Hey Folks,
I'm a commercial beekeeper thinking "out of the box" to try and keep my bees alive. There are some legume cover crops that I could plant in young stands that might help foresters and bees both. A mix of clovers, vetches and tansy can fix nitrogen and help control weeds for you while saving me the cost of artificial bee food. Bees are healthier on natural foods and when we truck bees to honey flows some diseased bees drift into the wrong hives and spread viruses.
Would the amount of nitrogen fixation significantly help your pine? I'm guessing there may only be 50 lbs/acre until the legumes are shaded out but there are other good benefits with cover crops. And it would be free to you. Would a cover crop interfere with your perennial weed control? How many years before the canopy shaded out the flowers? Do you use systemic neonic insecticides?
Twenty years ago bees made 200+ pounds of honey per colony, today they make 50 lbs. They are on life support. I think donating my seed and time to a young forest will be cheaper than my cost of food supplements. I'm guessing that 3-4 acres of pine would be required to support each hive, I need to do some experimental plantings to get realistic numbers.
Would this interest any foresters? I don't know much about pine management practices and don't even know if I'm asking you the right questions. But I'd sure appreciate your help. I live in Virginia and overwinter bees in Florida so anywhere near the I-95 corridor would be in my bee travels.
Thanks again for any help you can give.
Dave
Not sure about the Pine, but Tree Lucerne is probably the species you are talking about, and it's sometimes used locally as a "nurse crop", to help re-establish native forest. You plant it, but leave (or clear) gaps for the target trees. The long term trees, that often can't be planted in an exposed or full sun location, grow well in the shelter provided by the fast growing lucerne, then eventually overtop at as it matures and starts to die off 10-20 years down the track.
Now pine locally us usually planted dense so that it closes the canopy over quickly, then it's pruned and thinned to waste over the next 10 years.
But I can't see any reason your idea wont work with pine trees. Make sure you clearings for the pines are big enough to allow them plenty of light. Eventually the lucerne is going to get shaded and smothered by the larger pines, but you should get maybe 10 years of bee food before that happens, and better formed pine trees as they grow up through the nurse crop, and so shed their lower branches sooner.
If you have a good cover of Lucerne, then your other weeds should be less of a problem.
So I don't think the idea is crazy. Not worth the effort if you only want to grow pine trees, but throw in the bee keeping and that changes things.
Thank you, Ianab. I had not heard of that plant so I looked it up, it appears to be native to your area but not to the United States, which would probably make it an invasive here.
I don't know of any small trees used as cover crops in the States, usually the cover crops add nitrogen or biomass for mulch and weed supression. Nectar production usually isn't a priority for cover crop because most plant farmers aren't specialized beekeepers.
But thanks for letting me know that a small leguminous tree is used for this purpose on your side of the world.
Quote from: eastcoastbeek on September 23, 2017, 09:05:38 PM
........Twenty years ago bees made 200+ pounds of honey per colony, today they make 50 lbs. They are on life support. ........
where there as many beehives per acre back then as there is now?
where bees moved as much back then as they are now?
last year from 4 hives i got over 27 quarts from a total of 18 frames.
this year one of the lids blew off during a heavy rain storm = hive drowned.
another one was very weak and died.
the remaining two are doing great.
PM me is you want to talk bees.
Hey Folks,
I'm a commercial beekeeper thinking "out of the box" to try and keep my bees alive. There are some legume cover crops that I could plant in young stands that might help foresters and bees both. A mix of clovers, vetches and tansy can fix nitrogen and help control weeds for you while saving me the cost of artificial bee food. Bees are healthier on natural foods and when we truck bees to honey flows some diseased bees drift into the wrong hives and spread viruses........
good idea.
Following
I'd love to be involved in this type thing if I had the property. I have flowers growing around my house and have noticed the lower count of bees this year as compared to last year and I have more flowers blooming this year. We do have spraying for mosquitoes but I'm not sure if it is the selective chemical.
Black Locust is one to look into. Early season flowers, native, Nitrogen fixer, and rot resistant.
Quote from: DDW_OR on September 24, 2017, 02:19:09 PM
I've seen stats showing the drop from 4.8 million hives in the U.S. after 1945, declining to 2.5 million hives today. While that doesn't specifically compare today and 20 years ago, the long downward trend is well documented. Bees have always been moved for pollination, but fruit and vegetable industries have changed dramatically. I remember reading that blueberries now produce something like fifty times more fruit per acre than 40 years ago, and I believe other fruits have undergone a similar revolution. With blueberries and apples, for example, orchard water is recirculated, so systemic insecticide levels keep building higher until they are present in everything the bees touch (pollen, nectar, water that cools the hive). Neonics affect bee's sense of direction and they can't find their way back to the hive.
