Coffee
Started by Larry, July 19, 2018, 07:11:19 PM
Larry
Tastes so much better when its made with a home turned coffee scoop. :D My first, but not my last. :)
Actually, my life is changing where I put a lot more value on lasting, well made things, that please my eye. Out with the cheap plastic junk made in a far away land.
Peter Drouin
Looks like that will work well for you. Nice job.
A&P saw Mill LLC.
License NH softwood grader.
btulloh
Nice work.  One scoop per cup?
HM126
Ljohnsaw
Turned it, as in on a lathe?  Do tell (with pictures).  I don't see how that was possible!
John Sawicky
Larry
It is run of the mill hard maple. Once I have the process down, I have some figured wood to try.
This is how the scoop is initially turned. When I have a perfect sphere for the scoop portion, I work on the handle. The axis of the handle is shifted about a 1/4" to both sides of the center axis on the tailstock end. The handle is turned on each axis giving it the oval shape.  Its amazing that a small shift on the axis can have such a big impact on the shape of the handle.
After the handle is complete I place the ball of the scoop in a jam chuck as shown. The scoop ball is held in the jam chuck with hot melt glue. The handle can be neutral or tilted forwards/backwards. The ball is than hollowed just like turning a bowl. I put a completed scoop in the jam chuck just for this picture.
The concept is called multi axis turning. I've turned a few other projects, but have just scratched the surface.
Ljohnsaw
Thanks for the lesson!  I was thinking of something way different and much more difficult to accomplish. :-X
John Sawicky
Larry
Somebody that knows the process and is a good turner can complete one in less than 10 minutes.  I'm around 45 minutes.
That is a thing of beauty.
YellowHammer
Very nice.  I've got to ask because I'm a smart aleck, but what will you do if you get a Keurig? :D :D :D
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Larry
You mean that ugly red thing on the left?  I'm not sure what she does, but it can't be as good as what I do. :D :D
IMERC
Quote from: Larry on July 20, 2018, 08:40:12 PMi'm not sure what she does,
makes coffee for the dog?
Who ever invented work didn't know how to fish.... Here fishy fishy....
IMERC
Banjo picker
Quote from: YellowHammer on July 20, 2018, 07:51:22 PM
Mine has two holders, one for ground and one for the pods.  Deb uses the pods I use ground.  Banjo
