1965 C5 Cancar Tree Farmer SPECS and INFO Thread.
Started by lshobie, October 20, 2021, 05:24:05 PM
lshobie
Hey all it's been a while since I've posted but here is my latest purchase. 1967 c5 with braden winch and detroit 353.  Runs great just going to set the rack, change fluids, repair some u joints and fix the two pitted  blade rams.  Bought it from the second owner  family who bought it in the early 70s.
One of the planetaries is leaking around the brass pin and I'm going to replace the brake and clutch cylinders as well.
It's hard to find info on these as it is scattered all over the place so I will post part numbers and info as I go in this top section:
Manuals, I haven't been able to find any for this skidder - help would be greatly appreciated - I will pay for them of course.
Service:
Operator:
Parts:
Model Cancar Treefarmer C5
Serial number_ 650512
Engine: Detroit Diesel 3-53 Naturally Aspirated
Engine Model Number 5033-7200. Unit number 17741
Max rpm 2830
Filters:
Hydraulic cartridge beside radiator. WIX 51567
Oil cartridge. 23522888, wix napa 1138, fram ch119pl
fuel filter element
Brake master Wagner 29744  FD2951 FE2951 29744 2951 29744C 5461387 616588 M68105 M1402121 M54484 M457266
Clutch Master FD2951 FE2951 29744 2951 29744C 5461387 616588 M68105 M1402121 M54484 M457266
Clutch slave.  doorman cs36164
Brake slave. doorman cs36164
Clutch and brake fluid DOT 3
Axles
Tranny T98-746.    (094)
Diffs:  #5200K532 (Y10)
Winch Braden
Tires 18.4-34 Forestry tire
8 bolt rim
Drive shaft U joint:
Winch U joint:
Hydraulic pump:
Steer control:
Blade control:
Fluids:
Engine Oil:  SAE 40 spring/summer/fall.  SAE 30 winter
Hydraulics:  ATF
Braden winch: 80w90 non hypoid
Planetaries:  ATF
Transmission:  80W90 non hypoid
Transfer Case:  80w90. Non hypoid
Air oil bath: any engine oil
https://www.youtube.com/watch?v=2LssgGcQoJE
John Deere 440 Skidder, C5 Treefarmer,  Metavic Forwarder, Massey 2500 Forklift, Hyundai HL730 Wheel Loader, Woodmizer LT40, Valley Edger,  Alaskan Mill, Huskys, Stihls, and echos.
That sure does look good!!
Even have all parts for the hood!!!
lshobie
lshobie
Detroit Diesel with oil bath air cleaner and oil cartridge not a spin on.  Generator and voltage regulator.
lshobie
Question:
This threaded hole - is it just a fill plug or should there be a breather tube in that?  Thanks!
lshobie
Kodiakmac
Quote from: lshobie on October 20, 2021, 08:21:24 PMThis threaded hole - is it just a fill plug or should there be a breather tube in that?  Thanks!
After checking what is/isn't in that housing, I'd be putting in a threaded plug.  Quickly.
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
Kioti rx7320, Wallenstein fx110 winch, Echo CS510, Stihl MS362cm, Stihl 051AV, Wallenstein wx980  Mark 8:36
bushmechanic
Nice score on the machine! The more I look at this I think it's not a C5 but a C4 Pulpwood special. That's a Cotta transfer case and the hole is for a 1/8 pipe thread vent. It's really in good shape for the year.
lshobie
Hey thanks, the tag says C5, I think its a c4 for the most part with the Detroit instead of the gasser?
Do you know anything about the two trunion mounts on the from axle...the pivots?  One is completely blown out ( the rear one) and it is making a big hole in the frame.  Im not sure how they mounted the front axle on that because both pins face into each other - unless the rear one was removable and slipped into place after the wishbone was installed?
Cheers and thanks for your comments.
Louie
lshobie
These pics were sent by another member so I know what how the cradle pins are set up.  Many thanks to him!
logman81
I had a very similar skidder except mine had the Ford gas and updated arch. It was in the same kind of condition yours was in but went through it and replaced all the worn out parts.
Precision Firewood & Logging
logman81
logman81
Mine was also a factory extended frame as well.
lshobie
Quote from: logman81 on October 27, 2021, 10:49:11 AM
That looks great!
lshobie
logman81
Should have kept the 664c clark even with the front motor mount being broken its still way more skidder then that tree farmer is. The little plug on the right side of that Braden winch is the fill line and use a rated oil for bronze gears. I went through my entire c4b which is the same machine minus the 353 DT and you can still get most parts for the old girl!
Don't overload it or this will happen to the planitaries
lshobie
Thanks for the info, just curious what overloading is lol, like....how many ash trees at show long and diameter?  Or red oak and diameter.  Straight pull.
Cheers
,louie
C5C Tree Farmer
Were you able to find parts for the master cylinders?
logman81
logman81
Parts are available through Harold's logging in Maine, Ask for Randy tell him Dave Peckham sent ya! I got all my parts from him when I restored my c4.
lshobie
Thanks David!
Here is a vid from yesterday.  Logging tomorrow after my wife opens her presents....
             https://youtu.be/H3FCsDLDz5s
lshobie
lshobie
logman81
I had the same winch on my c4b. Not to bad of a winch a tad on the slow side and can be a pain to adjust, keep it covered up when not using it to keep it from rusting up!
lshobie
Ya it's not like my clark winch but it does the trick.  Pretty impressed with this little skidder - very little damage in the bush and makes a nice atv trail at the same time.  Needs cab protection though - next summers project.