I'd be happy to talk bees anytime.
Quote from: TKehl on September 25, 2017, 01:40:12 PM
Beekeepers LOVE black locust, but I think it competes for too much sunlight to sit well with foresters. I need to plant you a ground cover that works for you, and cutting black locust after a few years seems a lot more expensive than just letting the taller pines shade out the short ground covers for free.
understory medicinals that flower at the times you are moving through? that would provide another crop as well.
I replied about black locust earlier but didn't give the full answer it deserved because I was in a hurry to pick up my kids. Although locust is nearly a perfect bee tree, I see two issues that would keep it from being interplanted among pine. First, it probably grows faster than pine so it would need to be mechanically removed, and this expense would almost certainly be higher than the value of added nitrogen. Locust used to have commercial value as fence posts, but those days are long gone so it would cost a forester more money than it returned.
Second, locust blooms for 2 weeks in June, when Mother Nature has already flooded the market with nectar. The pollinators can't keep up with all the food supply during May and June. More blossoms in June don't really help bees. The cover crop mix I suggest blooms July through October when there are few sources of nectar for the bees.
Timing is everything in the bee world.
Quote from: Don P on September 25, 2017, 07:01:24 PM
That's a great idea because many medicinals are great bee flowers. Rosemary, Borage, lemon balm, thyme, bee balm and others don't just produce lots of nectar but help bees shed mites naturally.
However medicinal seeds aren't cheap and they don't fix nitrogen for faster pine growth. Most are in the range of $50-200/lb and seed at 10-20 lbs per acre. In contrast, common cover crops like clovers, tansy, buckwheat and vetches are in the $2-3/lb price range and are sown at 5-10 lbs/acre. That's a big difference when I'm donating the seed.
I could grow patches of medicinals for seed and drop the cost, but I'd need a couple of years to ramp up.
And finally, I wouldn't be moving through with my bees. The wild nectar flow of May/June is available nearly everywhere, and if a cover crop blooms until October, I would leave my bees in the area May-October, until I move them to Georgia or Florida for the winter.
Thanks for the medicinals suggestion. They are great bee flowers, but I think legumes would give a higher return to the forester. And for this to work I need to show it increases profit for the forester.
Dave
I see you have mentioned vetches several times. Personally I find vetch to be a plague. It will overtake a pasture and crowd out good grass. I've heard it's good for livestock but I have yet to see my cows are equine eat any of it. I have been told that goats will eat. Might be good for ground cover in a reforestation area but I wouldn't want it to spread.
Just did a little bit of searching about vetch. What we have is hairy vetch and the seed is toxic to cattle.
Quote from: LeeB on September 26, 2017, 01:28:05 AM
I've also read of that issue with hairy vetch. There's a fine line between a plant that grows strongly enough to fertilize the trees but that doesn't grow so strongly to become invasive.
But I think even if a vigorous legume gets enough sun to establish in a young forest it probably won't be an issue for long. I think after 4-5 years the cover crops will be gone and I'll need to find a new tract for bee forage. Flowers may come back after thinnings, but probably only for a year or two until they are shaded out again.
It is easy for me to custom change the seed mix to address the issues of forest owners. Cover crops grow differently in different regions anyway.
Whatever you plant, please be sure it's not an invasive species. As an example, Crown vetch was recommended for erosion control by the Virginia DOT for a number of years. Now it is recognized as being very invasive. I always double check the seed mixes I use for meadow establishment against the VA Invasive Plant Species List.
Quote from: ESFted on September 26, 2017, 01:18:36 PM
I don't want to give the impression that I'm going to plant invasive species. That would be immoral and possibly disastrous for the environment. Consider what honeysuckle and kudzu have done to parts of the country.
But for foresters to grow faster pine, legumes as cover crops are a good option. Nearly every cover crop and clover in U.S. agriculture is an alien plant. They came from other parts of the world and were widely planted for 100 years before we discovered cheap artificial fertilizers in the early 1900's. Clovers are everywhere, just like dandelions.
Nothing is more invasive than the dandelion, which came over on the Mayflower. Because it's been here for 500 years, the "invasion" is over -- we lost and the dandelion won. That's not necessarily a bad thing. We list it as invasive because we don't like it in our lawns, but not because it doesn't provide lots of food for wildlife. Another example is the European earthworm. They have displaced native American worms and changed our forests in ways both better and worse, but we're not getting rid of our worms and dandelions any time soon.
