Need a skidder!!!!!!
Started by logger, October 08, 2005, 08:11:04 PM
logger
My tractor finally got too small for logging, I need a skidder.  It doesen't matter what brand it is, Deere,timberjack,franklin, dosen't matter.  I am starting to cut and skid, before I used to just cut, so I need a skidder BADLY!!!!!!  Has to be 10,000 or under, because I can only afford that much.  ANY HELP WOULD BE GREAT!  Thanks. 8)
220 Poulan            Future Saws
Stihl MS280             Jonsered CS2171
Stihl MS440 Magnum Husky 575XP
Stihl MS460 Magnum   Dolmar PS-7900
Husky 385xp            Stihl MS361  Stihl MS441 Magnum
Stihl 066 Magnum       Stihl MS660 Magnum
logger
Frickman
logger
Westmoreland, PA, close donegal.  In western PA.8)
Frickman
I'm not too far away. I'll keep a look out for you.
logger
Thanks!  I am still looking on machienerytrader.com , I think I am going to pick up a Heavy equipment trader and look through it.  Thanks guys!
Hoop
You'll be able to skid more wood with a 3-legged horse than you will with a $10,000 or less skidder.
Ever hear the phrase "worn out iron"?
Can you find skidders for $10,000 and under?  Sure!  You'll find machines with transmission cases held together with JB Weld, worn out center pins/bushings, leaky hydraulics, weak engines, weaker transmissions, no brakes, worn out tires, etc, etc.
