Author Topic: Have been running new homebuilt sawmill for a week.  (Read 3631 times)
Offline davey duck
  • 607-731-7062
« on: March 27, 2012, 01:15:35 AM »
new  home built mill ,I am running the saw with a 7.5hp 1725rpm motor ,waiting for the new 14hp 3450rpm to get here this week.It is just a little slow cutting with the 7.5.the 3hp hydraulic power unit runs the saw head just fine.just need to get the hydraulic clamps and the log turner built and installed.most of the logs I have cut are 30-36 inches in dia. and 16 feet long .and seem to end up 50% over the log scale.
David G.Fleming
Offline Woodchuck53
Re: Have been running new homebuilt sawmill for a week.
« Reply #1 on: March 27, 2012, 01:47:17 AM »
Nice machine Davey. What size iron do you have under it? Looks like you built plenty of strenght in it. Have fun, stay safe.
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
Offline barbender
« Reply #2 on: March 27, 2012, 01:59:25 AM »
That's a nice looking mill, nice heavy frame under it too.
Offline davey duck
  • 607-731-7062
« Reply #3 on: March 27, 2012, 02:24:58 AM »
the frame is made of 6x12" I beams that weigh 1200 lbs. each they were 40 feet long cut them down to 30 feet and used the 6 39" peices for the sub frame.it seems that most of the logs weigh well over a ton each.the mill is still a work in progress.
David G.Fleming
Offline customsawyer
    • The Custom Sawyer
« Reply #4 on: March 27, 2012, 04:07:23 AM »
Nice looking mill. I bet it will handle them logs just fine.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline mometal77
« Reply #5 on: March 27, 2012, 04:31:29 AM »
Looks like you have over come all the hurdles now everything is down hill.  Great looking mill.
Too many Assholes... not enough bullets...I might have become a millionaire, but I chose to become a tramp!
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #6 on: March 27, 2012, 06:22:03 AM »
Nice looking mill you've got there Dave.  8)
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline morgoon
  • Location: North Western Ontario...Probably further North than the other Northern Ontario
« Reply #7 on: March 27, 2012, 06:48:16 AM »
That's amazing!
I'd love to see more pictures of the hyd set up
Great work
Homemade bandsaw, made by my mentor and dear friend Unto...who turned 85 this year
And I just made my first longbow...awesome
Offline fishpharmer
« Reply #8 on: March 27, 2012, 07:58:39 AM »
Very well done. 8)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline bandmiller2
« Reply #9 on: March 27, 2012, 08:04:42 AM »
Good job on the mill Ducky,are you running on single or three phase,I know a 14hp single is a rare bird.Just rechecked the name tag, my band runs on a 1750 Baldore three phase,enough power to run the band and a hydraulic pump for band head lift and carriage travel.Have a seperate 2hp motor driving A pump in the base for turning and clamping.Your right about the weight of logs many builders try to cheap out on the steel,not a good idea,you can't build a mill too strong and heavy duty. Frank C.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: March 27, 2012, 09:10:19 AM »
That is a hunka sawmill for sure and log weight will not be a problem for that frame.  Congratulations.   :)
Offline thecfarm
« Reply #11 on: March 27, 2012, 09:48:28 AM »
What kind of logs you sawing that big?   8)  Almost looks like hemlock. What's all the lumber going to be used for?
Offline davey duck
  • 607-731-7062
« Reply #12 on: March 27, 2012, 12:00:09 PM »
  the logs are poplar most of the trees I have cut havehad 3 or 4 17foot logs in then.also a few more photos.
David G.Fleming
Offline Al_Smith
« Reply #13 on: March 27, 2012, 09:28:04 PM »
Wow that frame is a stout one for sure .Looks like about mile of hydraulic hose too .
Offline davey duck
  • 607-731-7062
« Reply #14 on: March 27, 2012, 11:34:45 PM »
the motor is 1 phase and the same on the new motor coming next week,the hydraulic hoses are 48' feet long x4,  the backstop has 2 -12foot hoses plus all the one on the power unit.I am looking for a hydraulic chain turner and clamp like on a Woodmizer or just start building one thanks for all the nice comments.I started building the sawhead over a year ago,it has been a real adventure finding all the parts on ebay and at auctions.I had a Turner Mill ,just sold it this week,a demo . on my new mill sold the old one,just to prove the power of sawdust. David.
David G.Fleming
Offline york
« Reply #15 on: March 28, 2012, 07:56:32 AM »
David,good to see the beams being used,looking good.....
Did you say,you had a hose crimp machine???
albert
Albert
Offline Al_Smith
« Reply #16 on: March 28, 2012, 08:19:35 PM »
With few exceptions a 10 HP is usually as large of a single phase motor as  you can find .They of course make larger but in over 40 years of being an electrician I've only seen a few .They were oldies and huge .
Geeze I'll bet that larger motor will be a heavy rascal . I've got an old 5 HP single ,1125 RPM that must weigh 200 pounds itself .
Offline bandmiller2
« Reply #17 on: March 28, 2012, 09:50:39 PM »
Davey,I ment to say I have a 15hp three phase on my bandmill and its plenty to run the band and and hydraulic pump.Al at one time I had a 50 hp single phase motor it ran an old cider mill,I got rid of that sucker when I read how many reddy kilowatts it would draw,had to move it with a loader. Frank C.
Offline davey duck
  • 607-731-7062
« Reply #18 on: March 29, 2012, 12:04:01 AM »
I bought the motor as a ten hp on ebay he said it would produce 14hp,but I am only counting on it doing 10hp it draws around 50 amps under load,it is a 3450rpm Im guessing it will use 25-30 amps with no load ,it is a 1 phase,sometime down the road we may change the electric service to 3 phase for the barn ,that might save money,the motor weighs 175pounds and it is new .
David G.Fleming
Offline Al_Smith
« Reply #19 on: March 29, 2012, 06:06:33 AM »
It's a light frame motor then if it only tips the scales at 175 .Don't get me wrong because it will work no problem .
When they say "will produce " what they are refering to is it will run in an overloaded condition .It's most likely a 1.35 service rating .
Getting a tad off the subject but I've seen really really old motors that were rated for only maybe 3 hp but weighed about 4-500 pounds .Big old low speed motors from probabley the 1920's or 30's .
Homebuilt sawmill
Started by ajccmc on Sawmills and Milling
Last post May 17, 2006, 04:51:29 PM
by lmbeachy
Waiting on Sawmill, a 72 week wait????
Started by Steve Samson on Sawmills and Milling
Last post June 08, 2021, 03:51:38 AM
by redbeard
Sawmill is running again
Started by thecfarm on Sawmills and Milling
Last post March 17, 2012, 07:55:52 PM
by macpower
thumbup
Sawmill is up and running!!
Started by Sawdogg on Sawmills and Milling
Last post December 16, 2019, 08:25:45 PM
by Gearbox
