Timbco 425c 8.3ct engine rebuild
Started by davidn3, November 03, 2022, 01:40:44 AM
davidn3
Come to find out, a mouse chewed through the heater hose behind the cab.  Didn't realize I was low on coolant.   Coolant temp never got hot, but probably was low enough that the temp gauge was just reading voided temps.  Developed a tapping top front of the engine. I replaced the tensioner pully and water pump (how I found the low coolant) I got concerned that I dropped a valve seat.  Took the head off.  Valve seats and head look good.  Pistons all look good.  Took the radiator out and cover off the front end.  All gears look good.  At this point I'm not too far from being able to just pull the engine,  clean it up and do a rebuild. My question right now is how is the engine flywheel attached to the transmission if at all.  Bolted?  Just splines on the shaft?
kiko
It has a splined shaft and a drive plate. Unbolt gearbox from engine flywheel and it will slide apart.  Also replace the gear box seal.  When reassembling place the seal in the gear box and the the shaft into the gearbox, that way you won't poke the seal lining it back up
davidn3
Thanks.  Are these flywheel bolts accessible by taking the starter off?  That was my next step when I get the chance.  The access cover on the opposite side doesn't expose any bolts to remove.
kiko
No internal bolts just the ones on the outside where gearbox bolts to engine flywheel housing.
davidn3
Ok.  I misunderstood.   That makes things easier.   So Just bellhousing bolts and slides out.  Thanks a lot.
charles mann
@davidn3 does your 8.3 have an air intake water cooled aftercooler? Iv got an 8.3 with an aftercooler, but wanting to do a delete, and instal an intercooler/charged air cooler, but the military vehicle community doesnt seem to have an option for an aftercooler delete. Plus i need find a way to instal an intercooler with the limited space i have between the radiator and hood grill.
Temple, Tx
kiko
Charles, this question was not directed to me , but I can help you.  There were two different  heads that took different intakes.  One has 18 bolt and one 16? If you have 18 bolts on your aftercooler I could provide you an engine serial number that ha the 18 bolt intake
 you can see the intake here on this 8.3 without aftercooler
Seeing two pics posted. Are they the same, or should we be able to detect something different in the first vs the second?
kiko
Accidental double. Maybe this on will be more understandable.   This is an intake on a 8.3 cummins without an aftercooler. One with an aftercooler , the aftercooler would be located in the same position as this intake.
Fuel injection lines will be routed differently to go around the aftercooler
charles mann
@kiko
Thanks. I'll see if my back has the strength to fold open my hood and get a ladder to climb up on the tire and count the bolts. If if im not able to heave the hood up, i'll dig the tm to see if it says the qty of bolts on the rmvl/instal of the aftercooler.
The eng you posted the pictures of w/o an aftercooler. Is it turboed?
Temple, Tx
kiko
It does have a turbo, it pipes straight into the intake, no CAC.  But CAC piping could be plumbed in to this intake
davidn3
Mine doesn't have an intercooler or aftercooler.  Was thinking about putting one on, but didn't want to interfere with fuel lines and etc.
