Interior kiln plywood
Started by Tree Dan, March 19, 2021, 09:51:37 AM
Tree Dan
I cannot find Cdx plywood in Canada.
What else can I use?
Wood Mizer LT40HD, Kubota KX71, New Holland LS150, Case TR270
6400 John Deere/with loader,General 20" planer, Stihl 880, Stihl 361, Dolmar 460, Husqvarna 50  and a few shovels,
60" and 30" Log Rite cant hooks, 2 home built Tree Spades, Homemade log splitter
K-Guy
CDX plywood is just construction grade. Any good plywood will work.
Nyle Service Dept.
- D. Adams
Tree Dan
GeneWengert-WoodDoc
You do want plywood with an exterior adhesive.  That is what the "X" means?  Interior adhesives can result in delamination with moisture or heat.  cD-X is used for plywood sheathing in construction.  However, oftentimes plywood is rated with number, like 24/0, which indicates the acceptable span between joists, wall studs, etc.  look for the words indicating exterior.
