Another one bites the dust (Battery)
Started by gimpy, June 20, 2015, 10:33:19 PM
gimpy
The only complaint I have about owning equipment is regularly I seem to have to replace an expensive battery on one rig or another. An Interstate battery on the mill has gone bad. I'm replacing all my equipment batteries one by one with Optimas. They never seem to fail. But boy are the hard on a wallet.
Gimpy old man
Lucky to have a great wife
John Deere 210LE tractor w/Gannon Box
Percy
I rarely get more that two years out of a battery on my 2003 LT70.........I buy the good ones with the highest amp/hr rating and still they swallow the big onion regular like. Cost of doing business I guess.....
Rougespear
Gee wizz that is an expensive maintenance cost every two years!  I'm assuming this is the battery for the hyd system yes?  Would almost be cheaper to switch over to a gas-powered hyd system instead of 12v.  I guess it's more noisy though...
Custom built Cook's-style hydraulic bandmill.
Chuck White
I got just over 6 years out of my last battery, just put a new one in this Spring.
When it gets to the point where you need to jump-start your mill when it hasn't been used in a week or so, everytime, you need a new battery.
POSTON WIDEHEAD
Never operate a mill with a weak battery.  :)
So I asked the parts guy last week why the battery was so high priced?  His answer was because of the lead.  I then told him that I brought my old battery with the same amount of lead in it, so he was not selling me lead, so why?  ..........Long silence.   :-\
Quote from: POSTONLT40HD on June 21, 2015, 12:04:32 PM
Very correct David.  Low voltage = high current and bad things could/will happen.
luvmexfood
Quote from: Magicman on June 21, 2015, 03:32:50 PM
Guess you confused the poor guy. ;D
Give me a new saw chain and I can find you a rock in a heartbeat.
bigred1951
I guess I'm lucky with batteries knock on wood. I've had my truck for almost 5 years that now has 250k on it and the same old battery in it from when I bought it. Never has failed to start except one time this past winter when it was 0 deg outside and had been sitting for a month. Had to jump it that one time and still going. Same deal with my dump truck. It sits for months at a time and so far always starts.
Ox
I think I remember the price of batteries skyrocketing when they shut down the last lead smelter in this country due to EPA regulations.  To my understanding it was the last place here that took lead ore and refined it into lead, not recycling lead.  I started hanging on to all my old batteries years ago for the lead in them and when the battery places were basically begging me to leave the core with them I figured I best keep all the lead I can find.  Someday it'll be worth something maybe.
Does anybody have any long term experience with the Optima batteries?  Like 7 years plus?  Have they been around that long yet?  How do they compare to lead acid batteries in the extreme cold when cranking diesels?
A battery is better being used every day like the one in your truck, if they sit unused their life is shortened. Probably batteries on a woodmizer should be a deep cycle as the hydraulics pull them down faster than the alternator can charge, and many times their not brought back to full charge. If your anywhere near an outlet a battery conditioner would keep the battery topped off when the mill is not used. Frank C.
YellowHammer
Quote from: Ox on June 21, 2015, 08:19:02 PM
I don't have any long term experience, but like many folks, I have a lot of equipment and a lot of batteries, one of which always sees to be weak, or on its last legs.  I've started replacing the dying lead acid batteries with the AGM batteries, and so far have been very happy.  I put one in my diesel mill some time ago, and it's as strong today as it was when it was new.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Ox
Yes, this is the reason I was asking.  I too seem to have dead or dying batteries all the while.  I've always gone with Interstate batteries for the last 10 years or so and I'm happy with them but if there's a clearly better option out there, I might be game.  Thanks.
sandsawmill14
i have switched to deep cycle marine batteries on all my equipment and seems to have helped. even replaced the 4d size batteries with them and so far so good but only time will tell :)
Kbeitz
Batterys will last a long tme if you put a battetry minder on them.
Love machine shop work
and Wood work shop work
And now a saw mill work
Chuck White
While my mill is out of service through the Winter months, I always have the 2.5 amp maintainer hooked up to the battery.
scsmith42
I once added up the replacement cost of all all of the batteries that I have here on the farm and it was over 4K  >:(  Since then I've added more equipment too.  Having to replace cheap batteries every couple of years is a loser...
