Author Topic: New woodmizer rail  (Read 1127 times)
Offline MacPhly
New woodmizer rail
« on: May 08, 2021, 10:57:48 AM »
So I got my new lt35. Love this thing!! Itís like having a super power!
Anyway quick question. There seems to be some kind of coating on the rail. I started knocking it off with scotchbrite but now Iím having second thoughts. Is that just laying bare more metal to rust? Iím thinking itíll wear off eventually anyway but maybe Iím just speeding up the process...? Thoughts?
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: New woodmizer rail
« Reply #1 on: May 08, 2021, 12:28:55 PM »
If itís like the new Woodmizerís I have bought itís paint. Donít try to take it off just let it wear it off.
Offline donbj
« Reply #2 on: May 08, 2021, 12:53:56 PM »
As mentioned, no need to remove all the paint. The rollers only contact about a 1/8th inch path on the rail. I keep a bottle of atf and a narrow paint brush handy and keep surfaces coated with that when not in use and rust is not an issue.
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
Offline tawilson
« Reply #3 on: May 08, 2021, 02:21:28 PM »
At Dollar General the other day and saw a pan scrubber that holds soap and dispenses with a button. It works with at too. Since I got the Woodmizer I use it all over the place.
2017 LT40HDG35 WIDE
Woodmaster 725
« Reply #4 on: May 08, 2021, 04:22:39 PM »
Not sure about washing, but waxing sawmills is not allowed here. :D :D :D :D :D
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #5 on: May 08, 2021, 10:02:44 PM »
   Be sure to keep the felt pad soaked with ATF as described in the manual. Every time you run up and back it lubes the rail. I don't remember but seems like it is supposed to be lubed about every 4 hours or so. Just loosen the 2 wing bolts, lift the pad unit, clean out any accumulated sawdust, soak the felt pad with ATF and reinstall.
Offline Woodpecker52
« Reply #6 on: June 11, 2021, 12:04:13 PM »
Best accessory for a sawmill air compressor and long air handle, cleans off felt pads, belts, blades, tracks with ease.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline 711ac
« Reply #7 on: June 14, 2021, 05:03:42 PM »
I'm "dusting" with a Makita blower that uses the same batteries as all my other makita cordless stuff. Not an air compressor but if I don't let it build up it gets the job done.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: June 14, 2021, 05:34:32 PM »
I have a Stihl BG56C that travels with me and blows the sawmill off at the end of each sawing day.  It also serves very well blowing loose dirt from logs and even sawdust from a stickered stack of lumber.
It's air volume far exceeds any air compressor.
Offline John S
« Reply #9 on: June 15, 2021, 03:28:54 PM »
I wipe a light coating of ATF on the rails, blade guide arm, saw head masts and chains, each day with the end of an old sock.  I have seen YouTube videos where ATF is poured on the rails and it just seems to be flowing off.  Too much in my opinion.
2018 LT40HDG38 Wide
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #10 on: June 18, 2021, 08:51:32 PM »
I have the same blower!
At the end of the day, if you happen to be pressed for time getting back on the road, use the blower to cool off the muffler so you can install your cover.
Only takes a couple of minutes, rather than half an hour waiting for it to naturally cool!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Percy
  • Resident trouble maker
« Reply #11 on: June 19, 2021, 10:08:12 AM »
Leaf blowers rule!
Help - woodmizer bed rail alignment issue.
Started by Poweredward on Sawmills and Milling
Last post September 02, 2018, 08:59:44 PM
by terrifictimbersllc
New Woodmizer LT15 Start vertical rail not plumb
Started by AbbyR on Sawmills and Milling
Last post June 17, 2021, 11:45:42 PM
by AbbyR
WoodMizer LT40 Bedrail Adjustment, issue with shorter pivot rail adjustment.
Started by will49766 on Sawmills and Milling
Last post August 24, 2019, 07:15:35 PM
by will49766
question
Difference between twin rail and single rail
Started by kb3gkc on Sawmills and Milling
Last post July 06, 2020, 08:49:45 PM
by farmfromkansas
