What would be the best handsaw for cutting beams and posts?
Started by LaneC, May 28, 2014, 10:30:47 PM
LaneC
    If one were to have only 1 hand saw to cut post and beams, what type and teeth per inch is mostly used, or considered the best. I am wondering about the saws that would be cutting from 4x4's up to 12x12's. Any suggestions or opinions are appreciated.
Man makes plans and God smiles
purple otter
The best thing would be to have both a rip and crosscut saw. I use an old Disston D-8 with 3 1/2 tpi to rip, and a Disston D-8 7 tpi for crosscut. Around here you can get these old saws for around $5 sometimes at flea markets or estate sales. If you learn how to properly sharpen them you will always have sharp saws and they will last you a long time. You will be amazed when you rip a tenon with a proper rip saw.
Hudson Oscar 228 on homebuilt trailer, Kubota B2320 with homebuilt forks,Stihl 028 Super & 029 Super, Solar Kiln .
LaneC
Thanks so much for the reply. That is just what I looking for. I truly appreciate the input. I guess they probably do not make them like they used to. I have looked on ebay and I have only found one with 5-1/2 tpi(teeth per inch). I will try and keep looking. Thanks again for the info, it was very helpful.
Jim_Rogers
If you do a search here on the forum you may/should find a story about the saw recommended by Jack Sobon, and we agree with him on this saw.
However, I recently was shown a new "timber" saw at a timber framing school in VT.
So, I went online, and found it available on Amazon and with shipping it was about $28.
I have received it, and I have tested it. It does cut both rip and cross cut very aggressively. And it states that you can file it to resharpen it. And it lists the file number you can buy from them for it.
It is made in Sweden.
Jim Rogers
PS. I hope to do a video of it sometime.
LaneC
Thanks for the reply. That seems a very good price. I will check that out ASAP. The ones on ebay are more than that with shipping. I have a 4 tpi and a 7 tpi picked out. They are the Disstons and have been recommended as well but a new saw at that price is good. I surely appreciate the input from all  and would like to see the video.
Dan Miller
I am also in the two saw camp. I use a vintage Disston 5-1/2 TPI thumbhole rip, and for crosscuts a Stanley Sharptooth 28" saw. The latter is the one Jack Sobon was recommended to students. The Stanley should be readily available at big box stores or better hardware stores; probably Amazon too.
Dan
LaneC
I think if I am able, I will be joining the Disston saw family. I will get 1ea. 3-1/2 to 4 tpi and 1ea.7 or 8 tpi. The file for the profcut saw is almost $70.00 unless I am reading it wrong. For those interested it is file no. 272. What size file would one need for the Disstons? Would 1 triangular file do it or 2 different sizes?
Brian_Weekley
If you're planning to sharpen your own saws, you will also need a jointer, tooth set, files, and saw vise.  I use old Diston rip saws and it's fairly easy to sharpen a rip saw.  However, I like the new Stanley Sharptooth 28 for cross cutting.  These have a very different tooth design than the old Diston crosscut saws.  They cut like going through butter.  However, you can't resharpen them easily and generally consider them disposable saws.
http://www.vintagesaws.com/library/primer/sharp.html
e aho laula
Dave Shepard
I use the Sharptooth for almost everything, although I'm looking to sharpen a few old handsaws I have. I have all the tools, just haven't tried it yet. A friend of mine says that a properly sharpened saw will out cut a Sharptooth. I also have a few Ryoba saws, they rip very well.
Chilterns
Hi Jim,
Could you please post a close up photo of the tooth pattern of the Bahco Profcut Timber saw and also advise the TPI. This looks like a good candidate for rough work.
Chilterns
PC-Urban-Sawyer
Quote from: LaneC on May 31, 2014, 12:37:15 AM
That's the price for ten of the 272 files.  Apparently they are only sold in packages of 10.  Too bad we can't get a few people to go in on getting a ten pack and splitting them up.  Course the shipping would get to be a bit much...
Herb
Jim_Rogers
Quote from: Chilterns on May 31, 2014, 12:28:17 PM
Hi Jim,
Chilterns
Here you go:
I don't know if you'd call that 4 or 4 1/2 teeth per inch.
