Sawmill recommendations
Started by Aprilinnewyork, November 28, 2019, 12:42:22 PM
Aprilinnewyork
 ??? Recs for Sawmill in south central Virginia/north central North Carolina to rough cut 3000 sq/ft pine 1" plank flooring. Random width. They provide logs. Thank you!
   Go to the home page on this site and under the Extras tab is Find a Database. Select service as portable sawyer and enter your state and see if any of those are close enough. If nobody there, go to the Woodmizer.com site and under the Services tab you will see find a sawyer. Enter your state and check the list that shows up. Good luck. If I were closer I'd offer to do it but just a little out of my normal range.
Aprilinnewyork
Thank you for the tutorial, I'll search there. Like your sheep quote!
Southside
It's what I do. PM me if you would like to discuss. 5% of the proceeds will go to the Forum if we do business.
