Author Topic: cheap water pumping  (Read 3897 times)
Offline peakbagger
Re: cheap water pumping
« Reply #20 on: June 28, 2021, 05:56:27 PM »
Its going to be a dry summer, my solar well pump setup is no longer working as the water table dropped too low. I need to go with a positive displacement pump instead of an open impeller centrifugal bilge pump. I had a Nemo pump picked out as its the least expensive option I could find. They are on on backorder but should fit pretty well with the panels I have. Its a standard Shurflow type pump that a separate company converts to a submersible.
Offline chep
« Reply #21 on: July 30, 2021, 08:52:32 AM »
Check out bunyip pumps on the YouTube
Pretty neat concept
Offline peakbagger
« Reply #22 on: July 30, 2021, 04:21:20 PM »
Thanks, it looks like ram pump which is great if someone has low pressure supply and wants to boost it up, unfortunately I do not have low pressure supply. The ram pumps have even fewer parts
Offline mudfarmer
  • Mama Tried
« Reply #23 on: August 08, 2021, 03:42:46 PM »
You will like the Nemo. Mine is only at 25ft but has pumped a lot of water.
Offline peakbagger
« Reply #24 on: August 11, 2021, 07:45:59 AM »
I got the Nemo and was ready to hook it up and my poly tank sprung a leak. I need to fix it before the Nemo goes in. The tank was free about 20 years ago and I really do no know how old it is. It didn't have a steel frame and sagged when it was full and is leaking at a crease. Worse case is road trip to pick up a tank with cage on craigslist.
It does look like a nice unit.
Need to hook up 2 well water pumps to alternate pumping
Started by DR_Buck on General Board
Last post March 29, 2018, 04:26:32 AM
by Al_Smith
dolmar 119 No bar oil pumping
Started by nygrosity on Chainsaws
Last post January 15, 2014, 01:18:35 AM
by nygrosity
MS 650 oil pump not pumping
Started by alsayyed on Chainsaws
Last post March 22, 2007, 12:38:08 AM
by Bill
On demand domestic hot water using water to water heat exchanger?
Started by Fether Hardwoods on Firewood and Wood Heating
Last post July 26, 2015, 09:50:11 PM
by r.man