Jim Rogers
Dave Shepard
LaneC
Thanks Brian weekly, you answered a question for me. The folks at a local big box store could not answer the question I had for them, as to the ability to sharpen these new saws. I now see they are basically disposable. That I do not care for. I bet they will cut good for a while though, but if I hit a couple of nails or something then you would have to get another saw. I saw that "10 pack" on the file description, but re-read and looked at the quantity which I thought said 1ea. however I guess they mean 1ea. package of 10. Thanks for clearing that up for me. I have yet to see a video of anyone sharpening that profcut. I am guessing it will be quite different than sharpening an old saw blade. Thanks for all of the input and recommendations. I appreciate it a lot.
LaneC
Thanks for posting the sharpening treatise also. Very informative, thanks.
Chilterns
Actually that might be 3.5 TPI. There are 7 complete teeth between the 1" and 3" mark (you don't count the first tooth on the 1" mark).
I have some old blunt 7-8 TPI Sandvik saws that are made from sharpenable i.e. not flame hardened steel and so I wonder If I could simply recut these to match the above tooth pattern by filing out every alternate tooth to make a deeper gullet ?
Chilterns
MattJ
If you search around for the files with the bahco part number on google you can find sellers selling individual files.  eBay had a listing for 29.99 for the file in handle with free shipping.  Granted that's the price of the saw but it makes it reusable.
Matt
LaneC
Thanks for the ebay tip. Has anyone seen a video or seen any procedures or examples of anyone using this kind of file on these new type teeth?
Dan Miller
Quote from: LaneC on May 31, 2014, 10:55:53 PM
Mine get cycled through a pattern of demotion - when too dull for timber framing, they get used in risky situations (like disassembling old boats, where fasteners are a risk), then relegated to being loaners for neighbors so they don't trash the good ones, finally, they are broken up into card scrapers.
I suppose the dull ones could be offered up to the saw painters, maybe in exchange for an old Disston or the like.
Dave Shepard
I've been saving my old Sharptooth saws. I want to take them to a saw shop and have them nibble new conventional teeth on them. I've even found a saw shop with a saw nibbler, just haven't gotten to it yet.
LaneC
Hello all. Dan miller, what is a card scraper? If you get these new type of teeth nibbled in will they be able to be re-sharpened?  Most of  the new ones, they are saying, are basically disposable. I have yet to see any videos or instructions on sharpening the fileable "new" saws.
Brian_Weekley
The "newer" saws like the Stanley Sharptooth and the Bahco Timber Saw use a three-sided sharpened tooth design.  Unlike a "traditional" Disston type saw that only cuts on the push stroke, the three-sided sharpened teeth allow the saw to cut on the pull stroke also.  These saws are manufactured and micro sharpened by machines.  However, the tooth design makes them much more complex to re-sharpen by hand (I'm guessing because I've never tried to sharpen this type of saw because I wouldn't know how to).  Some people like the Japanese saws that only cut on the pull stroke, but I don't know how to sharpen this kind of saw either.  Therefore, if you want to sharpen your own saws, go with the Disston--they're great saws and fairly straight forward to sharpen if you have the proper file, toothset, etc.  Otherwise, you can probably cut an entire frame with a "new" saw.  They're not that expensive so don't feel bad if you throw it away when your frame is done.
e aho laula
Dave Shepard
Quote from: LaneC on June 04, 2014, 10:16:24 PM
It is my hope that if I had these saws retoothed that they could be sharpened. The Sharptooth has the 3 edeged tooth design as Brian mentioned, and are not really made to be sharpened. They have a hardened tooth, which may be too hard for a file, and also they have 312 teeth, so I think that would take a while. :D Retoothing will cut the saw plate back behind the hardened part of the saw, so I should be able to file it.
TW
For crosscutting I use an old 28inch Disston number 7 of the old wide bladed variety. It has 4 1/2 teeth per inch and the same tooth type as the Sandvik beam saws. I like it a lot. It costed me half an euro at a farm auction. When it gets dull I resharpen it using a saw file with a diamond shaped section filing one side of a tooth at a time.
That type of saw teeth isn't new. It has been used by Scandinavian carpenters for at least 150 years. I suppose someone altered the tooth shape of my saw a century ago when it got here from America.
Personally I find a long an wide saw blade to be a great advantage for this kind of use. I have tried one of those Sandvik beam saws but as it was only 24" long the saw strokes had to be very short and the narrow blade flexed a bit too much for my taste.
D L Bahler
I used to use disston saws, I have a few of them. But, now I use stanley saws for just about everything, because I have found them for me to be the best balance of speed and precision.
For big cuts, I use an old frame (buck)  saw finding it to be a good method of cutting timbers to length.
But you have to add to this, I don't use saws as much as some might, and I don't like sawing. Also I don't like to sharpen saws.
