Best peavey
Started by bulldozerjoe, June 11, 2021, 08:21:22 AM
bulldozerjoe
 Looking for peavey, any recommendations
New holland tc 45
Fransguard 4000
Sthil 021-028super-029-066
Southside
Logrite, look no further. Link on the side of the page. Multiple sizes available.
Anything other than a logrite and you lose. Anyone that tells you different simply does not know what they are talking about and it is that simple.
   Think of it as an essential piece of sawmill safety equipment. When the point of the LogRite peavy or cant hook bites into the log it is either going to roll or the wood will give way first rather than slip which is what often happens with other brands. Trust me - you do not want your hook slipping when you are putting a lot of weight into turning a big heavy log.
Nebraska
Your chin will thank you!  Mine did..  Logrite only.
maple flats
Logrite, absolutely the best, accept no look alikes.
Patrick NC
I use a 60" logrite. I like the peavey over a cant hook because you can stick the point in the ground to stand it up vs leaning it on something or bending over to pick it up every time.
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Wudman
You can bet your (whatever) on the Logrite.  It will bite and you won't break a handle when all of you is behind it.  Best hands down.
Wud
Charlie Daniels
I always get a kick out of the idea that people like a peavey for its ability not related to working it. Namely sticking in the ground. I can see the prying and levering advantages for those that need it, but I just never needed or desired a kickstand for my canthook. ;)
Old Greenhorn
That's a no-brainer: LogRite for all the reasons above.
Old Greenhorn
You know it is funny Jeff, I thought the same thing, but really needed the cant hook style so I got that. Now I find that I can usually stab that tip in the ground enough to make it stand anyway. So win-win. 8) 8)
 The nice thing about the cant hook style is that the dog end can catch right on the corner of most square cants, thereby minimizing any damage to the cant. Those cheapos have a sharp dog and I really hate finding the gouge it leaves in an otherwise perfect board.
The only question the OP really needs to answer is what style and what length does he need. I am loving my extreme duty 60" hook, but plan to add a 48" down the line.
Southside
A viable, quality, alternative would be to get a Logrite.
terrifictimbersllc
60" regular LogRite peavey if you just want to get your show on the road.
trimguy
I've tried the other ones, definitely get a Logrite. I have a 60" even though I don't use it as much with the hydraulics I still need one with the mill. Thinking of adding a 48" to it. Mine are cant hooks.
Patrick NC
Quote from: Jeff on June 11, 2021, 11:00:57 AM
I sort of thought the ability to stand it where it's handy for me to grab it when I need it was a valid use. I do also pry and use it to turn logs, but the fact that it's standing there within arms reach is what I like best. Somehow my cant hook always finds its way to the ground or I have to walk a few extra steps to lean it on something.
moodnacreek
Kinda hard to jump logs with a cant hook. Don't listen to me, go to a log rolling contest. I worked a wooden log deck for years and turned logs on the carriage all day long would not agree with any of the above but I have never used a portable band mill either.
maple flats
Logrite, peavy or cant hook, I have both (in 60"), I also have a 4' cant hook and a Monster one in 78" for the BIG logs. I prefer the cant hook but both do the job.
Gere Flewelling
My son is into woodsman's competitions and says his Grandfathers 100 year old peavey made in Maine is the best as it has just the right ark on the hook to catch and release when you are rushing to roll a pine log.   It has won him some first places. He also prefers to use it when helping me on the sawmill.  I think the main factor is the fact that Grampie gave it to him and told him some if it's history before he passed.  As for me, I like the Logrite's and will usually grab that one first.
Old 🚒 Fireman and Snow Cat Repairman (retired)
Matthew 6:3-4
As far as the Peavey/Cant hook angle, I don't have anywhere handy to lean mine that it isn't in the way, I often use it to pry and leverage the end of a log to get it aligned with my mill, and I have hydraulics so I never need to turn a cant by hand. So it is Peavey, Peaveyn and Peavey for me😁 It's really just a matter of preference and difference in workflow, if I was turning cants on a mill bed I would say cant hook, because the peavey point gets in the way in that situation.
bulldozerjoe
Quote from: Old Greenhorn on June 11, 2021, 11:37:54 AM
Yes, I'm 6'2
New holland tc 45
Fransguard 4000
Old Greenhorn
Quote from: bulldozerjoe on June 11, 2021, 06:23:26 PM
Yes, I'm 6'2
Well your height doesn't really have anything to do with it. The size of the logs or cants your are turning does. The lignite hook have different sized hooks for different diameter logs. Check their website I am pretty sure it gives size ranges. Pick one that matches your needs and your logs.
bulldozerjoe
I just orderd the 60 inch for my 30 inch mill on trailer
New holland tc 45
Fransguard 4000
Old Greenhorn
Quote from: bulldozerjoe on June 11, 2021, 06:37:58 PM
Great choice! That's what I have, I got the extreme version (Yellow). You'll like either one.
dgdrls
to your left.  And if the planets align which they should this year
go the Boonville NY loggers festival and meet Tammy and Kevin.
Awesome tools!
D