About six or seven years ago I queried the members on this forum for their recommendations regarding long lasting but economically priced batteries.  The overwhelming consensus at that time was Duracel Gold's from Autozone.  I switched over, and have yet to replace any of them.
However, about three years ago Autozone quietly changed their warranty (as well as the product design), and when buying a replacement battery they had both the old and new models in stock.  Picking up both, I noticed that the new battery appeared to be about 15% lighter than the old model.  Hmm... coupled with reducing their warranty period it sounded to me that they had reduced the lead content and possibly the longevity of their batteries.  At that time I switched over to Panasonic Batteries from the local Batteries Plus.  Better warranty than the new Duracel Gold warranty, and I get a better deal on them (business discount).
I had some Optima batteries in some of my equipment, but moved away from them when I discovered that if you let them completely discharge they will go bad.  I had two in an old GMC truck (with an electric winch) that used to sit for months w/o being used.  One month out of the full replacement warranty period (3 years) both of my Optima's would not hold a charge and the pro-rated rate was still higher than a Duracel Gold.  So I switched over and have not looked back.
Ditto the comments recommending desulphanating chargers for batteries that are going to sit unused for a while.  They make a big difference.
Tom's 3638D Baker band mill
ddcuning
A friend of mine who helped me get my generator up and going at the house brought me a small plug in type float charger. He explained that if you keep a float charger on the battery, it will last for years and years. I have a large float charger on the two 8D batteries on the mill engine and the charger keeps them at peak at all times. I have not had any trouble with the batteries at the mill (of course, have not run it that much) or the generator at home using the float charger. I think the one for the generator was about $10 and it had a maintenance feature to aid in corrosion issues. Generator has been there for three years now with no battery troubles.
Dave C
We're debt free!!! - Dave C, Nov 2015
Something you guys may want to try. Find out who is the battery distributor in your area many times they have blemished batteries that they will sell very reasonable. I was a fire apparatus mechanic for 31 years and batteries were a lead plated hemroid to me. Best thing that ever happened was battery conditioners, all trucks and ambulance had a land line and conditioner. If you need a powerfull compact battery try what they call a group-31 you can get about 1000 cold crank amps from them. A good quality battery is a heavy battery. Frank C.
ladylake
Really good price at the local International  truck dealer over here  , $80 for a group 31
woodmills1
I thought the lead was replaced years ago by calcium.
Chuck White
Speaking of batteries, my truck wouldn't start today, battery issues.
I just put a new one in it a couple of years ago from Auto Zone.
They have a good warranty on them though, 2-year full replacement, I think it's a little less than 2 years ago that I put that in.   :P - warranty
Calcium was added to the lead in battery plates to make the batteries maintenance free. Myself I consider it of dubious value and prefer the old style where you had to add water occasionally. Frank C.
DeepWoods
I know this is not the norm, but last fall when I parked my skid steer for the winter I figured I would be replacing the battery in the spring.  Well when I went to start it for the first time this spring it turned over and was up and running after about three revolutions on the engine.  It has always been a good starter, but the battery is now on its 11th year.  I have not changed the battery in the time I have owned the Bobcat.  I don't even know who manufactured it as I have never had a problem with it.  Never even had to jump it.   I also had a deep cycle for my trolling motor in my boat that went 10 years before I had to replace it.  On the other side, I just replaced the battery for my Norwood Mill this year, only got two years out of it. And not covered under warranty. I think they just don't make them like they used to.
Norwood LM2000 with 23 HP Briggs and 21 foot track, Hand Built Logging Arch, Cooks Cat Claw Sharpener and Setter. 48" Xtreme Duty Logrite Cant Hook.
gimpy
I now replace my batteries with Optimas. I have had two Interstates and both have gone down at what I feel as short term. I am learning to keep my equipment batteries on tenders. But my truck has two Optimas and they are never an issue. Nothing but deep cycle for me whenever possible. I also buy online because I just saved over $50 on my new battery.
Gimpy old man
