Author Topic: Spencer Tapes  (Read 2127 times)
Offline JBS 181
Spencer Tapes
« on: September 17, 2009, 08:06:38 PM »
When you have a tape break on you and the spring unwinds. Is there an easy way to wind that spring back up without tearing the whole thing apart?
Offline pasbuild
Re: Spencer Tapes
« Reply #1 on: September 17, 2009, 08:23:09 PM »
no
If it can't be nailed or glued then screw it
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
Re: Spencer Tapes
« Reply #2 on: September 17, 2009, 08:26:29 PM »
Online chevytaHOE5674
  • Forester
Re: Spencer Tapes
« Reply #3 on: September 17, 2009, 08:55:33 PM »
Easy way? No
Possible? Yes
Online Paul_H
Re: Spencer Tapes
« Reply #4 on: September 17, 2009, 10:18:15 PM »
You should be able to loosen(not remove) the ring of small screws and wind the spring back up by turning the Blue side clockwise.Mine are the Spencer loggers tape and they don't have to be taken apart if the spring isn't broken.
Offline Clark
Re: Spencer Tapes
« Reply #5 on: September 18, 2009, 11:00:18 PM »
Do as Paul said but I would add that you need a way to prevent the tape from unwinding every time you wind the spring up.  If there isn't a tape on it, I just shove a flat-head screw-driver between the reel and the body of the Spencer tape.
Clark
SAF Certified Forester
Offline mike_van
Re: Spencer Tapes
« Reply #6 on: September 19, 2009, 06:05:02 AM »
I use a Stanley 20 ft tape, as the longest log my mill  will take is 16 ' 6".    I made up a longer tip for it, so it wouldn't pull off the end of the log.  Cheep? Me?  maybe............ :D
I was the smartest 16 year old I ever knew.
Offline Wild willy
  • Logger
Re: Spencer Tapes
« Reply #7 on: September 20, 2009, 08:19:31 PM »
If the spring un spools it's like like a saw spring just wind it back wards take the tape off and plan for half hour it takes time but it works us your thumb as the stop or a flat head I a us my thumb works faster then hold and put the tape back on and it will wind up sometimes u may have to do a time or two
Timberjack 225c/john deere 640/Clark 665 husky372xp/385xp/288xp
Bill Hibbs
50' SPENCER TAPES and anything else!
Started by BradMarks on Pacforest Supply Company
Last post March 06, 2015, 11:24:02 AM
by BradMarks
Spencer logging tapes
Started by Nate379 on Forestry and Logging
Last post February 05, 2015, 07:41:23 PM
by Jhenderson
VHS tapes - conversion to still pictures
Started by woodbowl on Technical Support Topics
Last post September 14, 2005, 05:17:41 PM
by Furby
sad
Cassette tapes and little bitty moths
Started by woodbowl on General Board
Last post November 07, 2007, 04:09:30 AM
by SwampDonkey