Having said all that, planting invasives is a bad practice for everyone. There are plenty of good cover crops that aren't invasive.
Forester chiming in here......I think you have a couple of options. The I-95 corridor south of Virginia traverses the coastal plain. A lot of the intensive forestry operations use a bedding plow to raise the seedlings above the seasonal water table. To lower up front costs some operators have increased their spacing between rows and increased planting density within rows. This will result in increased time for the area between rows to become overtopped. You may be able to utilize this space for 7 or 8 years in a wide row spacing versus 4 or 5 in conventional planting. Utilizing legumes may provide some nitrogen benefit, but it will also promote recreational opportunities with hunting (most land is leased for hunting purposes - legumes may add value to the hunt club (hunting opportunity) and landowner (lease rates).
I think the stronger opportunity is post thin. There are equipment corridors, loading decks, and roads that can be utilized for your purpose. I routinely "daylight" roads during operations. We will alter thinning densities adjacent to roads and remove all timber on road edges to allow sunlight to the road surface. We also did this for years in support of bob white quail habitat. Your legumes would fit well in this scenario. If you are willing to maintain these strips, a lot of folks would probably work with you in perpetuity. Other opportunities are power line easements. A high voltage transmission line occupies significant area. One down side.....here in Southern Virginia, you will have to account for the bear population. One on my neighbor tends bees and he has a major issue with bears.
Wudman
Wudman,
That is valuable input. I didn't know about the wider row spacings. In that case the flower crops will definitely pay back the planting cost. I figured I needed at least 2-3 years of flowers to recoup the planting cost but 7-8 years would be great.
Many cover crops are annuals that reseed themselves, some require annual or biannual reseeding. I'd be happy to perpetually maintain open spaces and power lines to keep enough flowers in bloom for the bees and for game. Many flower seeds and root balls remain viable in the soil for 10-20 years, just waiting for new openings in the canopy, so post thin is a good option for me too. It's no problem for me to have a full yard for a few years, then drop to a maintenance number of hives until thinning reopens the canopy. I would track the number of hives times the weight of honey produced to get a feel for how many hives a parcel can support over time. Because bees only travel 2-3 miles, every parcel is unique.
There are also many good "wet footed" bee flowers for wide planted forests with seasonal water tables. All the members of the wort family (motherwort, figwort, spiderwort...) have high nectar production and grow in wet soils. So do some mints, bee balm, marsh hedge nettle, swamp sunflower, swamp aster, swamp milkweed, etc. Most of these are also expensive seeds, so I would need to harvest my own seed stock.
I guessed that cover crops would bring more game but didn't know how much. I need to research which cover crops are best at that. It doesn't even need to be a bee flower, I could alternate rows.
Bears roam through much the mid-Atlantic and the Southeast. I put an electric fence around every yard with 1.5-2 joules worth of current which has worked for me so far, knock on wood. Or wud, in your case.
Thanks to everyone for the continued input.
I've been doing some more research and I can add canola to the list of cover crops. It isn't a legume but is great for attracting game after some hard frosts. Here is something I found on a hunting forum:
"canola: In late fall after the first deep freeze of the year, a chemical reaction occurs where all the starch in the plant turns to sugar, making canola candy to the wildlife.
Canola contains both high oil content as well as high protein content.
It contains about 40% oil and 23% protein."
Canola is great for bees too. In a recent study bees were fed pollen with deficient levels of fatty acids. When they were offered new pollen choices with good Omega ratios they fed exclusively on the good pollen. So bees have a way of knowing good Omega ratios from bad ones. While I don't know if canola pollen has high Omega 3s like the seed, it is well known among beekeepers that bees love canola flowers.
In much of the southeast U.S. canola is a cool season crop in place of winter wheat. I don't know if spring planted canola will survive summer heat. It is a major summer crop in Canada (in fact, canola is an acronym for "CANada Oil, Low Acid) But at $1/lb for seed and only 4 pounds of seed per acre, it is worthwhile for me to plant canola as a cover crop and foresters can hopefully get more money out of their hunting leases. Canola only blooms for about a month, so I will probably need to stagger plantings.
Does this make sense to others?
