Author Topic: Auto Brake  (Read 245 times)
Offline Bindian
  • Gender: Female
Auto Brake
« on: June 05, 2021, 03:47:14 PM »
I have a LT40 Diesel with auto clutch.  I adjusted my drive belt at 50 hours. The brake was not adjusted.  Now, at 150 hours, I adjusted my drive belt again.  I engaged the clutch and disengaged the clutch to check the blade brake.  Before today, the blade stopped instantly.
Now, after tightening the belt, the blade stops about a second later.  I went to adjust the brake band, where upon I noticed it is adjusted to the stops to tighten the brake.  Is blade stop in 1 second okay?  If not, how do I adjust the brake when the adjustment came maxed out from the factory?
hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel. An old Lull 644D-34 called Bull
My Hero is Johnny Jett
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Auto Brake
« Reply #1 on: June 05, 2021, 04:21:52 PM »
I was told by Wood-Mizer within 5 seconds which is about what mine does.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Auto Brake
« Reply #2 on: June 05, 2021, 08:15:58 PM »
I would say mine is 1 sec or so. If you are all the way adjusted on the brake. Check for  brake pad thickness
Offline Chuck White
  • Sawing Mobile since 2005
Re: Auto Brake
« Reply #3 on: June 06, 2021, 07:57:01 AM »
You're good with 1 second, Bindian!
My manual says the blade brake should be adjusted to stop the blade within 4-5 seconds!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Auto Clutch
Started by Magicman on Sawmills and Milling
Last post October 24, 2013, 05:33:03 PM
by Magicman
576 Xp auto tune
Started by ga jones on Chainsaws
Last post November 12, 2015, 09:01:20 PM
by 49er
Auto clutch
Started by stumpy on Sawmills and Milling
Last post April 30, 2007, 07:51:43 AM
by woodbeard
auto idle
Started by doug olsen on Sawmills and Milling
Last post February 27, 2016, 08:57:20 PM
by MartyParsons
