SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: Cooks Cat Claw sharpener shaft broke  (Read 948 times)
Offline LeeB
« on: September 13, 2023, 06:59:11 PM »
Just ordered a new pillow block assembly for my sharpener. The shaft the rock goes on broke between the two bearings. Looks like it may have been broken for a while. Wonder how I was managing to get a decent sharpening done. You cant buy just the shaft.
Offline Gere Flewelling
  • Hobby Miller
Re: Cooks Cat Claw sharpener shat broke
« Reply #1 on: September 13, 2023, 08:16:33 PM »
That’s interesting. That is a pretty heavy duty shaft and bearing set up.  Did the stone experience some sort of trauma that could have caused the break? I know I accidentally let the head drop once while adjusting the degree angle and shattered the grind rock. I can’t imagine any other way that stress could be enough to cause the shaft to break. I hope you can get it repaired soon. Good luck!
Old 🚒 Fireman and Snow Cat Repairman (retired)
Matthew 6:3-4
Offline LeeB
« Reply #2 on: September 13, 2023, 11:57:34 PM »
I was pretty surprised myself. The rock was stuck on the shaft and I wacked it lightly to get it broke loose. Once I got it off I noticed the shaft didn't look like it was sitting right and the front bearing was out of the pillow block at an angle. I pulled the mounting bolts and only half of the assembly came out. It will be an easy fix. I suppose you can expect a few things to start going wrong considering it's age. I've had it 16 years ans it was used when I bought it. I have no idea how old it actually is. It has Suffolk Machinery stickers on it. My setter is also a Suffolk. Did maybe cooks buy the manufacturing rights from them?
Offline customsawyer
    • The Custom Sawyer
« Reply #3 on: September 14, 2023, 06:55:25 AM »
Lee you might want to edit the title. :D
I thought I knew what you were saying but had to come in here to make sure.
www.thecustomsawyer.com
Offline LeeB
Re: Cooks Cat Claw sharpener shaft broke
« Reply #4 on: September 14, 2023, 07:14:51 AM »
Done  :D :D :D ;D
Offline Chuck White
  • Sawing Mobile 2005-2022
« Reply #5 on: September 17, 2023, 08:33:35 AM »
@LeeB Just wondering if it is back up and running!
I've had my CatClaw 14 years now, and all I've ever done to it maintenance wise was grease it once in a while, and I replaced the drive belt once!
NOTE: I've found that if you have to do any maintenance regarding the belt or bearing, etc, the easiest way to get it realigned is to leave one of the pillow block bearing in place, and that will be your starting point!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, Retired Mobile Sawyer 2022, 2018 Silverado 4X4,  2019 Subaru Forester.  Cooks Cat Claw Sharpener and single-tooth setter
Offline LeeB
« Reply #6 on: September 17, 2023, 09:09:12 AM »
Not yet. Still waiting on parts.
Offline LeeB
« Reply #7 on: October 08, 2023, 11:48:46 PM »
Got the parts in a while back and only just today had a chance to tinker with it. The instructions that come with it are not much help. This is going to be fun.
Offline Chuck White
« Reply #8 on: October 09, 2023, 08:18:38 AM »
Good to hear you got the parts.
Remember what I mentioned in post #5 above, only remove one pillowblock bearing, it'll make belt alignment quicker!
~Chuck~
Offline LeeB
« Reply #9 on: October 09, 2023, 12:17:56 PM »
The shaft was broken and I ordered a whole assembly already put together. Both blocks had to come out.
Offline Chuck White
« Reply #10 on: October 10, 2023, 08:53:00 AM »
Ordering as a unit was a good choice, eliminates another part going awry!
~Chuck~
Offline LeeB
« Reply #11 on: October 10, 2023, 09:35:08 AM »
Doesn’t help with getting everything lined up again.
Offline LeeB
« Reply #12 on: October 10, 2023, 06:41:08 PM »
Got it lined up and back together. Got lucky and could see an imprint where the front bearing had set before. Worked it out from there. I had emailed Cooks for more directions but never heard back. I figured it out on my own. Their rock squaring/alignment tool would have helped but I made a tri-square work.
SPACE AVAILABLE