OK, so after some more research there are some other good cover crops that deer love as well as the bees. Most of the brassicas have a good bloom and are good deer forage. In particular, some of the turnips also create deep air columns in the soil break up hardpan and increase water absorption. I remember from researching earthworms that these air tunnels are surrounded with aerobic bacteria which are more beneficial to soil than anerobic bacteria.
A lot of the clovers also fit the three big requirements. They are good deer forage, they bloom at the right times for bees, and the seeds are inexpensive. Alsike, dutch white, red and sweet clovers fit these requirements. Sweet clovers are a bit tall for very young stands.
My understanding is that many timber parcels are owned by insurance companies. So I will start contacting TIMOs and asking if they are willing to work with me if I can show that cover crops will increase their return on investment through nitrogen fixation and increased game forage and tilth.
Thanks to all who have contributed to this thread, by no means is the subject closed. Please continue to offer more advice.
Another thought. Seeding cover crops between rows of pine will be rough work, with all the downed logs, branches and everything. It would be easier to broadcast seed on the entire parcel just before the pine gets planted. Then I could get around the brush easier.
I am going to send you a PM right now. I would be very interested to speak with you about working together on our land in southern Virginia. On our land I am actually doing something very similar with silvaculture as the goal. I have played with bees for a couple of years with no degree of lasting success, mites got me two years ago, not really sure what happened a few weeks back when I lost several hives, but I have zero background with bees and nobody to mentor with. For what it's worth we use zero herbicide or insecticides at all on our property.
Quote from: Southside logger on December 23, 2017, 09:04:17 PM
.... I have played with bees for a couple of years with no degree of lasting success, mites got me two years ago, not really sure what happened a few weeks back when I lost several hives, but I have zero background with bees and nobody to mentor with. For what it's worth we use zero herbicide or insecticides at all on our property.
Mites to bees is like termites to wood.
eventually all gets infected with out treatment.
I also have limited knowledge of bee keeping and have tried no treatments but will be using various treatments in the future. i have been told to not use the same treatment more than two years in a row so the mites do not become immune. ideally one type per year.
Interesting post! I am curious for some input/info on my situation. I have about 3/4 acre on a steep hill, that I cleared in the Fall. We hydroseeded with micro clover (low and fast and known for nitrogen fixing since it's difficult to reach the area for fertilization), white clover and an American Meadows Northestern wildflower mix which had bloomers from early spring through late fall. This mixture contains 27 wildflowers, 17 annuals for first-year color, plus 10 perennials or biennials for second and successive years' bloom.
Since I have wooded areas too with a lot of undergrowth ranging from wild roses, to raspberries to downright even weeds and thorns of unknown species, there's a lot of blooms going on most of the growth season.
This is all at/near the site where I have my mill, which I did primarily for aesthetic reasons, but I'd also like to place a honey bee colony there and have the joy of harvesting my own honey.
Any comments about how much/large of a bee colony this may support and will the noise from the mill irritate the bees. The spot which I'd place hives is 250-300' from the mill.
Thanks!
I don't think the noise will bother your prospective bees at all. They will be fine near your mill. But the 3/4 acre of new forage will not tip the balance to feed your bees. A hive forages up to 8-10,000 acres and the amount of flowering trees or wildflowers in that big region is more crucial to hive health than a new small meadow. Every bit helps and I don't want to rain on anyone's enthusiasm, but I want to be realistic. Put up your first hive and see how much honey it collects, then you know whether your bees have the food resources to expand in the future. Often one beehive collects lots of honey when another one just 5 miles away collects very little. Regions vary greatly.
Quote
In general this is good common sense. There is an effective treatment method using oxalic acid which been used widespread for 15 years without losing effectiveness. But wherever you can, it is a good policy to vary the type of treatment to prevent resistance. Some of the treatment methods take more skill and experience so another factor to consider is what type of treatment you can make without harming your bees.
I got the PM and have enjoyed the conversation.
Quote from: PA_Walnut on December 24, 2017, 05:14:51 AM
.........Any comments about how much/large of a bee colony this may support and will the noise from the mill irritate the bees. The spot which I'd place hives is 250-300' from the mill.
Thanks!
Place the hives in an area that is not used much so they do not get disturbed.
I agree the noise from the mill will have little effect on the hives.
use a
motorized radial extractor to get the honey out of the frames.
I got my first hive off of Craigslist 12/07/14. it turned out to be a weak hive so i had to baby it through the winter. fed it sugar and installed a 3 foot heating tape on the bottom board.
the first year, 2015, i had two swarms move into my empty hive boxes, that made 3 hives total
in its first summer i got 12 frames of honey using the hand crank. as my mentor stated as he inspected the hives "no body gets this much their first year"
the reason is i am almost in the middle of nowhere. and there are very few beekeepers near me
and lots of blackberry.
