Material Handling
Started by Cypress Man, June 11, 2014, 10:18:21 PM
Cypress Man
Hi everyone.
We've just installed the new IC5 power conveyor and transfer table to improve material handling and increase production. So far things seem to be working well and should help improve production. The new log deck should be come in a few weeks to prevent the bottleneck feeding the mill. Will keep everyone updated on how it has helped our operation once the log deck is installed and will post more pictures.
LT70 wide head electric, IC5 Power conveyor, transfer table, Stop and Load Log Deck, Catapiller 360B Telehandler, Cat tl642c Teleloader, Cat TH514 Telehandler, Woodmizer EG400 edger, Logosol PH360 moulder, Extrema 26" Planner, Grizzly 16" dual conveyor resaw, Prentice 285 log loader
You have a very professional layout.   smiley_thumbsup
Bibbyman
The one big thing I came to understand about the production side of running a sawmill business is material handling.   The log deck will automate one aspect of the process but may complicate doing special jobs - short logs, odd shaped logs, etc.
Are you planning to run all the hydraulics off the mill pumps?  Are the pump or pumps 3ph AC? Or 12v DC?
Sawing since '94
Gadrock
The only other color that would be right...in this situation...would be
GREEN...envious green.
Carry on
LT40 G18,   bent Cresent wrench,   broken timing light
Prentice 280 loader, Prentice 2432 skidder, Deere 643J fellerbuncher, Deere 648H skidder, Deere 650H Dozer
backwoods sawyer
Hope it all comes together to make you good money. Noticed your sawdust bin under the edger another good time saver on clean up smiley_thumbsup
Backwoods Custom Milling Inc.
POSTON WIDEHEAD
WoodenHead
Very nice setup!  Someday I might get there.   :D
How many people do you have working with you?
Peter Drouin
I like the box under the edger. How long is the building to put all that in line? I thought about a log deck, But I cut a lot of big, long beams and it would be in the way. Nice job.
A&P saw Mill LLC.
License NH softwood grader.
brianb88
That there is a nice setup.
Measure twice, cut once
Cypress Man
Thanks for all the complements.
Bibbyman: Yes the hydraulic pumps are 3 phase AC. This is a wide head LT70 "ALL" electric mill. No contact strip means the hydraulics work in all head positions. That is really convenient.  I have a six foot extension on the mill so I can cut beams/lumber up to 26 ft long. I've also thought about some inconvenience with the log deck but I've convenced myself that i can reach beams over the top of the deck with the Cat 360B extended reach lift or simply reach it from the back side being the building is open on that side. I also have the option of dragging beams back onto the IC5 conveyor to the transfer table. There I can simply place the forks behind the transfer table and kick it off with the Kickers onto the forks. It seems simple enough in theory. Its coming in July 3rd so I'll let you know how that works out.
Backwoods Sawyer: The box under the edger is definately a time saver. Just lift it with the telehandler and go dump it.
Woodenhead:Somedays I have 3 people to run on other days 4. You can run smoothly with 3 but 4 is really easy on everyone. One floater can operate forklift hauling to and from the mill effortlessly.
Peter: The building is 100 ft. long on that side and it takes every inch . There is never enough room at a mill.
Dave Shepard
That looks like a really sweet setup. 8) I'd have just about the same thing, but I'd have the wireless remote and two BX24's. ;D I might have to build one of those boxes for me edger, too. I figure a good starter millshed is 30' wide and one side of the other of 900' long. :D You know, give or take a 100'.
drobertson
giant splinter
You sure have a very well thought out mill production area, productivity is what it takes to come out on top and it looks like you have done a great job of planning and putting it all together ...... nice layout!
roll with it
