Spencer Tapes
Started by JBS 181, September 17, 2009, 08:06:38 PM
JBS 181
When you have a tape break on you and the spring unwinds. Is there an easy way to wind that spring back up without tearing the whole thing apart?
pasbuild
If it can't be nailed or glued then screw it
chevytaHOE5674
Easy way? No
Possible? Yes
Paul_H
You should be able to loosen(not remove) the ring of small screws and wind the spring back up by turning the Blue side clockwise.Mine are the Spencer loggers tape and they don't have to be taken apart if the spring isn't broken.
Clark
Do as Paul said but I would add that you need a way to prevent the tape from unwinding every time you wind the spring up.  If there isn't a tape on it, I just shove a flat-head screw-driver between the reel and the body of the Spencer tape.
Clark
SAF Certified Forester
mike_van
I use a Stanley 20 ft tape, as the longest log my mill  will take is 16 ' 6".    I made up a longer tip for it, so it wouldn't pull off the end of the log.  Cheep? Me?  maybe............ :D
I was the smartest 16 year old I ever knew.
Wild willy
If the spring un spools it's like like a saw spring just wind it back wards take the tape off and plan for half hour it takes time but it works us your thumb as the stop or a flat head I a us my thumb works faster then hold and put the tape back on and it will wind up sometimes u may have to do a time or two
Timberjack 225c/john deere 640/Clark 665 husky372xp/385xp/288xp
Bill Hibbs
