Author Topic: WM 6' Bed extension connection inprovements with pictures  (Read 7563 times)
Online GAB
Re: WM 6' Bed extension connection inprovements with pictures
« Reply #20 on: July 19, 2015, 11:58:39 AM »
I'm going to be adding a BX12 to my BX24 soon, and my extension was not drilled on both ends from the factory. I've got a friend making a drilling jig right now. The factory hole on mills that are drilled is .500". If you drill your mill this size, then you will be able to use the newer extensions, as well as buy the proper tapered pins from Wood Mizer. From what I'm told, all BXs are drilled both ends now. The rails are case hardened, so you can drill the middle easily.
Dave:
I suggest that you grind a flat spot the entire length on the side of your pins before you install them as alignment pins are very tight fitting.  This will allow for air to escape or get in as you install or remove them.  Also the flat spot would allow a place to get penetrating oil to get in.
Again, just a suggestion.  I didn't and one pin is stuck in the extension and the other is stuck in the mill.
Gerald
W-M LT40HDD34 w/6' ext & SLR, JD 420, JD 950w/loader and Woods backhoe, V3507 Fransguard winch, Cordwood Saw, 18' flat bed trailer, and other toys.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #21 on: July 19, 2015, 01:59:18 PM »
The pins are different diameters on each end. I think they are designed to stay in the extension, which is logical, but I also have one in the mill and one in the extension.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #22 on: July 19, 2015, 02:22:51 PM »
Dave - when I built my two extensions, I worked up a drill bit guide to centre the holes to the rails.
I used cut-off Sched 8 bolt shanks for the pins, and cut them for length so that they would 'float' in the holes. Two 3/4" holes = pin 1 1/4" A dab of No-Seize on them before they went in will keep them mobile.
Send me a PM if you'd like to borrow my jig - it's small and shipping wouldn't take long.
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline flatrock58
« Reply #23 on: July 19, 2015, 08:48:07 PM »
Dave, I wanted to see where the drilling jig went?  I would like to drill mine and it would come in handy if I could borrow it.  I have a 6' extension that came with my mill and has never been used by me or the original owner.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
Offline pineywoods
« Reply #24 on: July 19, 2015, 08:50:42 PM »
Member slingshot came up with a simple, easily built jig for drilling the ends of the rails. I built one and used it to drill the rails on 4 mills and 1 extension. A search should find it, or there are pics in his gallery,,
Online Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #25 on: July 20, 2015, 01:41:56 PM »
I think slingshot sent it to me, I used it and sent it to @stephen1 in Canada. I'm not sure if he sent it on to someone else or not.
But there is one floating around somewhere......
Jim Rogers
Offline beenthere
« Reply #26 on: July 20, 2015, 02:44:09 PM »
Jim
The @ function needs to have the exact lettering... i.e. @Stephen1 should work. ;)
Offline Stephen1
    • muskoka Sawmill
« Reply #27 on: July 20, 2015, 03:12:18 PM »
Hey that @ works! I know I have the part you are talking of Jim. I have not had to use my extension in a while. I will look for it.
Offline flatrock58
« Reply #28 on: July 20, 2015, 06:53:20 PM »
Stephen If you find it I would like to use it to drill my be rails.  I don't have access to a machine shop any more to make one.
Steve
6' extension
resaw attachment
CBN Sharpener
Solar Kiln
Online Jim_Rogers
    • jrsawmill.com
« Reply #29 on: July 20, 2015, 08:12:24 PM »
Jim
Thanks beenthere......
Offline Andries
« Reply #30 on: July 21, 2015, 01:42:10 PM »
Clamp it on the rail and drill.
Pretty straight foreword - but yeah, a lathe is needed to make one.
LT30G24, LT40G25
Stihl chainsaws
    • My homepage
« Reply #31 on: August 03, 2015, 08:24:28 PM »
Picked up my drilling jig today. Will drill mill and extension in the morning. Photos don't do it justice.
Offline tmilham
« Reply #32 on: June 08, 2021, 10:21:08 PM »
Anyone have one of these drill jigs that they would care to rent out?
Tim Milham
Offline Andries
« Reply #33 on: June 08, 2021, 11:28:40 PM »
Mine is buried deep in a storage shipping container.
I'll send it to you if I can get my mitts on it in the next little while.
LT30G24, LT40G25
Stihl chainsaws
Offline Stephen1
    • muskoka Sawmill
« Reply #34 on: June 09, 2021, 06:24:19 AM »
I had found the one I had, but then I moved. I will keep thinkin and hopefully a 4 AM wake up will tell me where it is.
Pictures of my LT-30 with extension I built for sawing 21' logs
Started by Slingshot on Sawmills and Milling
Last post November 16, 2010, 11:38:19 PM
by Slingshot
Angle Iron Connection for Post and Tie Beam Connection
Started by Jjoness4 on Timber Framing/Log construction
Last post October 04, 2017, 05:42:14 AM
by MbfVA
connection to hot tub
Started by xlogger on Firewood and Wood Heating
Last post October 11, 2014, 06:16:39 AM
by xlogger
losing my connection to FF
Started by 47sawdust on General Board
Last post June 27, 2015, 10:46:26 PM
by Brian_Rhoad