2016, got 27 quarts of honey from 18 frames using the electric motor. my extractor is a 9 frame from http://www.brushymountainbeefarm.com/Advanced-Extracting-Kit_2
had to buy the motor separately
this year, 2017, i started with 4 hives. one died, one got drowned when the lid blew off during a rain storm. and the wet spring delayed honey production. so i could only get 3 frames safely
so in 2018 i will be splitting my remaining 2 hives to make 4. since i have 166 acres i will move the splits to the other end of the property. and install a solar electric fence to protect them from predators, bear, raccoon, skunk, and people.
lessons learned:
rise hive 2 feet off of ground
heavy brick or block on top of lid
hive medications to treat honey bee parasites
MOTORIZED extractor. it is like having an extra helper
in my area i have to worry about humidity in the hive more than the cold
tried putting a long heat tape around the extractor to add heat to make the honey flow better. it worked great. had to re-wire the tape so it would work at temps above 45 deg F
tried adding a water heater blanket, but it was a mess to clean
DDW, it sounds to me like you're doing everything right. Depending on how long your honey flow is in the spring, you might purchase a couple of queens and split your hives early in the year, when your flow is beginning. Often these splits fail because the bee population is too small to keep warm, but in your part of the country that is less of an issue.
I only suggest this because I get the impression that you have more hives when you wrote that you had a couple of empties laying around to attract swarms. If you're out of hive bodies, no need to make more splits. Also, with your acreage, you might do some selective plant growing to help your bees along your fence lines or any land that is not being worked for a higher purpose. You're right, blackberries are a very good source of food for bees.
Most people say that your plantings will make no difference but I think an acre of good bloom during the dearth will keep your hives alive and could still work with the other goals you have for your land.
Oops, upon re-reading your post I see that you have already decided to make a couple more splits. Nice to see an alignment of thinking.
the Douglas County Beekeepers Association sent out this news article.
further study is needed but outcome is promising. unless the Varroa mites develop a resistance.
___________________________________________________
Accidental Discovery Could Save Bees From Their Greatest Threat
They've found that a tiny dose of the compound lithium chloride kills Varroa destructor mites without harming bees.
https://www.realclearscience.com/quick_and_clear_science/2018/01/15/accidental_discovery_could_save_bees_from_their_greatest_threat.html
I have read sourwood trees produced exceptional honey. It definitely grows in the southeast and is otherwise useless. Unless you like to make arrows, it is the most prolific coppicing tree i have encountered and the shoots are very straight.
Deer will eat on the first year of shoots but will prefer gum ir maple sprouts (which also coppice great) over sourwood by the second year. I have clumps of sourwood shoots that grew from zero to 7ft in one season. Nothing else here grows that fast.
http://mtnhoney.com/types_honey.htm
Quote from: mike_belben on January 21, 2018, 08:30:44 PM
Don't y'all have kudzu down there? ;D
Ive seen it on my roadtrips along a lot of interstate but not anywhere in my area yet.
I hate Crown vetch. It almost ruined our Christmas tree farm. You can't kill it.
We have lots of problems in my area with bears stealing our honey.
How about sweet clover?
I like it. Years ago everyone was worried about the coumarin (sp?) that forms after flowering as it can kill livestock. It tolerates a wide range of soil types, is cheap and can be frost-seeded. I use it for a long term-cover crop (2 years or more before plowing down) or in the hog pasture after they have done their worst) :D and grazing before it flowers. It flowers a little later than a lot of the trees and native plants. Buckwheat might be an option the first year, though it doesn't fix N. Crimson clover is nice, but I don't think the bees can reach the nectar.
From a soil erosion standpoint, I think the cover crop would be worth it even without pollinator benefit, or even helping the trees get started.
If you are already mowing between the rows, white clover seems to be beneficial to the bees, though the fellow that keeps bees on our place doesn't put much stock in it. They work it pretty heavy, though. Busy bees and all that... Of course it shades out easily.
I am converting some acreage of poor woods into silvopasture slowly, so we are sort of going in opposite directions, but with some shared goals. I hope to read more about your endeavor!
Just in case you have not yet checked them out, let me suggest Ernst Seeds as a source for native seed mixes tailored to a variety of needs. I've been retired for a while, but used to use them all the time.
https://www.ernstseed.com/products/
