what others have said, having cut a bunch of black ash and some white ash, watch for areas of rot in the logs. I spray water on the cant as I'm cutting, to help spot discolored grain where it has gone bad on cut faces. Those areas are very prone to be brittle, and snap in half. Also ash grain cut running an angle can have long and jagged splinters, I wear gloves anytime I handle it.
Share via delicious Share via digg Share via facebook Share via linkedin Share via pinterest Share via reddit Share via stumble Share via tumblr Share via twitter Share via whatsapp
SPACE AVAILABLE
