Author Topic: A close call yesterday  (Read 1652 times)
Offline customsawyer
    • The Custom Sawyer
« on: June 03, 2021, 06:50:55 AM »
I'm moving all of my equipment home from the big mill I have cut for almost 16 years. My last load that I was hauling home was the mill itself. Knowing that the tires were dry rotted, I went ahead and put new ones on it. They only had to make it 55 miles to the house. You guessed it. Right side tire blew. Bad part is that due to the amount of sawdust corrosion, the tabs that are welded on the frame and bolts to the axle  broke loose. Axle went all the way back to the next two jacks, which put it at a bad angle. Sawmill jumped over in the ditch and almost turned over. Got it all back home but it sure did test the nerves. Y'all with the older mills might want to check those welds.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline caveman
  • In the land of the blind the one eyed man is king
Re: A close call yesterday
« Reply #1 on: June 03, 2021, 07:00:25 AM »
Dang, Jake.  That will make the pucker worms start crawling.  I am glad you and the mill are okay.  I look forward to seeing how you work the other LT-70 into your setup.  How far did you make it before things went awry?
Caveman
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: June 03, 2021, 07:01:24 AM »
That mill is destined for the Hall of Fame.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Southside
    • White Oak Meadows
« Reply #3 on: June 03, 2021, 07:03:17 AM »
Glad to hear that it all turned out OK in the end. Way too close for comfort.
White Oak Meadows
    • The Custom Sawyer
« Reply #4 on: June 03, 2021, 07:09:30 AM »
I made a little over 30 miles before the tire blew. This is the mill that has over 14,000 hours on it and it has cut over 30 million BF. The mill was cleaned up under every day but the sawdust would sit on top of those places and just keep rusting them out. I guess it is paying me back for all the abuse I have put it through.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: June 03, 2021, 07:13:06 AM »
Wowser Jake, the way I read it a "new" tire gave up?  I was wondering if the weld gave way first and the resulting damage got the tire and whatever else.  smiley_headscratch
No matter, I'm glad that it wasn't any worse and the old gal can live to see sawdust again with your new sawing profile.  smiley_thumbsup
    • The Custom Sawyer
« Reply #6 on: June 03, 2021, 07:17:37 AM »
Tire went first. Everything else followed. All I can figure is maybe a bad tire or it had a slow leak where it didn't seat good on the rim.
Offline Bruno of NH
« Reply #7 on: June 03, 2021, 07:22:11 AM »
Sorry to hear this
Hope you can get it back cutting.
It will be nice just working from your home operation I bet.
Will you run 2 mills at your mill yard ?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: June 03, 2021, 07:25:40 AM »
Yup, the rim could have been compromised by the sawdust too.  Just goes to show again that no good intention goes unpunished.
Offline Southside
    • White Oak Meadows
« Reply #9 on: June 03, 2021, 07:41:11 AM »
How did you end up getting it home?
White Oak Meadows
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #10 on: June 03, 2021, 07:58:38 AM »
At least it stayed shiny side up! Its better have your trailer in the ditch but right side up after a blowout, than try to over correct and roll it.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #11 on: June 03, 2021, 08:39:02 AM »
No kidding - close call, that came very near to ending a mills life.
Good driving skills Jake. 👍
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline scsmith42
    • Whispering Pines Farm
« Reply #12 on: June 03, 2021, 08:59:51 AM »
Scary....
Glad that you made it home Jake!
Tom's 3638D Baker band mill
Offline kantuckid
« Reply #13 on: June 03, 2021, 09:40:54 AM »
I decided to replace my single axle RV trailer tires as one had issues. The other side when I pulled the wheel had a large sidewall bubble not easily seen w/o crawling underneath the trailer. I bought trailer specific tires on Walmart.com on shipped to stored deal which allowed me far more choices than at a store plus I got them mtd & balanced as part of the deal. Hard to buy a made in USA tire these days.
Offline samandothers
« Reply #14 on: June 03, 2021, 09:46:08 AM »
Really sorry to hear and see this!   Glad it was the ditch side that this occurred on.  Glad y'all are safe and others not involved.
Offline Southside
    • White Oak Meadows
« Reply #15 on: June 03, 2021, 09:58:50 AM »
Actually I just remembered that when my 70 went back to Indy in the fall of' 19 they put on new, heavier, tires and wheels, updated the trailer weight rating and all. So for anyone with a 70 it's something to check into.
White Oak Meadows
Offline mike_belben
  • Pulp Friction
« Reply #16 on: June 03, 2021, 10:05:46 AM »
i am real glad to see you didnt roll the bed into a twist drill. thatd be a heartache.
losing a trailer axle is among my two worst destructive testing experiences, and ive run a lot of tests.
fortunately this one was detected and i only lost the 1mph turnaround crawl back to the house gamble.  yup, shoulda had it towed before it came off, live and learn.  hard to get ahead when youre money is always behind.  i didnt know what it was on the interstate the day before.. praise the Lord he gave me a bailout on that one.
PSA: never ever ever put off a teardown after youve had a random swerve and recover.  that only happened two times before it came plum off without a sound.  luckily by then i had pulled over, pulled the spindle cap and realized the nut and thread was wiped out.  that $200 tow woulda saved me thousands, and years without the truck. expensive wisdom, yours for free.
Psalm 37:16
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #17 on: June 03, 2021, 05:26:29 PM »
   Sorry to hear about it but glad you are okay. Is it still under warranty? :D (Probably not :()
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #18 on: June 03, 2021, 05:33:57 PM »
Mills are repairable or get replaced,
Glad your OK and no one was hurt
D
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #19 on: June 03, 2021, 06:04:30 PM »
Have a look at that rim carefully with a light or with some compressed air and check to see if the rim was leaking. Might not have been the tire.
Close Tornado Yesterday
Started by Qweaver on General Board
Last post June 28, 2010, 09:06:04 PM
by LOGDOG
Close call
Started by luvmexfood on Chainsaws
Last post March 03, 2014, 03:48:33 PM
by Step
Close call
Started by Jeff on Sawmills and Milling
Last post May 14, 2018, 10:56:58 PM
by larrydown60
Close call...............
Started by Burlkraft on General Board
Last post December 15, 2005, 10:42:33 AM
by OneWithWood
